Clone nRF Connect SDK
I am currently just trying to clone the nRF connect sdk according to the getting started assistent.
All the first steps just worked fine, but I ran into a problem now and don´t know how to fix this.
The problem appears at the last step, where the requirements of the zephyr repository should be installed.
When I run the commands, which are given in the getting started assistent, I receive erors. The error seams to disappear by trying to install pillow:
command: pip3 install -r zephyr\scripts\requirements.txt
error:
Building wheels for collected packages: Pillow
Building wheel for Pillow (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"'; __file__='"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d 'C:\Users\leder\AppData\Local\Temp\pip-wheel-f2ppq5ks' --python-tag cp38
cwd: C:\Users\leder\AppData\Local\Temp\pip-install-39dzhpkl\Pillow\
Complete output (174 lines):
C:\Users\leder\AppData\Local\Temp\pip-install-39dzhpkl\Pillow\setup.py:28: RuntimeWarning: Pillow does not yet support Python 3.8 and does not yet provide prebuilt Windows binaries. We do not recommend building from source on Windows.
warnings.warn(
running bdist_wheel
running build
running build_py
creating build
creating build\lib.win-amd64-3.8
creating build\lib.win-amd64-3.8\PIL
copying src\PIL\BdfFontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BlpImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BmpImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BufrStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ContainerIO.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\CurImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\DcxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\DdsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\EpsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ExifTags.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\features.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FitsStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FliImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FpxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FtexImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GbrImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GdImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GifImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GimpGradientFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GimpPaletteFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GribStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Hdf5StubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IcnsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IcoImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Image.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageChops.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageCms.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageColor.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageDraw.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageDraw2.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageEnhance.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFilter.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFont.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageGrab.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMath.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMode.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMorph.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageOps.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImagePalette.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImagePath.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageQt.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageSequence.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageShow.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageStat.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageTk.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageTransform.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageWin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImtImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IptcImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Jpeg2KImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\JpegImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\JpegPresets.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\McIdasImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MicImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MpegImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MpoImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MspImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PaletteFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PalmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcdImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcfFontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PdfImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PdfParser.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PixarImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PngImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PpmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PsdImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PSDraw.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PyAccess.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SgiImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SpiderImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SunImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TarIO.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TgaImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TiffImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TiffTags.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WalImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WebPImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WmfImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XbmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XpmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XVThumbImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_binary.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_tkinter_finder.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_util.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_version.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\__init__.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\__main__.py -> build\lib.win-amd64-3.8\PIL
running egg_info
writing src\Pillow.egg-info\PKG-INFO
writing dependency_links to src\Pillow.egg-info\dependency_links.txt
writing top-level names to src\Pillow.egg-info\top_level.txt
reading manifest file 'src\Pillow.egg-info\SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.codecov.yml'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'azure-pipelines.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.azure-pipelines'
no previously-included directories found matching '.travis'
writing manifest file 'src\Pillow.egg-info\SOURCES.txt'
running build_ext
The headers or library files could not be found for zlib,
a required dependency when compiling Pillow from source.
Please see the install instructions at:
pillow.readthedocs.io/.../installation.html
File "C:\Users\leder\AppData\Local\Temp\pip-install-39dzhpkl\Pillow\setup.py", line 852, in <module>
setup(
File "c:\python38\lib\site-packages\setuptools\__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "c:\python38\lib\distutils\core.py", line 148, in setup
dist.run_commands()
File "c:\python38\lib\distutils\dist.py", line 966, in run_commands
self.run_command(cmd)
File "c:\python38\lib\distutils\dist.py", line 985, in run_command
cmd_obj.run()
File "c:\python38\lib\site-packages\wheel\bdist_wheel.py", line 204, in run
self.run_command('build')
File "c:\python38\lib\distutils\cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "c:\python38\lib\distutils\command\build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "c:\python38\lib\distutils\command\build_ext.py", line 340, in run
self.build_extensions()
File "C:\Users\leder\AppData\Local\Temp\pip-install-39dzhpkl\Pillow\setup.py", line 687, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: zlib
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "C:\Users\leder\AppData\Local\Temp\pip-install-39dzhpkl\Pillow\setup.py", line 902, in <module>
raise RequiredDependencyException(msg)
ERROR: Failed building wheel for Pillow
Running setup.py clean for Pillow
Failed to build Pillow
Installing collected packages: Pillow, py, more-itertools, attrs, atomicwrites, pluggy, wcwidth, pytest
Running setup.py install for Pillow ... error
command: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"'; __file__='"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\leder\AppData\Local\Temp\pip-record-x4io0id5\install-record.txt' --single-version-externally-managed --compile
Complete output (176 lines):
warnings.warn(
running install
running build
running build_py
creating build
running egg_info
running build_ext
setup(
dist.run_commands()
cmd_obj.run()
File "c:\python38\lib\site-packages\setuptools\command\install.py", line 61, in run
return orig.install.run(self)
File "c:\python38\lib\distutils\command\install.py", line 545, in run
cmd_obj.run()
cmd_obj.run()
ERROR: Command errored out with exit status 1: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"'; __file__='"'"'C:\\Users\\leder\\AppData\\Local\\Temp\\pip-install-39dzhpkl\\Pillow\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\leder\AppData\Local\Temp\pip-record-x4io0id5\install-record.txt' --single-version-externally-managed --compile Check the logs for full command output.
Many thanks in advance.
  • Hi.
     Could you try to downgrade to Python 3.7? Based on the error it ooks like you can't use Python 3.8.
    Andreas
