Central part of relay not connecting to the other peripheral board
I have added  nus service to the relay central and peripheral example.The relay board advertises and i can connect to the peripheral part of device through the nrf connect app.When another board which has ble_app_uart peripheral advertises ,the central part of the relay is not able to establish a connection to the peripheral and the scanning and advertising LEDs of both the boards  start blinking with some frequency.I am not able to figure out the problem.I think the code is getting stuck somewhere in the ble_evt_handler function in the central gap role part.Code attached for reference.
Thank You
 * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE Heart Rate and Running Speed relay application main file.
 * @detail This application demonstrates a simple relay, which passes on the values it receives.
 * By combining a collector part on one end and a sensor part on the other,
 * the s130 can function simultaneously as a central and a peripheral device.
 * The following figure shows how the sensor ble_app_hrs connects and interacts with the relay
 * in the same manner it would connect to a Heart Rate Collector. In this case, the relay
 * application acts as a central.
 * On the other side, a collector (such as Master Control Panel or ble_app_hrs_c) connects
 * and interacts with the relay in the same manner it would connect to a heart rate sensor peripheral.
 * LED layout:
 * LED 1: Central side is scanning.       LED 2: Central side is connected to a peripheral.
 * LED 3: Peripheral side is advertising. LED 4: Peripheral side is connected to a central.
 * @note While testing, make sure that the Sensor and Collector are actually connecting to the relay,
 *       and not directly to each other!
 *    Peripheral                  Relay                    Central
 *    | Heart  |        | Heart     |   Heart  |        |           |
 *    | Rate   | -----> | Rate     -|-> Rate   | -----> | Collector |
 *    | Sensor |        | Collector |   Sensor |        |           |
 *    +--------+        +-----------|   and    |        +-----------+
 *                      | Running   |   Running|
 *    +--------+        | Speed    -|-> Speed  |
 *    | Running|------> | Collector |   Sensor |
 *    | Speed  |        +-----------|----------+
 *    | Sensor |
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_nus.h"
#include "ble_nus_c.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "app_error.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_srv_common.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
//#include "ble_hrs.h"
//#include "ble_rscs.h"
//#include "ble_hrs_c.h"
//#include "ble_rscs_c.h"
#include "ble_conn_state.h"
#include "nrf_fstorage.h"
#include "fds.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf.h"
#include "app_uart.h"
#include "nrf_uart.h" //or #include "nrf_uarte.h" to use EasyDMA
#if defined (UART_PRESENT)
#if defined (UARTE_PRESENT)
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define PERIPHERAL_ADVERTISING_LED      BSP_BOARD_LED_2
#define PERIPHERAL_CONNECTED_LED        BSP_BOARD_LED_3
#define CENTRAL_SCANNING_LED            BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED           BSP_BOARD_LED_1
#define DEVICE_NAME                     "nRF Relay"                                 /**< Name of device used for advertising. */
#define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Passed to Device Information Service. */
#define APP_ADV_INTERVAL                300                                         /**< The advertising interval (in units of 0.625 ms). This value corresponds to 187.5 ms. */
#define UART_TX_BUF_SIZE 256
#define UART_RX_BUF_SIZE 256
#define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define APP_BLE_CONN_CFG_TAG            1                                           /**< Tag that identifies the SoftDevice BLE configuration. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to the first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
#define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
#define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size in octets. */
#define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size in octets. */
//#define HART_RATE_SERVICE_UUID_IDX      0                                           /**< Hart Rate service UUID index in array. */
//#define RSCS_SERVICE_UUID_IDX           1                                           /**< RSCS service UUID index in array. */
/**@brief   Priority of the application BLE event handler.
 * @note    You shouldn't need to modify this value.
