Access the led_state value in the blinky app example, for using it in the main function !
hi ,
new to Nordic developmen. struggling to access the characteristic data to be able to use it in the main function !
i have started with the blinky app example as it covers my needs for the ble setting (need one service + 2 characteristics ) . for my project i need to use the characteristic data (the  led_state  in the example ) in my main function .
but the led_state data seems to be not accessible at this function !  have tried the memcpy() , can't copy it .
please kindly guide .
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
if(led_state){
        bsp_board_led_on(BSP_BOARD_LED_0);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(BSP_BOARD_LED_0);
        NRF_LOG_INFO("Received LED OFF!");
    "led_state" is a variable that only exists inside led_write_handler() and you cannot use it outside of this function.
    What you can do is to create a static variable outside of the function to store the LED status information and then use this variable in main().
    For example:
    static uint8_t m_led_state;
        m_led_state = led_state;
        if (led_state)
            bsp_board_led_on(LEDBUTTON_LED);
            bsp_board_led_off(LEDBUTTON_LED);
  • hi,
    thanks for your reply !
    i have merged the pwm driver example with the blinky example to be able to control the PWM duty cycle via an application on my phone .
    i can control the pwm's duty cycle from the app , but the control seems to be dellayed ! when the ducty cycle goes up , it is kind on working , but when it goes down the control seems to take lot of time .
    i use a slider in the app for controlling the duty cycle , the app will keep writing new values to the led characteristic when ever the slider value updated .
    this is the pwm example i used . so basicaly i just copy the led_sate variable from the led_write_handler() an passe it to the pwm_update_duty_cycle() function .
    i have enabled the required settings in the sdk_config file for the PWM , it is working fine . the example work as expected !
    the issue where just when we add the ble control .
    #include <stdio.h>
    #include <string.h>
    #include "nrf_drv_pwm.h"
    #include "app_error.h"
    #include "boards.h"
    #include "bsp.h"
    #include "nrf_drv_clock.h"
    #include "nrf_delay.h"
    #define OUTPUT_PIN LED_1
    static nrf_drv_pwm_t m_pwm0 = NRF_DRV_PWM_INSTANCE(0);
    // Declare variables holding PWM sequence values. In this example only one channel is used
    nrf_pwm_values_individual_t seq_values[] = {0, 0, 0, 0};
    nrf_pwm_sequence_t const seq =
        .values.p_individual = seq_values,
        .length          = NRF_PWM_VALUES_LENGTH(seq_values),
        .repeats         = 0,
        .end_delay       = 0
    // Set duty cycle between 0 and 100%
    void pwm_update_duty_cycle(uint8_t duty_cycle)
        // Check if value is outside of range. If so, set to 100%
        if(duty_cycle >= 100)
            seq_values->channel_0 = 100;
            seq_values->channel_0 = duty_cycle;
        nrf_drv_pwm_simple_playback(&m_pwm0, &seq, 1, NRF_DRV_PWM_FLAG_LOOP);
    static void pwm_init(void)
        nrf_drv_pwm_config_t const config0 =
            .output_pins =
                OUTPUT_PIN, // channel 0
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 1
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 2
                NRF_DRV_PWM_PIN_NOT_USED,             // channel 3
            .irq_priority = APP_IRQ_PRIORITY_LOWEST,
            .base_clock   = NRF_PWM_CLK_1MHz,
            .count_mode   = NRF_PWM_MODE_UP,
            .top_value    = 100,
            .load_mode    = NRF_PWM_LOAD_INDIVIDUAL,
            .step_mode    = NRF_PWM_STEP_AUTO
        // Init PWM without error handler
        APP_ERROR_CHECK(nrf_drv_pwm_init(&m_pwm0, &config0, NULL));
        // Start clock for accurate frequencies
        // Wait for clock to start
        while(NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
        pwm_init();
        for (;;)
            for(int i = 0; i <= 100; i++)
                pwm_update_duty_cycle(i);
    Can you attach the code where you use PWM+BLE?
    Marjeris
