The writing of SD card in slave causes disconnection
I can success transplant saadc and fatfs to my ble project.However, when there is a SD card, the slave can write data to SD card successfully, but disconnect with the master. If the SD card is removed, the slave can connect with the master stably.when the slave is writing to SD card.
the connection error in slave:
the connection error in master:
my core code about SD card as following
(1)main:
while(1) {
	if( sampling_done == true) {
		sdWrite(time_sd,data_sd);
(2)sdWrite():
static void sdWrite(uint32_t time[],int16_t data[])
		FRESULT ff_result;
	  uint32_t bytes_written;
		char buffer[3000] = {0};
		int n=0;
		int counter=0;
		while(counter < MAX_NUM_SAMPLES)
			n += sprintf(&buffer[n], "%d  %d\r\n",time[counter], data[counter]); //format the data to ASCII
			counter++;
		//ff_result = f_write(&file, TEST_STRING, sizeof(TEST_STRING) - 1, (UINT *) &bytes_written);
		ff_result = f_write(&file, buffer , n , (UINT *) &bytes_written);
			if (ff_result != FR_OK)
					NRF_LOG_INFO("Write failed.\r\n");
				  //NRF_LOG_INFO("%d bytes written.\r\n", bytes_written);
		 NRF_LOG_FLUSH();
		 f_sync(&file);
(3)timer handle:
static void thi_monitor_handler(void)
		nrf_saadc_value_t  saadc_val=0;
		nrf_drv_saadc_sample_convert(0,&saadc_val);
		//if( file_switch == true){
			data_sd[event_sd]=saadc_val;
			time_sd[event_sd]=time_control;
			time_control=time_control+1;
			event_sd++;
			if(event_sd>=MAX_NUM_SAMPLES)
				event_sd=0;
				sampling_done = true;
			}else{
				sampling_done = false;
			if(counttx<10)
					DataRead[2*counttx]=(saadc_val>>8);
					DataRead[2*counttx+1]=saadc_val;
					counttx++;
			if(counttx>=10)
				uint32_t err_code;
				if(m_conn_handle!=BLE_CONN_HANDLE_INVALID)
					do
							err_code = ble_lbs_on_button_change1(m_conn_handle, &m_lbs, DataRead);
					}while(err_code == NRF_ERROR_RESOURCES);
				counttx=0;
How should I do to make the writing and connection both working?
all my code shown blow, however some comment are not display properly.
 * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief Blinky Sample Application main file.
 * This file contains the source code for a sample server application using the LED Button service.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_err.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_conn_params.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "ble_lbs.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_qwr.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_delay.h"
#include "nrf_drv_timer.h"
#include "nrf_drv_saadc.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "ff.h"
#include "diskio_blkdev.h"
#include "nrf_block_dev_sdc.h"
#define FILE_NAME   "NORDIC.TXT"
#define TEST_STRING "kx."
#define SDC_SCK_PIN       3///< SDC serial clock (SCK) pin.ARDUINO_13_PIN
#define SDC_MOSI_PIN      2///< SDC serial data in (DI) pin.ARDUINO_11_PIN
#define SDC_MISO_PIN      28///< SDC serial data out (DO) pin.ARDUINO_12_PIN
#define SDC_CS_PIN        29///< SDC chip select (CS) pin. ARDUINO_10_PIN
#define ADVERTISING_LED                 BSP_BOARD_LED_0                         /**< Is on when device is advertising. */
#define CONNECTED_LED                   BSP_BOARD_LED_1                         /**< Is on when device has connected. */
#define LEDBUTTON_LED                   BSP_BOARD_LED_2                         /**< LED to be toggled with the help of the LED Button Service. */
#define LEDBUTTON_BUTTON                BSP_BUTTON_0                            /**< Button that will trigger the notification event with the LED Button Service */
#define DEVICE_NAME                     "Nordic_Blinky"                         /**< Name of device. Will be included in the advertising data. */
#define APP_BLE_OBSERVER_PRIO           3                                       /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define APP_BLE_CONN_CFG_TAG            1                                       /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_ADV_INTERVAL                64                                      /**< The advertising interval (in units of 0.625 ms; this value corresponds to 40 ms). */
#define APP_ADV_DURATION                BLE_GAP_ADV_TIMEOUT_GENERAL_UNLIMITED   /**< The advertising time-out (in units of seconds). When set to 0, we will never time out. */
#define MIN_CONN_INTERVAL               MSEC_TO_UNITS(16, UNIT_1_25_MS)        /**8< Minimum acceptable connection interval . */
#define MAX_CONN_INTERVAL               MSEC_TO_UNITS(16, UNIT_1_25_MS)        /**12< Maximum acceptable connection interval . */
#define SLAVE_LATENCY                   60                                       /**< Slave latency. */
#define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Connection supervisory time-out (4 seconds). */
//#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(20000)                  /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (15 seconds). */
//#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(5000)    /**< Time between each call to sd_ble_gap_conn_param_update after the first call (5 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)
#define MAX_CONN_PARAMS_UPDATE_COUNT    3                                       /**< Number of attempts before giving up the connection parameter negotiation. */
#define BUTTON_DETECTION_DELAY          APP_TIMER_TICKS(50)                     /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define DEAD_BEEF                       0xDEADBEEF                              /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
BLE_LBS_DEF(m_lbs);                                                             /**< LED Button Service instance. */
NRF_BLE_GATT_DEF(m_gatt);                                                       /**< GATT module instance. */
NRF_BLE_QWR_DEF(m_qwr);
/**< Context for the Queued Write module.*/
static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(2);
static uint16_t m_conn_handle = BLE_CONN_HANDLE_INVALID;                        /**< Handle of the current connection. */
static uint8_t m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET;                   /**< Advertising handle used to identify an advertising set. */
static uint8_t m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];                    /**< Buffer for storing an encoded advertising set. */
static uint8_t m_enc_scan_response_data[BLE_GAP_ADV_SET_DATA_SIZE_MAX];         /**< Buffer for storing an encoded scan data. */
//bool file_switch=false;
bool file_switch=true;
//static FIL file1;
/**@brief Struct that contains pointers to the encoded advertising data. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = m_enc_scan_response_data,
/**@brief Function for assert macro callback.
