Data throughput mesh
Hi guys I m trying to send a simple message every time a gpio interrupt occurs on the client in order to receive that on the server. I m using the ble mesh protocol and I used in particular the light switch example. I modified the client code in order to send a message on the gpio interrupt and it works fine with a good data throughput.. I will expect to receive the data on the server but here there is the problem. If the data frequency is bigger than about 6/7 Hz the server does not receive all the data. There is a way to overcome this limit? Which is for ble mesh the limit? Is there in the server software some elements I can change in order to overcome the receiving frequency?
  • Hi.
    Well, you can either try to buffer up some data if you want to keep that sample rate, or you have to lower the sample rate.
    Anyway, I still think that aiming for 15ms latency is quite difficult.
    Andreas
  • what does it mean buffer up? the scope is to understand which is the fastes frequency the server can receive. there is a limit on the server?
  • Hi.
    Sorry if that was confusing.
    What I mean is you said:
    marikalp said:
    all the changed states,
     So I understand you sample multiple GPIO's?
    You can have 11byte per packet you send, so if you make sure that you send 11 bytes each time you send a message.
    Andreas
  • hi..can I ask you if the problem could be I m using the nrf52840 board ,but for ble mesh I don't use the softdevice like for ble (s140) and ant (s340)..have i to flash it before to run my code?
    Thanks a lot.
  • trying to flash before the s140 softdevice i had this error:
    <t:      13105>, app_error_weak.c,  108, Mesh assert at 0x0002D682 (:0)
    what do i schould  do?
1 2 3 4
