LTE Line Monitor UART is Red and Yellow blinking
nRF Connect v3.2.0 - LTE Link Monitor is running on Ubuntu 16.04, and nrf9160 fw is v1.0.1. When connecting the board to my laptop, all Modem, UICC, LTE, PDN are Green. But, UART is in Red and Yellow blinking. Also, I failed to upgrade modem firmware via nRF Connect v3.2.0 - Programmer. On Windows, it works fine.
    We are investigating some compatibility issues with the modem flashing in Ubuntu 16. Ubuntu 18 should work fine. The red/yellow UART blinking is just the UART CTS/DSR signaling in linux CDC ACM.
  • HI,
    I have similar problem on Ubuntu 20.04. UART is yellow and red blinking, PDN is grey, other connections are red.
    I use
    images_dfu_hex/nrf9160dk_at_client_dfu_2020-04-29_bc7ade8b.hex
    mfwnrf9160120.zip
    From the log:
    App pc-nrfconnect-linkmonitor v1.1.1 official
    nRFConnect 3.4.0 is supported by the app (^3.2.0)
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS1
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS10
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS11
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS12
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS13
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS14
    2020-06-15T14:36:19.041Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS15
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS16
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS17
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS18
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS19
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS2
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS20
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS21
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS22
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS23
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS24
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS25
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS26
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS27
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS28
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS29
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS3
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS30
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS31
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS4
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS5
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS6
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS7
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS8
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS9
    2020-06-15T14:36:19.042Z VERBOSE Could not fetch serial number for serial port at /dev/ttyS0
    2020-06-15T14:36:26.322Z INFO Modem port is opened
    2020-06-15T14:36:26.325Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-06-15T14:36:48.116Z INFO Modem port is opened
    2020-06-15T14:36:48.124Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-06-15T14:38:19.534Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2020-06-15T14:38:20.535Z ERROR Error: 'AT+CFUN?
    ' timed out
    What can be the problem?
    Árpád
  • Wrong application hex, it should be
    images_full/nrf9160dk_at_client_2020-04-29_bc7ade8b.hex
  • Hi Sigurd,
    the problem is solved, the wrong hex caused the problem.
    Árpád
