nRF52840 (BMD-340-A-R) + Raspberry Pi 3B+ max MTU size does not work
Dear Nordic Support,
I am using ble_nus service on nRF52840 (BMD-340-A-R) + Raspberry Pi 3B+ (https://github.com/IanHarvey/bluepy). The nRF52840 is the peripheral and the Pi 3B+ is the central. Using nRF5 SDK 15.3.
I set following parameters:
#define NRF_SDH_BLE_GAP_DATA_LENGTH      251
#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE   247
The connection between the nRF52840 and the Raspberry Pi is OK, the MTU also changed.
The issue is:
1/ The nRF52840 can only receive and send below 23 bytes.
2/ Same configuration for the nRF52840 but there is not problem when connecting with the Android.
Do you have any suggestion to fix this issue? Or to find the root cause of this? My temporary solution to make the nRF52840 send and receive more than 23 bytes with the Pi 3B+ is modifying the following line in ble_gatt.h:
#define BLE_GATT_ATT_MTU_DEFAULT          23
change to
#define BLE_GATT_ATT_MTU_DEFAULT          247
I found the relevant case: https://devzone.nordicsemi.com/f/nordic-q-a/38563/max-mtu-for-characteristic-read-not-honoured-in-some-cases
Thank you and best regards,
       Duy Tran
  • Hi Duy Tran
    Let's see if I understand your problem correctly. Your nRF52840 (peripheral) is not able to receive/send more than 23 bytes when it is connected to a Raspberry Pi central, but there are no problems if the central is an Android phone for example, is that correct?
    A few things you can check:
    • What are the MTU settings of the Raspberry Pi? Is that set to transfer more than 23 bytes by default? I have not looked specifically at this example, but could it be that the Raspberry Pi also uses ble_gatt.h to decide the default MTU?
    • Did you try the workaround from the relevant case you linked to? Please see the verified answer, and try that out.
    • Where in the code is the NRF_SDH_BLE_GATT_MAX_MTU_SIZE set? Are you sure that that is the MTU size that is used by the application, and not the BLE_GATT_ATT_MTU_DEFAULT?
    Simon
  • Hello ,
    Thank you for your answer, you understand the problem correctly.
    I checks things that you told me:
    1/
    => It is set to 247 already. There is a configuration param.
    2/
    => I am still working on the relevant case. Not yet work.
    3/
    => Below is the function I am using to check. I copied from an example. I also run the debug and it shows that the MTU is changed to 247 bytes.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        m_wrench_send++;
        NRF_LOG_INFO("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
        Duy
  • Hi
    Have you tried connecting the Raspberry Pi to your Android phone, to confirm whether you're able to transfer more than 23 bytes between those devices? If not, I think it's safe to say that the Raspberry Pi is the common denominator in this issue.
    If that's not the case, you can try sniffing the connection (between the nRF and the Raspberry Pi) using the nRF Sniffer, and upload the sniffer log here, so I can take a look at what happens between the devices when they connect and negotiate the MTU size.
    Simon
  • Hello ,
    Sorry for my late reply, I don't have enough board so I had to bought one. I tested as you said and the issues lies in the Raspberry Pi. I don't know what happens inside it.
    I attached log with both cases: with MTU exchange removed (work - similar to the relevant case) and without MTU exahnge removed (not work). These logs are the connection between the nRF52840 and the Raspberry Pi 3 B+.
    Sniffer with MTU exchanged removed.pcapng
    Sniffer without MTU exchanged removed.pcapng
    Honestly, I don't understand well the about this MTU exchange process, do you know any helpful documents for this?
           Duy
  • Hi Duy
    Our throughput and long-range demo (and the documentation it links to) might be able to help you understand the MTU process better. As for how to change the MTU size for the Raspberry Pi, I'm not sure how to do this, and I think that question is better suited for a Raspberry Pi forum, as we focus on Nordic products.
    Simon
