Hi Marcus,
The HWID is related to the nRF91DK.
When working with the Thingy:91 you should use the IMEI + PIN code.
The Thingy:91 needs to be connected to the network to be able to be paired with your cloud account.
The default application running on the Thingy tries to connect to the LTE-M network, so if you are in an area where you only have nb-IoT you need to flash the nb-iot version of the application.
When connecting to the nb-iot network you most likely have to use a local SIM from the carrier provider since the iBasis has limited support on the nB-IoT network.
If you do not have an nrf91DK or an external j-link with a 10-pin cable to connect to the Thingy:91 you can switch out the Firmware by following this guide: https://devzone.nordicsemi.com/nordic/cellular-iot-guides/b/getting-started-cellular/posts/thingy91_2d00_fw_2d00_update_2d00_mcuboot
Martin L.
Thank you very much for the explanation and reply.
- Here in Hamburg there should not be an issue with a connection (LTE-M / NB-IoT)
- In the documentation the blinking blue LED is descirbed as a sign for connection
- In your video it is told that there should be a green light.
- Also in your video it is told that the registration comes first and then the device is connected
So which way around?
I also tried a different SIM from Hologram. It does also not work properly. No Connection.
Sorry, but there seems to be an issue with the device.
I would like to return this one and get a new one.
Hi Marcus,
From this list you can see which carrier in your country support the different networks:
https://www.gsma.com/iot/deployment-map/#DE
The iBasis SIM card states that they have "Limited coverage" in Germany.
The issue is most likely not with the device, but with the SIM + and which network you are trying to connect to.
The "green light" represents that the device is ready for pairing with an nrf cloud account and the "dark blue" light represents that you have a connection with your nrf cloud account.
From what I can see from the official list from GSMA and the Hologram coverage site:
I would assume that you could get a connection by using the Hologram SIM and running the nb-IoT version of the Thingy:91 FW.
You can download that here.
Then you follow the guidelines presented in the previous post and flash the "thingy91_nbiot_legacy_pco_v0.2.2" version.
(Legacy PCO means that you are not enabling ePCO in the modem, since from experience the eNB (basestations) in your area supports legacy PCO)
Martin L.
So please flash the NB-IoT version and you should get a connection.