#define APP_BLE_OBSERVER_PRIO           3
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
//static ble_hrs_t m_hrs;                                             /**< Heart Rate Service instance. */
//static ble_rscs_t m_rscs;                                           /**< Running Speed and Cadence Service instance. */
//static ble_hrs_c_t m_hrs_c;                                         /**< Heart Rate Service client instance. */
//static ble_rscs_c_t m_rscs_c;                                       /**< Running Speed and Cadence Service client instance. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);
BLE_NUS_C_DEF(m_ble_nus_c);
NRF_BLE_GATT_DEF(m_gatt);                                           /**< GATT module instance. */
NRF_BLE_QWRS_DEF(m_qwr, NRF_SDH_BLE_TOTAL_LINK_COUNT);              /**< Context for the Queued Write module.*/
//BLE_ADVERTISING_DEF(m_advertising);                                 /**< Advertising module instance. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_discovery, 2);                      /**< Database discovery module instances. */
NRF_BLE_SCAN_DEF(m_scan);
                                    /**< Scanning module instance. */
static uint16_t          m_conn_handle = BLE_CONN_HANDLE_INVALID;                   /**< Handle of the current connection. */
//static uint16_t m_conn_handle_hrs_c  = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the HRS central application */
//static uint16_t m_conn_handle_rscs_c = BLE_CONN_HANDLE_INVALID;     /**< Connection handle for the RSC central application */
/**@brief Names that the central application scans for, and that are advertised by the peripherals.
 *  If these are set to empty strings, the UUIDs defined below are used.
static char const m_target_periph_name[] = "Nordic_Blinky";
//#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN
/**@brief UUIDs that the central application scans for if the name above is set to an empty string,
 * and that are to be advertised by the peripherals.
//static ble_uuid_t m_adv_uuids[] =
   // {BLE_UUID_HEART_RATE_SERVICE,        BLE_UUID_TYPE_BLE},
    //{BLE_UUID_RUNNING_SPEED_AND_CADENCE, BLE_UUID_TYPE_BLE}
static ble_uuid_t m_sr_uuids[] =
   {BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = NRF_BLE_SCAN_SCAN_DURATION,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
    .extended      = true,
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is an example only and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling errors from the Connection Parameters module.
    APP_ERROR_HANDLER(nrf_error);
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    ble_gap_evt_adv_report_t const * p_adv =
                   p_scan_evt->params.filter_match.p_adv_report;
    ble_gap_scan_params_t    const * p_scan_param =
                   p_scan_evt->p_scan_params;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            // Initiate connection.
            err_code = sd_ble_gap_connect(&p_adv->peer_addr,
                                          p_scan_param,
                                          &m_scan.conn_params,
                                          APP_BLE_CONN_CFG_TAG);
        } break;
/**@brief Function for initialization the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param = &m_scan_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    if (strlen(m_target_periph_name) != 0)
        err_code = nrf_ble_scan_filter_set(&m_scan,
                                           SCAN_NAME_FILTER,
                                           m_target_periph_name);
                                       SCAN_UUID_FILTER,
                                       //&m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]
                                        &m_sr_uuids);
  /**  err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &m_adv_uuids[RSCS_SERVICE_UUID_IDX]);
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
/**@brief Function for initializing the scanning.
static void scan_start(void)
    err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing the advertising and the scanning.
static void adv_scan_start(void)
    //check if there are no flash operations in progress
    if (!nrf_fstorage_is_busy(NULL))
        // Start scanning for peripherals and initiate connection to devices which
        // advertise Heart Rate or Running speed and cadence UUIDs.
        scan_start();
        // Turn on the LED to signal scanning.
        bsp_board_led_on(CENTRAL_SCANNING_LED);
        // Start advertising.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            adv_scan_start();
/**@brief Function for changing filter settings after establishing the connection.
static void filter_settings_change(void)
    err_code = nrf_ble_scan_all_filter_remove(&m_scan);
                                           SCAN_NAME_FILTER,
/**if ((m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
                                          &m_sr_uuids );
   /** if ((m_conn_handle_hrs_c != BLE_CONN_HANDLE_INVALID) &&
        (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID))
                                           SCAN_UUID_FILTER,
    /**if ((m_conn_handle_rscs_c != BLE_CONN_HANDLE_INVALID) &&
                                           SCAN_UUID_FILTER,
                                           &m_adv_uuids[HART_RATE_SERVICE_UUID_IDX]);
    //APP_ERROR_CHECK(err_code);
/**@brief Handles events coming from the Heart Rate central module.
