I am looking for (andriod) mobile phone that support Bluetooth LE coded (long range)
Have you ever tested bluetooth (LE coded) with mobile phone ?
Please recommend, What should I use the part no. of mobile phone ?
Thank you
Best Regards,
Thank you
Best Regards,
Depending on whether you're using the phone as the scanner or peripheral, there are different ways to do so. If the phone is your scanner, you'll have to set coded_PHY in the advertising settings (on the nRF side). There are no filters for this in the scanner in the nRFConnect app, so you'll just have to filter it otherwise.
If you're using your phone as an advertiser you can set the phone to only advertise in coded_PHY within the app.
Simon
