Strange interaction between SysTick and Sleep
I am currently using SysTick to count milliseconds in my device. This works fine, however with it enabled I can't sleep the device as it wakes up instantly.
I have tried to disable it, however it does not work. The following code blinks the LED unless I remove the references to SysTick_Config
    SysTick_Config(SystemCoreClock / 1000);
    syshal_gpio_init(GPIO_LED_GREEN);
    for (;;)
        syshal_gpio_set_output_high(GPIO_LED_GREEN);
        for (uint32_t i = 0; i < 1000000; ++i)
            __NOP();
        SysTick->CTRL = 0;
        nrf_pwr_mgmt_run();
        syshal_gpio_set_output_low(GPIO_LED_GREEN);
            __NOP();
I'm almost certainly going to switch to using an RTC but it would be nice to understand why this does not work.
I am using the nRF52840 with no softdevice
    The SysTick requires that the CPU is running on nRF52 devices, so when you enter sleep (WFE/WFI), the systick is suspended.
    Using RTC is a recommended option.
    Håkon
  • The SysTick stopping when sleeping is actually the functionality I'm after. My issue is more surrounding the fact that SysTick appears to be waking my device from sleep
  • Could you try rebooting your device with the debugger detached?
  • Hi Roy, unfortunately the results are the same
    In some cases I have seen the debugger mess with the sleep modes but this code seems to fail every time with or without it.
    Increasing the timer period to 1000ms from the current 100ms seems to resolve the issue but I can't imagine why. Unfortunately that's not a fix I can use for my application
    EDIT: I've tested the following interrupts and none appear to be being entered that shouldn't. The device is also definitely not resetting
    Reset_Handler <- Not sure as the startup file handles this one
    TIMER3_IRQHandler <- Does get entered
    // None of the below are entered
    NMI_Handler
    HardFault_Handler
    MemoryManagement_Handler
    BusFault_Handler
    UsageFault_Handler
    SVC_Handler
    DebugMon_Handler
    PendSV_Handler
    SysTick_Handler
    POWER_CLOCK_IRQHandler
    RADIO_IRQHandler
    UARTE0_UART0_IRQHandler
    SPIM0_SPIS0_TWIM0_TWIS0_SPI0_TWI0_IRQHandler
    SPIM1_SPIS1_TWIM1_TWIS1_SPI1_TWI1_IRQHandler
    NFCT_IRQHandler
    GPIOTE_IRQHandler
    SAADC_IRQHandler
    TIMER0_IRQHandler
    TIMER1_IRQHandler
    TIMER2_IRQHandler
    RTC0_IRQHandler
    TEMP_IRQHandler
    RNG_IRQHandler
    ECB_IRQHandler
    CCM_AAR_IRQHandler
    WDT_IRQHandler
    RTC1_IRQHandler
    QDEC_IRQHandler
    COMP_LPCOMP_IRQHandler
    SWI0_EGU0_IRQHandler
    SWI1_EGU1_IRQHandler
    SWI2_EGU2_IRQHandler
    SWI3_EGU3_IRQHandler
    SWI4_EGU4_IRQHandler
    SWI5_EGU5_IRQHandler
    TIMER4_IRQHandler
    PWM0_IRQHandler
    PDM_IRQHandler
    MWU_IRQHandler
    PWM1_IRQHandler
    PWM2_IRQHandler
    SPIM2_SPIS2_SPI2_IRQHandler
    RTC2_IRQHandler
    I2S_IRQHandler
    FPU_IRQHandler
    USBD_IRQHandler
    UARTE1_IRQHandler
    QSPI_IRQHandler
    CRYPTOCELL_IRQHandler
    PWM3_IRQHandler
    SPIM3_IRQHandler
    EDIT2: I've tried this on two of our custom boards and also on the PCA10059 Dongle
  • I have attached two variants that cause this behaviour. One is based on SysTick and the other on a Timer. It seems to be timing related as tweaking NOP_COUNT determines if the device sleeps properly or not
    #include "nrfx_timer.h"
    #include "nrf_gpio.h"
    #define NOP_COUNT (1000000) // Works if changed to 100000
    const nrfx_timer_t timer_inst = NRFX_TIMER_INSTANCE(3);
    void timer_irq(nrf_timer_event_t event_type, void* p_context)
        const nrfx_timer_config_t timer_config =
            .frequency          = NRF_TIMER_FREQ_125kHz,
            .mode               = NRF_TIMER_MODE_TIMER,
            .bit_width          = NRF_TIMER_BIT_WIDTH_32,
            .interrupt_priority = 6,
            .p_context          = NULL
        nrf_gpio_cfg_output(NRF_GPIO_PIN_MAP(0, 11));
        nrfx_timer_init(&timer_inst, &timer_config, timer_irq);
        nrfx_timer_extended_compare(&timer_inst, NRF_TIMER_CC_CHANNEL0, 125 * 100, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true); // 100 ms
        nrfx_timer_enable(&timer_inst);
        for (;;)
            nrf_gpio_pin_toggle(NRF_GPIO_PIN_MAP(0, 11));
            for (uint32_t i = 0; i < NOP_COUNT; ++i)
                __NOP();
            nrfx_timer_disable(&timer_inst); // Disable the timer
            __WFE();
            // Clear the internal event register.
            __SEV();
            __WFE();
                __NOP();
    #define NOP_COUNT (10000) // Works if changed to 1000
    void SysTick_Handler(void)
        // Setup systick
        SysTick->LOAD  = (uint32_t)((SystemCoreClock / 1000) - 1UL);     // set reload register
        NVIC_SetPriority(SysTick_IRQn, (1UL << __NVIC_PRIO_BITS) - 1UL); // set Priority for Systick Interrupt
        SysTick->VAL   = 0UL;                                            // Load the SysTick Counter Value
        // Enable SysTick IRQ and SysTick Timer
        SysTick->CTRL = SysTick_CTRL_CLKSOURCE_Msk | SysTick_CTRL_TICKINT_Msk | SysTick_CTRL_ENABLE_Msk; // Works if this line is removed
        for (;;)
                __NOP();
            //SysTick->CTRL &= ~ (SysTick_CTRL_TICKINT_Msk | SysTick_CTRL_ENABLE_Msk); // Irrelevant
            __WFE();
            __SEV();
            __WFE();
            //SysTick->CTRL |= SysTick_CTRL_ENABLE_Msk | SysTick_CTRL_TICKINT_Msk; // Irrelevant
                __NOP();
  • I think the ordering of your sleep routine is the reason why you're seeing this behavior.
    Try setting sev/wfe/wfe instead.
    Read this thread for more detailed info: https://devzone.nordicsemi.com/f/nordic-q-a/10424/nrf51422-won-t-sleep/38735#38735
    Håkon
  • Thanks Håkon, that's exactly what's happening. Any periodic interrupt that occurs just at the right time can cause this to happen. It just so happens that my code is of that perfect timing to cause this to always happen.
    What's happening is the SysTick event is pending just as WFE is called, this means WFE is effectively treated as a NOP. The next time through the loop the same happens at exactly the same time
    The fixes for this are:
    a) Use SEV, WFE, WFE. This is risky as stated by Radoslaw Koppel in the thread you linked
    b) Randomise when you call WFE, SEV, WFE. This removes the "perfect storm" timing issue
    c) Don't use periodic interrupts
    I am going to use C as a solution. I can emulate the SysTick's functionality I need by using a Timer and a Counter joined with PPI. This prevents me needing to generate any interrupts at all. I assume A is not a solution if you use the softdevice as I imagine that internally this uses the WFE, SEV, WFE sequence