/**static void hrs_c_evt_handler(ble_hrs_c_t * p_hrs_c, ble_hrs_c_evt_t * p_hrs_c_evt)
    switch (p_hrs_c_evt->evt_type)
        case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_hrs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_hrs_c = p_hrs_c_evt->conn_handle;
                NRF_LOG_INFO("HRS discovered on conn_handle 0x%x", m_conn_handle_hrs_c);
                filter_settings_change();
                err_code = ble_hrs_c_handles_assign(p_hrs_c,
                                                    m_conn_handle_hrs_c,
                                                    &p_hrs_c_evt->params.peer_db);
                // Initiate bonding.
                err_code = pm_conn_secure(m_conn_handle_hrs_c, false);
                if (err_code != NRF_ERROR_BUSY)
                // Heart rate service discovered. Enable notification of Heart Rate Measurement.
                err_code = ble_hrs_c_hrm_notif_enable(p_hrs_c);
        } break; // BLE_HRS_C_EVT_DISCOVERY_COMPLETE
        case BLE_HRS_C_EVT_HRM_NOTIFICATION:
            NRF_LOG_INFO("Heart Rate = %d", p_hrs_c_evt->params.hrm.hr_value);
            err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, p_hrs_c_evt->params.hrm.hr_value);
            if ((err_code != NRF_SUCCESS) &&
                (err_code != NRF_ERROR_INVALID_STATE) &&
                (err_code != NRF_ERROR_BUSY) &&
                (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
                APP_ERROR_HANDLER(err_code);
        } break; // BLE_HRS_C_EVT_HRM_NOTIFICATION
            // No implementation needed.
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("Discovery complete.");
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
     //   case BLE_NUS_C_EVT_NUS_TX_EVT:
           // ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            //break;
        case BLE_NUS_C_EVT_DISCONNECTED:
            NRF_LOG_INFO("Disconnected.");
            scan_start();
/**@brief Handles events coming from  Running Speed and Cadence central module.
/**static void rscs_c_evt_handler(ble_rscs_c_t * p_rscs_c, ble_rscs_c_evt_t * p_rscs_c_evt)
    switch (p_rscs_c_evt->evt_type)
        case BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
            if (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                m_conn_handle_rscs_c = p_rscs_c_evt->conn_handle;
                NRF_LOG_INFO("Running Speed and Cadence service discovered on conn_handle 0x%x",
                             m_conn_handle_rscs_c);
                err_code = ble_rscs_c_handles_assign(p_rscs_c,
                                                    m_conn_handle_rscs_c,
                                                    &p_rscs_c_evt->params.rscs_db);
                err_code = pm_conn_secure(m_conn_handle_rscs_c, false);
                // Running Speed Cadence Service discovered. Enable notifications.
                err_code = ble_rscs_c_rsc_notif_enable(p_rscs_c);
        } break; // BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
        case BLE_RSCS_C_EVT_RSC_NOTIFICATION:
            ble_rscs_meas_t rscs_measurment;
            NRF_LOG_INFO("Speed      = %d", p_rscs_c_evt->params.rsc.inst_speed);
            rscs_measurment.is_running                  = p_rscs_c_evt->params.rsc.is_running;
            rscs_measurment.is_inst_stride_len_present  = p_rscs_c_evt->params.rsc.is_inst_stride_len_present;
            rscs_measurment.is_total_distance_present   = p_rscs_c_evt->params.rsc.is_total_distance_present;
            rscs_measurment.inst_stride_length = p_rscs_c_evt->params.rsc.inst_stride_length;
            rscs_measurment.inst_cadence       = p_rscs_c_evt->params.rsc.inst_cadence;
            rscs_measurment.inst_speed         = p_rscs_c_evt->params.rsc.inst_speed;
            rscs_measurment.total_distance     = p_rscs_c_evt->params.rsc.total_distance;
            err_code = ble_rscs_measurement_send(&m_rscs, &rscs_measurment);
        } break; // BLE_RSCS_C_EVT_RSC_NOTIFICATION
/**@brief Function for assigning new connection handle to available instance of QWR module.
