I have troubles with the timer interrupt. The code work fine until the timer hit the compare value and then stop.
This is my function for the timer init:
void timer_init(uint32_t periode_ms){ uint32_t time_ticks; // config timer nrfx_timer_config_t timer_cfg = { .frequency = NRF_TIMER_FREQ_500kHz , .mode = NRF_TIMER_MODE_TIMER, .bit_width = NRF_TIMER_BIT_WIDTH_32, .interrupt_priority = NRFX_TIMER_DEFAULT_CONFIG_IRQ_PRIORITY, .p_context = NULL }; // init timer APP_ERROR_CHECK(nrfx_timer_init(&TIMER_LED, &timer_cfg,timer_led_handler)); //transform ms in system ticks time_ticks = nrfx_timer_ms_to_ticks(&TIMER_LED, periode_ms); // config timer periode nrfx_timer_extended_compare(&TIMER_LED, NRF_TIMER_CC_CHANNEL1, time_ticks, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true); // start timer nrfx_timer_disable(&TIMER_LED); nrfx_timer_clear(&TIMER_LED); nrfx_timer_enable(&TIMER_LED); }
Here is the handler function:
void timer_led_handler(nrf_timer_event_t ev_type, void* p_context){ bsp_board_led_on(1); }
In the main function, i have a rudimentary loop to blink another led
int main(void){ log_init(); bsp_board_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS); gpio_init(); timer_init(1000); /* Toggle LEDs. */ while (true) { nrf_delay_ms(200); bsp_board_led_invert(0); } }
The led 0 blink during approx. 1s and then remains off and the led 1 never turn on.
I'm using the SDK 15.3.0 59ac345 on a nRF52832 on a custom board and developping with ECLIPSE/GCC.
