My HTC Nexus 9 tablet OS 7.0.1 does not see the advertisements from an nRF5840 dongle running the BleHeartRateMonitor demo from pc-ble-driver. All my other Androids do. Is this a known issue with the HTC tablet?
Did you remember to manually enable "coarse location" privilege for the app? Android apps need this in order to be able to receive BLE advertisements.
Yes. It discovers other BLE devices without a problem. The Android settings menu doesn't see it either, and that does NOT need any location permissions. The only thing I can think of is that there is something funky in the advertisement that the HTC does not like. I just wondered if there are certain Androids that do not work with the nRF52840. Buy any BLE device on the market and there are typically a set of Androids they do not work with.
I think I have an answer to this one. It looks like the HTC Android will not accept an advertisement unless it has a flags field. The example ble heart rate monitor ads did not contain a flags field. I added one and the device was discovered. I do recall that if you did not set the does not support EDR/BR bit, Androids would do EDR/BR.
I would suggest adding the following code to the BleHeartRateMonitor
// Set the flags - important to indicate no EDR/BR support for some Androids
data_buffer[index++] = 2; // length of flags data type
data_buffer[index++] = BLE_GAP_AD_TYPE_FLAGS;
data_buffer[index++] = 6; // No EDR/BR support and general discoverable
to add the flags to the advertisement. This will stop Androids from falling back to their default behavior of selecting EDR/BR when nothing is provided. (This is a behavior of the Broadcom stack as I understand it.)
