parameters to modify to set properly the rx transceiver
hi, i'd like to make communicate 2 different nrf24l01+ without the enhanced shockburst if possible, i'm using arduino to control the tx and fpga to control the rx; i'd like to know which register i should modify to allow the communication (i'll insert the code below) and in particular i'd like to know the way i must configure the rx address with the respect to the tx one since i can't understand much in the datasheet.
    //disable auto ack- not used
    u8 raaREG = 0x01;
    u8 waaREG = 0x21;
    u8 disableAA = 0x00;
    u8 *disableAAp = &disableAA;
    u8 *raaREGp = &raaREG;
    u8 *waaREGp = &waaREG;
    Xil_Out8(IRQ_BASE_ADDR,0);
    XSpiPs_PolledTransfer(myinstanceptr,waaREGp,NULL,1);
    XSpiPs_PolledTransfer(myinstanceptr,disableAAp,NULL,1);
    Xil_Out8(IRQ_BASE_ADDR,1);
    XSpiPs_PolledTransfer(myinstanceptr,raaREGp,dummyp,1);
    XSpiPs_PolledTransfer(myinstanceptr,dummyp,dummyp,1);
	//frequency setup
	u8 freq = 0x39;
	u8 *freqptr = &freq;
	u8 wFRREG = 0x25;
	u8 rFRREG = 0x05;
	u8 *wFRREGp = &wFRREG;
	u8 *rFRREGp = &rFRREG;
	XSpiPs_PolledTransfer(myinstanceptr,wFRREGp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,freqptr,NULL,1);
	sleep(0.1);
	//following reading operations are for debug
	XSpiPs_PolledTransfer(myinstanceptr,rFRREGp,dummyp,1);
	//Setting retries to 0
	u8 retry = 0x00;
	u8 *retryp= &retry;
	u8 rREGrty  = 0x04;
	u8 wREGrty = 0x24;
	u8 *rREGrtyp =&rREGrty;
	u8 *wREGrtyp = &wREGrty;
	XSpiPs_PolledTransfer(myinstanceptr,wREGrtyp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,retryp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rREGrtyp,dummyp,1);
	//data rate setup and PA level
	u8 datarate = 0x26;
	u8 *datarateptr = &datarate;
	u8 rDRREG = 0x06;
	u8 wDRREG = 0x26;
	u8 *rDRREGp = &rDRREG;
	u8 *wDRREGp = &wDRREG;
	XSpiPs_PolledTransfer(myinstanceptr,wDRREGp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,datarateptr,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rDRREGp,dummyp,1);
	//setup address width
	u8 rawREG = 0x03;
	u8 wawREG = 0x23;
	u8 *rawREGp = &rawREG;
	u8 *wawREGp = &wawREG;
	u8 width = 0x03;
	u8 *widthp = &width;
	XSpiPs_PolledTransfer(myinstanceptr,wawREGp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,widthp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rawREGp,dummyp,1);
	//rx pipe setup
	//activate pipe 0 to receive
	u8 rxpipe = 0x01	;
	u8 *rxpipeptr = &rxpipe;
	u8 rRXREG = 0x02;  //activate pipe 0 to receive
	u8 wRXREG = 0x22;
	u8 *rRXREGp = &rRXREG;
	u8 *wRXREGp = &wRXREG;
	XSpiPs_PolledTransfer(myinstanceptr,wRXREGp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rxpipeptr,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rRXREGp,dummyp,1);
	//setting pipe width
	u8 rRXPIPE = 0x11;
	u8 wRXPIPE = 0x31;
	u8 *rRXPIPEp = &rRXPIPE;
	u8 *wRXPIPEp = &wRXPIPE;
	u8 rxpipebyte = 0x20;
	u8 *rxpipebyteptr = &rxpipebyte;
	XSpiPs_PolledTransfer(myinstanceptr,wRXPIPEp,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rxpipebyteptr,NULL,1);
	XSpiPs_PolledTransfer(myinstanceptr,rRXPIPEp,dummyp,1);
	    // register config setup commands
		u8 pwrup = 0x0A;
		u8 *pwrupptr = &pwrup;
		u8 primrx = 0x0B;
		u8 *primrxptr = &primrx;
		u8 rREG = 0x00;
		u8 wREG = 0x20;
		u8 *rREGp = &rREG;
		u8 *wREGp = &wREG;
		XSpiPs_PolledTransfer(myinstanceptr,wREGp,NULL,1);
		XSpiPs_PolledTransfer(myinstanceptr,pwrupptr,NULL,1);
		sleep(0.3);
		XSpiPs_PolledTransfer(myinstanceptr,primrxptr,NULL,1);
		sleep(0.3);
		XSpiPs_PolledTransfer(myinstanceptr,rREGp,dummyp,1);
		Xil_Out8(CE_BASE_ADDR,0x01);
		sleep(0.2); //need to wait after setting nrf as receiver
 //i'm not posting the rx address commands since it does not work, p.s. the xil out of the irq base addr is the low high high low transition of the csn and the xspipspolledtransfer is the spi transfer of fpga
 // xspipspolledtransfer is defined as (spi channel, *txbuffptr, *rxbuffptr, size(it has not to be increased of 1 as the arduino function does) )
  //for each step i first overwrite the register and then i check the result so the parts of the reading (the ones with dummyp) can be ignored
