I'm trying to figure out if my device is suffering from errata 172.
* How can I know if I'm using Ble_LR125Kbit or Ble_LR500Kbit?
* I'm trying to use the function bool enable_errata_172 (void). Do you have any example for that?
Thanks!
Thanks!
There seems to be a typo in the document, the correct function to call is enable_anomaly_172().
best regards
Jared
Thanks!
But it's still not clear from the document - which files should I include in order to use this function? Do you have any example?
You can look at ble_dtm.c which is used in the dtm example in the SDK. There it's checked if the workaround for nRF52840 Anomaly 172 should be enabled or not:
if ((*(volatile uint32_t *)0x40001788) == 0)
anomaly_172_wa_enabled = true;
nrfjprog command for reading MODE register:
nrfjprog --memrd 0x40001510
regards
Jared
Thanks, Jared!
One more question - is erreta 172 relevant for BLE 4.2?
The errata is specific to your IC version. Most of the nRF52840 revisions are affected by errata 172. A good practice is therefore to implement the workaround.
best regards
Jared
OK, but does it affect Nrf_1Mbit mode, or any other modes which are not Ble_LR125Kbit or Ble_LR500Kbit?
Thanks!
Only BLE long range with either 125 kbit or 500 kbit is affected.
Jared
Jared
