GPIOTE can toggle led but cannot set boolean
board: nRF52 DK
[update - fixed this - see #2]
When I use the following (shortened) code, the LED blinks when I press button 2 but I see no logs. NRF_LOG_INFO() is working in other areas of the code.
#define BMA_TAP_INTERRUPT_PIN BUTTON_2
bool foo = false;
void bma_tap_interrupt_handler(nrf_drv_gpiote_pin_t pin, nrf_gpiote_polarity_t action)
    nrf_drv_gpiote_out_toggle(LED1);
    foo = true;
void bma_enable_tap_interrupt(uint32_t pin, nrf_drv_gpiote_evt_handler_t evt_handler)
    ret_code_t ret_code;
    if (!nrf_drv_gpiote_is_init())
        ret_code = nrf_drv_gpiote_init();
        APP_ERROR_CHECK(ret_code);
    nrf_drv_gpiote_in_config_t gpiote_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
    gpiote_config.pull = NRF_GPIO_PIN_PULLUP;
    ret_code = nrf_drv_gpiote_in_init(pin, &gpiote_config, evt_handler);
    nrf_drv_gpiote_in_event_enable(pin, true);
    NRF_LOG_INFO("initialised pin %d for tap intr", pin);
    /** for debug **/
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    ret_code = nrf_drv_gpiote_out_init(LED1, &out_config);
    /** for debug **/
    bma_enable_tap_interrupt(BMA_TAP_INTERRUPT_PIN, bma_tap_interrupt_handler);
    for (;;)
        if (foo)
            NRF_LOG_INFO("bar");
            foo = false;
        idle_state_handle();
It doesn't make sense to me that nrf_drv_gpiote_out_toggle(LED1) gets called but foo does not get set to true.
[#2]
For an extra challenge, when I add the following function call to main (setup pins: sck=2, dout=26), LED1 turns on but pressing button 2 does not actuate the led anymore.
void hx711_init(enum hx711_mode mode, struct hx711_setup *setup, hx711_evt_handler_t callback)
    hx711_callback = callback;
    m_setup = setup;
    m_mode = mode;
    if (m_setup != NULL)
        nrf_gpio_cfg_output(m_setup->pd_sck);
        nrf_gpio_pin_set(m_setup->pd_sck);
        nrf_drv_gpiote_in_config_t gpiote_config = GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
        nrf_gpio_cfg_input(m_setup->dout, NRF_GPIO_PIN_NOPULL);
        ret_code = nrf_drv_gpiote_in_init(m_setup->dout, &gpiote_config, gpiote_evt_handler);
        /* Set up timers, gpiote, and ppi for clock signal generation*/
        NRF_TIMER1->CC[0]     = 1;
        NRF_TIMER1->CC[1]     = HX711_DEFAULT_TIMER_COMPARE;
        NRF_TIMER1->CC[2]     = HX711_DEFAULT_TIMER_COUNTERTOP;
        NRF_TIMER1->SHORTS    = (uint32_t) (1 << 2);    //COMPARE2_CLEAR
        NRF_TIMER1->PRESCALER = 0;
        NRF_TIMER2->CC[0]     = m_mode;
        NRF_TIMER2->MODE      = 2;
        NRF_GPIOTE->CONFIG[1] = (uint32_t) (3 | (m_setup->pd_sck << 8) | (1 << 16) | (1 << 20));
        NRF_PPI->CH[0].EEP   = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
        NRF_PPI->CH[0].TEP   = (uint32_t) &NRF_GPIOTE->TASKS_SET[1];
        NRF_PPI->CH[1].EEP   = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[1];
        NRF_PPI->CH[1].TEP   = (uint32_t) &NRF_GPIOTE->TASKS_CLR[1];
        NRF_PPI->FORK[1].TEP = (uint32_t) &NRF_TIMER2->TASKS_COUNT; // Increment on falling edge
        NRF_PPI->CH[2].EEP   = (uint32_t) &NRF_TIMER2->EVENTS_COMPARE[0];
        NRF_PPI->CH[2].TEP   = (uint32_t) &NRF_TIMER1->TASKS_SHUTDOWN;
        NRF_PPI->CHEN = NRF_PPI->CHEN | 7;
        NRF_LOG_WARNING("hx711 setup has not been assigned yet");
For this problem, I suspect it has something to do with GPIOTE channels, but I can't watch the registers because my vscode cortex debugger is not working right now. I'm not overlapping  any pins I believe.
