nRF_SoftReset issue query!!
I am using nRF52832 EVM board with SDK 15.3.0 in SEGGER studio IDE, win 10.
When I am implementing sd_nvic_SystemReset(); in my code, that time i am not able to write data  in flash.
Before writing data device is getting reset. So data is not getting store in flash
Solution done by me:
1. I have tried with delay after writing data to flash, then reset the device, still facing same issue.
2. Another solution,I have created a timer of 5 sec and after writing data in flash Timer is getting started and after 5 sec device is getting reset. In this scenario it is working fine.
Any solution/ suggestion why it is behaving in this manner?
Urvisha
    Consider using the FDS module if you are not using it. The FDS module has events that can tell you when a flash write/erase is done.
    Regards
  • HI,
    Writing to flash is asynchronous.
    When using the SoftDevice API, you will get a SoC event from the SoftDevice when the flash operation is complete or has failed, i.e. NRF_EVT_FLASH_OPERATION_SUCCESS or NRF_EVT_FLASH_OPERATION_ERROR.
    When using SDK libraries, there are other events that signals that a flash operation has succeeded or failed, depending on the flash library used.
    In any case you should wait for the appropriate flash operation event before resetting the device.
    Terje
