As simple as the title! I have tried to move my code from sdk v 3.1 to v3.2 but it will not join the network.
Back to basics and using off-the-box ligh switch example. Also, this example will not join the network (testing with a smartthings hub).
I have also detected a issue when setting the device as sleepy end device. I have changed the following on the example:
- On line 551:
zb_zdo_signal_can_sleep_params_t *can_sleep_params = ZB_ZDO_SIGNAL_GET_PARAMS(p_sg_p, zb_zdo_signal_can_sleep_params_t);
NRF_LOG_INFO("Can sleep for %ld ms", can_sleep_params->sleep_tmo);
zb_sleep_now();
- On line 601:
//sleepy_device_setup();
zb_set_rx_on_when_idle(ZB_TRUE);
Not sure if this related to the main issue, but the device will report a sleep time of 998ms but it will not sleep for that time. I will just keep reporting the sleep time but not going to sleep.