    Try setting the bool like this:
    static bool foo = false;
    volatile bool foo = false;
    volatile static bool foo = false;
    More info
    on this.
    Can also be the the interrupt is firing to fast.
    //place in ISR
    nrf_drv_gpiote_in_event_enable(pin, false);
    //place in main
    For #2 check that the DK is not using these pins for something else.
     The channel is setup as a toggle, meaning that you get the handler called when it goes active and inactive, is that the intended behavior?
    You are clearing and shutting down the timer when CC[2] hits. Do you start the timer again manually?
    Is the input signal in the MHz range? If so, you should look at implementing the workaround for this errata: https://infocenter.nordicsemi.com/topic/errata_nRF52832_Rev2/ERR/nRF52832/Rev2/latest/anomaly_832_155.html?cp=3_1_1_0_1_41
    Håkon
  • bool foo = false worked fine. The problem was something dumb.
    Since the problem only occurs when hx711_init() is called, I just made sure the hx711 pins don't overlap. I do not think this is the source of the problem
  •  The channel is setup as a toggle, meaning that you get the handler called when it goes active and inactive, is that the intended behavior?
    Just for debug. I will change it to LOTOHI/HITOLO when I've fixed the bug below.
    Yes I start the timer again in hx711_sample() using NRF_TIMER1->TASKS_START = 1. To give you a sense of the code flow, I have an APP_TIMER setup to call hx711_start() every 2s. Then when dout goes low, gpiote clocks out the adc value using the sck pin
    void hx711_start()
        NRF_LOG_DEBUG("start sampling");
        NRF_GPIOTE->TASKS_CLR[1] = 1;
        // Generates interrupt when new sampling is available.
        nrf_drv_gpiote_in_event_enable(m_setup->dout, true);
    void hx711_stop()
        NRF_LOG_DEBUG("stop sampling");
        nrf_drv_gpiote_in_event_disable(m_setup->dout);
    /* Clocks out HX711 result - if readout fails consistently, try to increase the clock period and/or enable compiler optimization */
    void hx711_sample()
        NRF_TIMER2->TASKS_CLEAR = 1;
        m_sample.count = 0;
        m_sample.value = 0;
        m_sample.status = Busy;
        NRF_TIMER1->TASKS_START = 1; // Starts clock signal on PD_SCK
        NRF_LOG_INFO("sampling hx711");
        for (uint32_t i=0; i < HX711_DEFAULT_ADC_RES; i++)
            do
                /* NRF_TIMER->CC[1] contains number of clock cycles.*/
                NRF_TIMER2->TASKS_CAPTURE[1] = 1;
                if (NRF_TIMER2->CC[1] >= HX711_DEFAULT_ADC_RES)
                    NRF_LOG_WARNING("readout not in sync");
                    goto EXIT; // Readout not in sync with PD_CLK. Abort and notify error.
            while(NRF_TIMER1->EVENTS_COMPARE[0] == 0);
            NRF_TIMER1->EVENTS_COMPARE[0] = 0;
            m_sample.value |= (nrf_gpio_pin_read(m_setup->dout) << (23 - i));
            m_sample.count++;
            m_sample.status = Unread;
        EXIT:
        m_sample.value = hx711_convert(m_sample.value);
        if (m_sample.value > 0x7FFFFF)
            NRF_LOG_WARNING("sample returned a negative value. Check connections");
            return;
        NRF_LOG_DEBUG("number of bits: %d. ADC val: 0x%x or 0d%d",
        m_sample.count,
        m_sample.value,
        m_sample.value);
        if (hx711_callback != NULL)
            hx711_callback(&m_sample.value);
    My TIMER1 prescaler is set to 0, so my timer is running in the MHz. The input signal from the hx711 to the dout pin is at most 80 Hz.
    I checked to see which pins each GPIOTE was assigned to. GPIOTE[0] is pin 26 (dout) and GPIOTE[1] is pin 14 (button 2 in pca10040.h). So the channels appear to be separated. Still not sure what the source of my problem is.
    Is the issue that you read out incorrectly using this function, or is the initial issue with button 2 (GPIO P0.14) still present?
    Did you try to implement the errata workaround? If you are sampling several channels asynchronously, you can still get into this scenario, even if the sampled signals are of lower frequency, as they can overlap with a very low time difference.
    Håkon