 * @param[in] line_num    Line number of the failing ASSERT call.
 * @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module.
static void timers_init(void)
    // Initialize timer module, making it use the scheduler
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    ret_code_t              err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Encodes the required advertising data and passes it to the stack.
 *          Also builds a structure to be passed to the stack when starting advertising.
    ble_advdata_t advdata;
    ble_advdata_t srdata;
    ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type          = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance = true;
    advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    memset(&srdata, 0, sizeof(srdata));
    srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
    srdata.uuids_complete.p_uuids  = adv_uuids;
    err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
    ble_gap_adv_params_t adv_params;
    // Set advertising parameters.
    memset(&adv_params, 0, sizeof(adv_params));
    adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    adv_params.duration        = APP_ADV_DURATION;
    adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
    adv_params.p_peer_addr     = NULL;
    adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    adv_params.interval        = APP_ADV_INTERVAL;
    err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    APP_ERROR_HANDLER(nrf_error);
/**@brief Function for handling write events to the LED characteristic.
 * @param[in] p_lbs     Instance of LED Button Service to which the write applies.
 * @param[in] led_state Written/desired state of the LED.
static void led_write_handler(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t led_state)
    if (led_state)
			//if(file_switch==false)
				//file_switch=true;
			//else
				//file_switch=false;
        bsp_board_led_on(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED ON!");
        bsp_board_led_off(LEDBUTTON_LED);
        NRF_LOG_INFO("Received LED OFF!");
    ble_lbs_init_t     init     = {0};
    // Initialize LBS.
    init.led_write_handler = led_write_handler;
    err_code = ble_lbs_init(&m_lbs, &init);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module that
 *          are passed to the application.
 * @note All this function does is to disconnect. This could have been done by simply
 *       setting the disconnect_on_fail config parameter, but instead we use the event
 *       handler mechanism to demonstrate its use.
/**@brief Function for handling a Connection Parameters error.
    err_code = sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
    bsp_board_led_on(ADVERTISING_LED);
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connected");
            bsp_board_led_on(CONNECTED_LED);
            bsp_board_led_off(ADVERTISING_LED);
            err_code = app_button_enable();
            NRF_LOG_INFO("Disconnected");
            bsp_board_led_off(CONNECTED_LED);
            err_code = app_button_disable();
            advertising_start();
            // Pairing not supported
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP,
                                                   NULL,
                                                   NULL);
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        case BLE_GATTS_EVT_TIMEOUT:
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Send button state change.");
            //err_code = ble_lbs_on_button_change(m_conn_handle, &m_lbs, button_action);
            if (err_code != NRF_SUCCESS &&
                err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
                err_code != NRF_ERROR_INVALID_STATE &&
                err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
    //The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
                               BUTTON_DETECTION_DELAY);
static void log_init(void)
        nrf_pwr_mgmt_run();
 * @brief  SDC block device definition
NRF_BLOCK_DEV_SDC_DEFINE(
        m_block_dev_sdc,
        NRF_BLOCK_DEV_SDC_CONFIG(
                SDC_SECTOR_SIZE,
                APP_SDCARD_CONFIG(SDC_MOSI_PIN, SDC_MISO_PIN, SDC_SCK_PIN, SDC_CS_PIN)
         NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
 * @brief Function for demonstrating FAFTS usage.
		static FIL file;
static void fatfs_example()
    static FATFS fs;
    static DIR dir;
    static FILINFO fno;
    FRESULT ff_result;
    DSTATUS disk_state = STA_NOINIT;
    // Initialize FATFS disk I/O interface by providing the block device.