 * @param[in] conn_handle New connection handle.
static void multi_qwr_conn_handle_assign(uint16_t conn_handle)
    for (uint32_t i = 0; i < NRF_SDH_BLE_TOTAL_LINK_COUNT; i++)
        if (m_qwr[i].conn_handle == BLE_CONN_HANDLE_INVALID)
            ret_code_t err_code = nrf_ble_qwr_conn_handle_assign(&m_qwr[i], conn_handle);
/**@brief   Function for handling BLE events from the central application.
 * @details This function parses scanning reports and initiates a connection to peripherals when a
 *          target UUID is found. It updates the status of LEDs used to report the central application
 *          activity.
static void on_ble_central_evt(ble_evt_t const * p_ble_evt)
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
            // start discovery of services. The NUS Client waits for a discovery result
            err_code = ble_db_discovery_start(&m_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->conn_handle,
                         p_gap_evt->params.disconnected.reason);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_INFO("Connection Request timed out.");
            // Pairing not supported.
            err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
   /** switch (p_ble_evt->header.evt_id)
        // Upon connection, check which peripheral is connected (HR or RSC), initiate DB
        // discovery, update LEDs status, and resume scanning, if necessary.
            NRF_LOG_INFO("Central connected");
            // If no Heart Rate sensor or RSC sensor is currently connected, try to find them on this peripheral.
           // if (   (m_conn_handle_hrs_c  == BLE_CONN_HANDLE_INVALID)
             //   || (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID))
                NRF_LOG_INFO("Attempt to find HRS or RSC on conn_handle 0x%x", p_gap_evt->conn_handle);
                err_code = ble_db_discovery_start(&m_db_discovery[0], p_gap_evt->conn_handle);
                if (err_code == NRF_ERROR_BUSY)
                    err_code = ble_db_discovery_start(&m_db_discovery[1], p_gap_evt->conn_handle);
            // Assign connection handle to the QWR module.
            multi_qwr_conn_handle_assign(p_gap_evt->conn_handle);
            // Update LEDs status, and check whether to look for more peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer that disconnected,
        // update the LEDs status and start scanning again.
            if (p_gap_evt->conn_handle == m_conn_handle_hrs_c)
                NRF_LOG_INFO("HRS central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
            if (p_gap_evt->conn_handle == m_conn_handle_rscs_c)
                NRF_LOG_INFO("RSC central disconnected (reason: %d)",
                                                   SCAN_UUID_FILTER,
            if (   (m_conn_handle_rscs_c == BLE_CONN_HANDLE_INVALID)
                // Start scanning.
                scan_start();
                // Update LEDs status.
            if (ble_conn_state_central_conn_count() == 0)
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
        } break; // BLE_GAP_EVT_DISCONNECTED
            // No timeout for scanning is specified, so only connection attemps can timeout.
        } break;
            // Accept parameters requested by peer.
        } break;
        } break;
/**@brief   Function for handling BLE events from peripheral applications.
 * @details Updates the status LEDs used to report the activity of the peripheral applications.
static void on_ble_peripheral_evt(ble_evt_t const * p_ble_evt)
            NRF_LOG_INFO("Peripheral connected");
            bsp_board_led_off(PERIPHERAL_ADVERTISING_LED);
            bsp_board_led_on(PERIPHERAL_CONNECTED_LED);
            multi_qwr_conn_handle_assign(p_ble_evt->evt.gap_evt.conn_handle);
            NRF_LOG_INFO("Peripheral disconnected. conn_handle: 0x%x, reason: 0x%x",
            bsp_board_led_off(PERIPHERAL_CONNECTED_LED);
        } break;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
            NRF_LOG_INFO("Fast advertising.");
            bsp_board_led_on(PERIPHERAL_ADVERTISING_LED);
        } break;
        case BLE_ADV_EVT_IDLE:
            ret_code_t err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
        } break;
/**@brief Function for checking whether a bluetooth stack event is an advertising timeout.
