Sorry for simple question. (Yup, I'm Canadian and we say sorry a lot!) I have SES 4.18 and nRF5 SDK 15.3.0 installed on my Mac (10.13.6) and cannot get logging (NRF_LOG_INFO()) to work. Flashing to nRF52 development kit board. Opened the ble_peripheral example ble_app_uart (for pca10040), built and flashed to dev kit and no debug messages. I've read many posts about this and everything appears configured properly.
Here are sections of main.c:
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_soc.h"
#include "nrf_sdh_ble.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "app_timer.h"
#include "ble_nus.h"
#include "app_uart.h"
#include "bsp_btn_ble.h"
#include "nrf_pwr_mgmt.h"
#if defined (UART_PRESENT)
#include "nrf_uart.h"
#if defined (UARTE_PRESENT)
#include "nrf_uarte.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define DEVICE_NAME "Nordic_UART" /**< Name of device. Will be included in the advertising data. */
#define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_ADV_INTERVAL 64 /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
#define APP_ADV_DURATION 18000 /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
#define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(30000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT 3 /**< Number of attempts before giving up the connection parameter negotiation. */
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define UART_TX_BUF_SIZE 256 /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 256 /**< UART RX buffer size. */
BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT); /**< BLE NUS service instance. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr); /**< Context for the Queued Write module.*/
BLE_ADVERTISING_DEF(m_advertising); /**< Advertising module instance. */
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID; /**< Handle of the current connection. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
static ble_uuid_t m_adv_uuids[] = /**< Universally unique service identifier. */
static void log_init(void)
nrf_pwr_mgmt_run();
/**@brief Application main function.
bool erase_bonds;
// Initialize.
uart_init();
log_init();
timers_init();
power_management_init();
ble_stack_init();
gap_params_init();
gatt_init();
services_init();
advertising_init();
conn_params_init();
// Start execution.
advertising_start();
// Enter main loop.
for (;;)
idle_state_handle();
The following source files are included in the project:
nrf_log_backend_rtt.c
nrf_log_backend_serial.c
nrf_log_default_backends.c
nrf_log_frontend.c
nrf_log_str_formatter.c
The following from sdk_config.h:
//========================================================== // <e> NRF_LOG_BACKEND_RTT_ENABLED - nrf_log_backend_rtt - Log RTT backend //========================================================== #ifndef NRF_LOG_BACKEND_RTT_ENABLED #define NRF_LOG_BACKEND_RTT_ENABLED 1 #endif // <o> NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE - Size of buffer for partially processed strings. // <i> Size of the buffer is a trade-off between RAM usage and processing. // <i> if buffer is smaller then strings will often be fragmented. // <i> It is recommended to use size which will fit typical log and only the // <i> longer one will be fragmented. #ifndef NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE #define NRF_LOG_BACKEND_RTT_TEMP_BUFFER_SIZE 64 #endif // <o> NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS - Period before retrying writing to RTT #ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS #define NRF_LOG_BACKEND_RTT_TX_RETRY_DELAY_MS 1 #endif // <o> NRF_LOG_BACKEND_RTT_TX_RETRY_CNT - Writing to RTT retries. // <i> If RTT fails to accept any new data after retries // <i> module assumes that host is not active and on next // <i> request it will perform only one write attempt. // <i> On successful writing, module assumes that host is active // <i> and scheme with retry is applied again. #ifndef NRF_LOG_BACKEND_RTT_TX_RETRY_CNT #define NRF_LOG_BACKEND_RTT_TX_RETRY_CNT 3 #endif // </e> // <e> NRF_LOG_ENABLED - nrf_log - Logger //========================================================== #ifndef NRF_LOG_ENABLED #define NRF_LOG_ENABLED 1 #endif // <i> Log data is buffered and can be processed in idle. #ifndef NRF_LOG_DEFERRED #define NRF_LOG_DEFERRED 1 #endif
main() calls both "printf()" and "NRF_LOG_INFO()" prior to starting advertising, but nothing appears in the Debug Terminal.
Thanks for any assistance. Much appreciated.
Tim