    static diskio_blkdev_t drives[] =
            DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
    diskio_blockdev_register(drives, ARRAY_SIZE(drives));
    NRF_LOG_INFO("Initializing disk 0 (SDC)...");
    for (uint32_t retries = 3; retries && disk_state; --retries)
        disk_state = disk_initialize(0);
    if (disk_state)
        NRF_LOG_INFO("Disk initialization failed.");
				//NRF_LOG_INFO("%d",disk_state)
        return;
    uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
    uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
    NRF_LOG_INFO("Capacity: %d MB", capacity);
    NRF_LOG_INFO("Mounting volume...");
    ff_result = f_mount(&fs, "", 1);
    if (ff_result)
        NRF_LOG_INFO("Mount failed.");
        return;
    NRF_LOG_INFO("\r\n Listing directory: /");
    ff_result = f_opendir(&dir, "/");
    if (ff_result)
        NRF_LOG_INFO("Directory listing failed!");
        return;
    do
        ff_result = f_readdir(&dir, &fno);
            NRF_LOG_INFO("Directory read failed.");
            return;
        if (fno.fname[0])
            if (fno.fattrib & AM_DIR)
                NRF_LOG_RAW_INFO("   <DIR>   %s",(uint32_t)fno.fname);
                NRF_LOG_RAW_INFO("%9lu  %s", fno.fsize, (uint32_t)fno.fname);
    while (fno.fname[0]);
    NRF_LOG_RAW_INFO("");
    NRF_LOG_INFO("Writing to file " FILE_NAME "...");
    ff_result = f_open(&file, FILE_NAME, FA_WRITE | FA_OPEN_APPEND);
        NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".");
        return;
        NRF_LOG_INFO("Write failed\r\n.");
        NRF_LOG_INFO("%d bytes written.", bytes_written);
    //(void) f_close(&file);
		f_sync(&file);
    return;
int counttx=0;
uint8_t  DataRead[20];
int16_t data_sd[1000];
uint32_t time_sd[1000];
uint32_t time_control=0;
int event_sd = 0;
int MAX_NUM_SAMPLES=100;
bool sampling_done=false;
volatile uint8_t state = 1;
void saadc_init(void)
    nrf_saadc_channel_config_t channel_config =
            NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN3);
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config);
			event_sd++;
				event_sd=0;
			}else{
			if(counttx<10)
					counttx++;
			if(counttx>=10)
				uint32_t err_code;
					do
				counttx=0;
//¶¨Ê±Æ÷³¬Ê±ÖжϲÙ×÷
static void thi_monitor_timeout_handler(nrf_timer_event_t event_type,void * p_context)
	    switch (event_type)
        case NRF_TIMER_EVENT_COMPARE2:
					thi_monitor_handler();
            //Do nothing.
static void timers_init1(void)
	  uint32_t err_code;
 //   APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
	  // ´´½¨Ò»¸öÖÜÆÚÖ´ÐеĶ¨Ê±Æ÷£¬ÓÃÓÚ¼ì²âÎÂʪ¶È
    err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, thi_monitor_timeout_handler);
//¶¨Ê±Æ÷¿ªÊ¼¼ÆÊ±£¬Ê±¼ä¼ä¸ô2ms
/**@brief Function for starting application timers.
static void application_timers_start(void)
    uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 10);
                                   NRF_TIMER_CC_CHANNEL2,
                                   ticks,
                                   NRF_TIMER_SHORT_COMPARE2_CLEAR_MASK,
                                   true);
		FRESULT ff_result;
		int n=0;
		int counter=0;
			counter++;
		 NRF_LOG_FLUSH();
		 f_sync(&file);
/**@brief Function for application main entry.
    // Initialize.
    log_init();
    leds_init();
		while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0);
		NRF_CLOCK->LFCLKSRC = CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos;
		NRF_CLOCK->TASKS_LFCLKSTART = 1;
		while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0);
    timers_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
	  //nrf_gpio_cfg_output(5);
		fatfs_example();
	  saadc_init();
		timers_init1();
		application_timers_start();
    services_init();
    advertising_init();
    conn_params_init();
    // Start execution.
    NRF_LOG_INFO("Blinky example started.");
    //NRF_LOG_DEFAULT_BACKENDS_INIT();
    NRF_LOG_INFO("FATFS example started.");
		NRF_LOG_FLUSH();
    while(1){
			//if( (sampling_done == true) && (file_switch == true))
    // Enter main loop.
    for (;;)
        idle_state_handle();
  • I assume there can be two reasons for disconnect, either:
    1. The sdWrite() somehow block the softdevice interrupts for a long period of time. Preventing it from processing the BLE events.
    -OR-
    2. The sdWrite() cause noise and impact the communication, maybe look at ripple on VDD and/or try other GPIO's for the SD card. Is this using your own nRF52 module, or are you using an nRF52-DK?
  • Thanks for your reply!
    I have found the problem, the f_write() seems not to block the process, but the f_sync() take a longer time which will bring the interrupts. So now I use the Master to give the Slave a signal to start wring 512 bytes(or integral multiples) per time, and in the end give the Slave a signal to use f_sync to save .txt. It works well in my one hour test and save 10 MB data.
    But now I meet another problem, the timer is inaccurate when I write to .txt. Perhaps the deviation is caused by the disconnection and connection as the following picture shows. The hardware timers performs well if the Slave connects with the Master well.
    Why is the time deviation happen when disconnection and connection? And what should I do?