 * @param[in] p_ble_evt Bluetooth stack event.
static bool ble_evt_is_advertising_timeout(ble_evt_t const * p_ble_evt)
    return (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_SET_TERMINATED);
    uint16_t conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
    uint16_t role        = ble_conn_state_role(conn_handle);
    // Based on the role this device plays in the connection, dispatch to the right handler.
    if (role == BLE_GAP_ROLE_PERIPH || ble_evt_is_advertising_timeout(p_ble_evt))
        //ble_hrs_on_ble_evt(p_ble_evt, &m_hrs);
       // ble_rscs_on_ble_evt(p_ble_evt, &m_rscs);
NRF_LOG_INFO("peripheral role.")
    on_ble_peripheral_evt(p_ble_evt);
    else if ((role == BLE_GAP_ROLE_CENTRAL) || (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT))
       // ble_hrs_c_on_ble_evt(p_ble_evt, &m_hrs_c);
        //ble_rscs_c_on_ble_evt(p_ble_evt, &m_rscs_c);
 //NRF_LOG_INFO("cenrtral role loop")
        on_ble_central_evt(p_ble_evt);
/**@brief Heart Rate Collector initialization.
/**static void hrs_c_init(void)
    ble_hrs_c_init_t hrs_c_init_obj;
    hrs_c_init_obj.evt_handler = hrs_c_evt_handler;
    err_code = ble_hrs_c_init(&m_hrs_c, &hrs_c_init_obj);
/**@brief RSC collector initialization.
static void nus_c_init(void)
    ble_nus_c_init_t init;
    init.evt_handler = ble_nus_c_evt_handler;
    err_code = ble_nus_c_init(&m_ble_nus_c, &init);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for initializing the Peer Manager.
static void peer_manager_init(void)
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bond information from persistent storage.
static void delete_bonds(void)
    NRF_LOG_INFO("Erase bonds!");
    err_code = pm_peers_delete();
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  Will be true if the clear bonding button was pressed to
 *                            wake the application up.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, NULL);
/**@brief Function for initializing the GAP.
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device, including the device name, appearance, and the preferred connection parameters.
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    gap_conn_params.min_conn_interval = m_scan.conn_params.min_conn_interval;
    gap_conn_params.max_conn_interval = m_scan.conn_params.max_conn_interval;
    gap_conn_params.slave_latency     = m_scan.conn_params.slave_latency;
    gap_conn_params.conn_sup_timeout  = m_scan.conn_params.conn_sup_timeout;
/**@brief Function for initializing the GATT module.
/**static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
    if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
        m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
        NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                  p_gatt->att_mtu_desired_central,
                  p_gatt->att_mtu_desired_periph);
    err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
    err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    cp_init.start_on_notify_cccd_handle    = BLE_CONN_HANDLE_INVALID; // Start upon connection.
    cp_init.disconnect_on_fail             = true;
    cp_init.evt_handler                    = NULL;  // Ignore events.
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
        uint32_t err_code;
        for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
            do
                err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
            } while (err_code == NRF_ERROR_BUSY);
        if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
 * @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                do
                    if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                         (err_code != NRF_ERROR_NOT_FOUND) )
                index = 0;
        case APP_UART_FIFO_ERROR:
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = NRF_UART_BAUDRATE_115200
#else
        .baud_rate    = NRF_UARTE_BAUDRATE_115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**void uart_event_handle(app_uart_evt_t * p_event)
    uint32_t       err_code;
            index++;
                do
                index = 0;
/**@brief Function for handling Queued Write module errors.
