Problems programming nRF9160 DK with Segger Embedded Studio
For some reason I can't quite program the nRF9160 on the development board using Segger Embedded Studio (SES) when I create a new project. I must be doing something wrong as I seem to be able to run the verify function in SES just fine. When there's other code in the chip it tells me the differences and when I manually program the .hex using the USB drive that pops up or the Programmer application in the nRF connect app it succeeds.
The error that I get is 'Failed to write memory.' and 'Failed to download application. Generic Error. Please check J-Link and target connection.'
I think it must be related to the new project i created because I can program the demo just fine.
My steps:
1. Open up SES (Nordic edition V4.20a)
2. File -> New Project -> Create the project in a new solution -> A C/C++ executable for Nordic Semiconductor nRF.
3. I give the project a name and click next, on the next page I choose Target Processor -> nRF9160_xxAA
4. I leave other settings untouched, or in some cases I selected additional Output format -> .HEX (section placement is Flash as per default)
5. I Click Next -> Next -> Finish and the project is ready.
6. In the top menu I choose Build -> Build and Run. This starts building the project and the last output before the 'Failed to write memory.' error pops up is:
    Downloading Test201910191139.elf to J-Link  4.4KB in 0.0s
    Download Failed  172.3KB/s
When I build the demo project it works:
1. Again I open up Open up SES (Nordic edition V4.20a)
2. File -> Open nRF Connect SDK Project
CMakeLists.txt -> C:/nordicsources/ncs/nrf/samples/nrf9160/gps/CMakeLists.txt
Board Directory -> C:/nordicsources/ncs/zephyr/boards/arm/nrf9160_pca10090
Board Name -> nrf9160_pca10090ns
Build Directory -> C:/nordicsources/ncs/nrf/samples/nrf9160/gps/build_nrf9160_pca10090ns
Clean Build Directory -> Checked
3. Click OK, and the project is generated / loaded
4. Top menu -> Build -> Build and Run
5. Building takes some time and ends with 'Downloading merged.hex to J-Link' which opens a dialog showing the progress and working out just fine.
So my best guess is that I should configure the project to use the .HEX instead of the .elf?
For now I don't seem to be able to find where I should change this.
Joost
Edit:
I just tried programming the generated .hex in SES using Target -> Download File -> Download Intel Hex File -> The generated.hex and it gives the same error, so the .elf instead of .hex does not seem to be the problem.
