cloud_connect failed: -111
Hi, the thread at https://devzone.nordicsemi.com/f/nordic-q-a/48859/nrf9160-dk-connecting-problems-with-nrf-cloud/211627 has been very useful for me to get past several problems getting the asset tracker example to work. I connect successfully to a NB-IoT network here in Norway now, thanks to (as explained in the linked thread) setting modem mode to NB-IoT, using legacy PCO mode and using a static IP address since DNS is not supported.
Finally, the problem I am left with is "cloud_connect failed: -111". I had high hopes that a certificate update (devzone.nordicsemi.com/.../nrf-cloud-certificate-update) would solve this, but after successfully updating my certificates the same problem still persists.
I have a nRF9160 DK v 0.8.5, with modem FW updated. I can successfully connect to the network using the at_client sample. Since the SIM included with the dev. kit only supports LTE-M1 (no coverage where I am located), I am using a SIM card from com4.no to connect to NB-IoT.
Here is my output from the terminal:
***** Booting Zephyr OS build v1.14.99-ncs3-snapshot2-2647-gd6e67554cfeb *****
[00:00:00.378,173]
[0m<dbg> nrf9160_gps.init: MAGPIO set: AT%XMAGPIO=1,0,0,1,1,1574,1577[0m
Asset tracker started
[00:00:00.389,282]
[0m<dbg> nrf_cloud_transport.nct_client_id_get: client_id = nrf-352656100223414[0m
[00:00:00.398,498]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_base_topic: $aws/things/nrf-352656100223414/shadow[0m
[00:00:00.410,156]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: accepted_topic: nrf-352656100223414/shadow/get/accepted[0m
[00:00:00.421,661]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: rejected_topic: $aws/things/nrf-352656100223414/shadow/get/rejected[0m
[00:00:00.434,204]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_delta_topic: $aws/things/nrf-352656100223414/shadow/update/delta[0m
[00:00:00.447,082]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: update_topic: $aws/things/nrf-352656100223414/shadow/update[0m
[00:00:00.458,923]
[0m<dbg> nrf_cloud_transport.nct_topics_populate: shadow_get_topic: $aws/things/nrf-352656100223414/shadow/get[0m
Connecting to LTE network. This may take several minutes.
[00:00:00.477,172]
[0m<inf> lte_lc: Using legacy LTE PCO mode...[0m
[00:00:00.483,428]
[0m<dbg> lte_lc.w_lte_lc_connect: Network mode: AT%XSYSTEMMODE=0,1,1,0[0m
[00:00:04.653,717]
[0m<dbg> lte_lc.at_handler: recv: +CEREG: 2,"0CEB","0202791C",9,0,0,"11100000","11100000"[0m
[00:00:04.664,123]
[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 2[0m
[00:00:05.574,218]
[0m<dbg> lte_lc.at_handler: recv: +CEREG: 1,"0CEB","0202791C",9,,,"11100000","11100000"[0m
[00:00:05.584,472]
[0m<dbg> lte_lc.parse_nw_reg_status: Network registration status: 1[0m
Connected to LTE network
[00:00:05.595,123]
[0m<dbg> nrf_cloud_transport.nct_connect: IPv4 Address 52.54.149.10[0m
LTE link disconnect
Shutdown modem
Any other suggestions would be greatly appreciated.
Terje
  • For your information: I have now tried again without using a static IP address, and confirmed that com4/Telia in Norway does not seem to support DNS lookup in NB-IoT. From my debug output:
    [00:00:19.198,181]
    [0m
    [00:00:43.211,425]
    [0m<dbg> nrf_cloud_transport.nct_connect: getaddrinfo failed 60
    [0m
    cloud_connect failed: 60
    LTE link disconnect
  • Hi.
    The mqtt_socket library merges all errors on connecting to -111 (connection refused).
    However, the reason for your failure to connect might be other things than just some issue with the certificates.
    Can you add a print inside the "if block" ncs/nrf/subsys/net/lib/mqtt_socket/mqtt.c:322 that prints the value of err_code?
    AWS (which nRF Cloud) is built upon uses load balancing, so the IP address of the endpoint you are looking for might change without warning.
    Didrik
  • Hi, thank you for the feedback.
    Added a print of the error code (and renewed the IP address to connect to).
    In mqtt_connect(): client_connect() returned error code -116
    This seems to indicate a connection timeout, which might make sense if connecting via a higher latency NB-IoT network (and not LTE-M1).
    I'm now trying to figure out how to increase timeout values, but there is a lot of code to read... Do you know how to increase timeout values across the board (socket timeout, AWS timeout and possibly other timeouts)?
  • I suspect that you are not getting a connection to the AWS server. Due to load balancing, the IP address you use might not be the correct one anymore.
    When it comes to finding configuration options, menuconfig or the corresponding tool in SES (Project -> Configure nRF Connect SDK Project) can be quite handy.
    However, I do not believe there is a single option to extend all kinds of timeouts.
  • Further debugging shows that the call in nrf91_sockets.c inside nrf91_socket_offload_connect() hangs for quite a few seconds and then returns the timeout error when calling nrf_connect().
    I'm not able to debug this further as it then goes into debugging assembly code...
    Do you know how to increase timeout values for the modem establishing the TLS connection?