 * @details A pointer to this function is passed to each service that may need to inform the
 * @param[in]   nrf_error   Error code that contains information about what went wrong.
/**static void nus_data_handler(ble_nus_evt_t * p_evt)
        uint32_t err_code;
            do
/**@brief Function for initializing services that are be used by the application.
 * @details Initialize the Heart Rate, Battery and Device Information services.
  //  ble_hrs_init_t     hrs_init;
   // ble_rscs_init_t    rscs_init;
    uint8_t            body_sensor_location;
 ble_nus_init_t     nus_init;
//ble_nus_init_t   nus_init;
// Initialize NUS.
    // Initialize Queued Write module instances.
        err_code = nrf_ble_qwr_init(&m_qwr[i], &qwr_init);
//nus_init.data_handler = nus_data_handler;
    // Initialize the Heart Rate Service.
   /** body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed or increased.
    hrs_init.hrm_cccd_wr_sec = SEC_OPEN;
    hrs_init.bsl_rd_sec      = SEC_OPEN;
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize the Running Speed and Cadence Service.
    memset(&rscs_init, 0, sizeof(rscs_init));
    rscs_init.evt_handler = NULL;
    rscs_init.feature     = BLE_RSCS_FEATURE_INSTANT_STRIDE_LEN_BIT |
                            BLE_RSCS_FEATURE_WALKING_OR_RUNNING_STATUS_BIT;
    // Here the sec level for the Running Speed and Cadence Service can be changed or increased.
    rscs_init.rsc_feature_rd_sec   = SEC_OPEN;
    rscs_init.rsc_meas_cccd_wr_sec = SEC_OPEN;
    err_code = ble_rscs_init(&m_rscs, &rscs_init);
    APP_ERROR_CHECK(err_code);*/
        uint32_t err_code;
            do
/**@brief Function for initializing the advertising functionality.**/
    ble_advertising_init_t init;
    init.advdata.name_type               = BLE_ADVDATA_SHORT_NAME;
    init.advdata.short_name_len = 6; // Advertise only first 6 letters of name
    init.advdata.include_appearance      = false;
    init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.uuid_cnt = sizeof(m_sr_uuids) / sizeof(m_sr_uuids[0]);
init.srdata.uuids_complete.p_uuids = m_sr_uuids;
/**static void advertising_init(void)
    uint32_t      err_code;
    ble_advdata_t advdata;
    ble_advdata_t scanrsp;
    uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    ble_uuid_t adv_uuids[] = {{BLE_UUID_NUS_SERVICE, m_nus.uuid_type}};
    //adv_uuids[0].uuid = BLE_UUID_NUS_SERVICE;
    //adv_uuids[0].type = m_nus.uuid_type;
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.flags                   = flags;
    memset(&scanrsp, 0, sizeof(scanrsp));
    scanrsp.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    scanrsp.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_set(&advdata, &scanrsp);
/**@brief Function for initializing logging.
static void log_init(void)
/**@brief Function for handling the idle state (main loop). If there is no pending log operation,
          then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/**@brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the application main entry.
    bool erase_bonds;
    // Initialize.
    uart_init();
    log_init();
    timer_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    gap_params_init();
    gatt_init();
    conn_params_init();
    db_discovery_init();
    peer_manager_init();
    //hrs_c_init();
    //rscs_c_init();
    services_init();
    advertising_init();
    // Start execution.
    NRF_LOG_INFO("Relay example started.");
 //advertising_start();
    if (erase_bonds == true)
        // Scanning and advertising is done upon PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
        adv_scan_start();
 NRF_LOG_INFO("Scan.");
    // Enter main loop.
    for (;;)
        idle_state_handle();
Parents Reply
  • So when i test peripheral and central uart examples ,they are working but in the relay setting the problem of central and peripheral(the other board) still exists. The error is in the on_ble_central_evt() function in the case
    with error code 0x00000008.
    What can be the reason for the timeout? Should i make some changes in the time intervals?
