Hello everyone,
Im developing a simple BLE scanner and its purpose is to receive and send beacons data by serial port.
My application worked quite well when flashing to the nRF52840-DK. But i cant figure out how to port it to nRF52840-Dongle.
I read the guide: https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial but it still doesnt work.
My first doubt was:
I must change the preprocessor definition from BOARD_PCA10056 to BOARD_PCA10059. But i se that we have different options panel for the Solution, the Project and even the Module. What exactly should be changed? I changed'em all... But sometimes
2. When i set BOARD_PCA10059 in the preprocessor definitions, i have to set the other parameters or they continue as default? The ones that appear as "inherit".
3. In the linker placement macros, can i have offset beetween the Softdevice and the application? Because when i set the start of application right after the end of the softdevice, the app layer appears black in the nRF Connect Programmer. With some offset it appears green. Attached picture of nRF Connect.
Despite these issues, i can flash it to the pca10059, but it just dont work. It works perfectly in the pca10056. Can you please provide me some tips to make it work?
My code:
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_util.h"
#include "app_error.h"
#include "ble_dis_c.h"
#include "ble_rscs_c.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
////ANDRE
//#include <stdbool.h>
//#include "nrf_delay.h"
//#include "boards.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that identifies the BLE configuration of the SoftDevice. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define APP_SOC_OBSERVER_PRIO 1 /**< SoC observer priority of the application. There is no need to modify this value. */
#define SCAN_INTERVAL 0x0320 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0320 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
static ble_gap_scan_params_t m_scan_param = /**< Scan parameters requested for scanning and connection. */
.active = 0x00,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
.timeout = SCAN_DURATION,
// .scan_phys = BLE_GAP_PHY_CODED, // Choose only one of the following scan_phys
.scan_phys = BLE_GAP_PHY_1MBPS,
// .scan_phys = BLE_GAP_PHY_2MBPS,
.extended = 1,
static void scan_start(void);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// uint8_t idx = 0;
// unsigned char mac[6];
int8_t rssi;
case BLE_GAP_EVT_ADV_REPORT:
// for ( idx=0; idx < 6; idx++ ) {
// mac[idx] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[idx];
//NRF_LOG_RAW_INFO ("----------------------------------\r\n");
NRF_LOG_RAW_INFO("Device: %02x:%02x:%02x:%02x:%02x:%02x ", p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[0],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[1],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[2],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[3],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[4],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[5]);
rssi = p_ble_evt->evt.gap_evt.params.adv_report.rssi;
NRF_LOG_RAW_INFO("RSSI:%d \r\n", rssi);
// NRF_LOG_RAW_HEXDUMP_INFO (m_scan.scan_buffer.p_data, m_scan.scan_buffer.len);
* @brief SoftDevice SoC event handler.
* @param[in] evt_id SoC event.
* @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
switch (evt_id)
case NRF_EVT_FLASH_OPERATION_SUCCESS:
/* fall through */
case NRF_EVT_FLASH_OPERATION_ERROR:
if (m_memory_access_in_progress)
m_memory_access_in_progress = false;
scan_start();
// No implementation needed.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
// Register handlers for BLE and SoC events.
NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
init_scan.p_scan_param = &m_scan_param;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
/**@brief Function for starting scanning.
// If there is any pending write to flash, defer scanning until it completes.
if (nrf_fstorage_is_busy(NULL))
m_memory_access_in_progress = true;
return;
err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing the timer. */
static void timer_init(void)
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
// Initialize.
log_init();
timer_init();
power_management_init();
ble_stack_init();
scan_init();
// Start execution.
NRF_LOG_RAW_INFO( " ----------------\r\n");
NRF_LOG_RAW_INFO( "| Scanning for BLE devices... |");
NRF_LOG_RAW_INFO("\r\n ----------------\r\n");
scan_start();
// Enter main loop.
for (;;)
idle_state_handle();
Preprocessor settings:
Linker Settings:
nRF Connect with the files to be written:
This was not modified form pca10056
And yet it is not happy.
