I follow the nRF Connect SDK on a Windows 10 x64 computer and it's a crap. I get a lot of errors like this one. It's so crappy that I doubt that I will continue with the nRF9160 (that looks interesting, after so many years on nRF52, I'am disapointed by the new SDK).
Running setup.py install for pygit2 ... error
ERROR: Command errored out with exit status 1:
command: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-_2v8t4rg\\pygit2\\setup.py'"'"'; __file__='"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-_2v8t4rg\\pygit2\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\fabien\AppData\Local\Temp\pip-record-8d3mh90x\install-record.txt' --single-version-externally-managed --compile
cwd: C:\Users\fabien\AppData\Local\Temp\pip-install-_2v8t4rg\pygit2\
Complete output (58 lines):
running install
running build
running build_py
creating build
creating build\lib.win-amd64-3.8
creating build\lib.win-amd64-3.8\pygit2
copying pygit2\blame.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\config.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\credentials.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\errors.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\ffi.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\index.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\py2.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\py3.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\refspec.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\remote.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\repository.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\settings.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\submodule.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\utils.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\_build.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\_run.py -> build\lib.win-amd64-3.8\pygit2
copying pygit2\__init__.py -> build\lib.win-amd64-3.8\pygit2
creating build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\attr.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\blame.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\buffer.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\checkout.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\clone.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\common.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\config.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\describe.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\diff.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\errors.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\graph.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\index.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\merge.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\net.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\oid.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\pack.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\proxy.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\refspec.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\remote.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\repository.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\revert.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\stash.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\strarray.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\submodule.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\transport.h -> build\lib.win-amd64-3.8\pygit2\decl
copying pygit2\decl\types.h -> build\lib.win-amd64-3.8\pygit2\decl
running build_ext
generating cffi module 'build\\temp.win-amd64-3.8\\Release\\pygit2._libgit2.c'
creating build\temp.win-amd64-3.8
creating build\temp.win-amd64-3.8\Release
building '_pygit2' extension
creating build\temp.win-amd64-3.8\Release\src
cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MT "-IC:\Program Files\libgit2\include" -Ic:\python38\include -Ic:\python38\include "-IC:\Program Files (x86)\Windows Kits\NETFXSDK\4.6.1\include\um" /Tcsrc\blob.c /Fobuild\temp.win-amd64-3.8\Release\src\blob.obj
error: command 'cl.exe' failed: No such file or directory
ERROR: Command errored out with exit status 1: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-_2v8t4rg\\pygit2\\setup.py'"'"'; __file__='"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-_2v8t4rg\\pygit2\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\fabien\AppData\Local\Temp\pip-record-8d3mh90x\install-record.txt' --single-version-externally-managed --compile Check the logs for full command output.
Collecting Pillow
Using cached files.pythonhosted.org/.../Pillow-6.2.0.tar.gz
Requirement already satisfied: PyYAML>=3.13 in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 2)) (4.2b4)
Collecting breathe==4.9.1
Using cached files.pythonhosted.org/.../breathe-4.9.1-py2.py3-none-any.whl
Requirement already satisfied: colorama in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 4)) (0.4.1)
Collecting docutils==0.14
Using cached files.pythonhosted.org/.../docutils-0.14-py3-none-any.whl
Collecting gcovr
Using cached files.pythonhosted.org/.../gcovr-4.1-py2.py3-none-any.whl
Collecting git-spindle==2.0
Using cached files.pythonhosted.org/.../git-spindle-2.0.tar.gz
Collecting gitlint
Using cached files.pythonhosted.org/.../gitlint-0.12.0-py2.py3-none-any.whl
Requirement already satisfied: intelhex in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 9)) (2.2.1)
Collecting junit2html
Using cached files.pythonhosted.org/.../junit2html-022.tar.gz
Requirement already satisfied: packaging in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 11)) (19.2)
Collecting ply==3.10
Using cached files.pythonhosted.org/.../ply-3.10.tar.gz
Collecting pyelftools==0.24
Using cached files.pythonhosted.org/.../pyelftools-0.24.tar.gz
Requirement already satisfied: pykwalify in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 14)) (1.7.0)
Collecting pyocd==0.21.0
Using cached files.pythonhosted.org/.../pyocd-0.21.0-py2.py3-none-any.whl
Requirement already satisfied: pyserial in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 16)) (3.4)
Collecting pytest
Using cached files.pythonhosted.org/.../pytest-5.2.1-py3-none-any.whl
Collecting sphinx==1.7.5
Using cached files.pythonhosted.org/.../Sphinx-1.7.5-py2.py3-none-any.whl
Collecting sphinx_rtd_theme
Using cached files.pythonhosted.org/.../sphinx_rtd_theme-0.4.3-py2.py3-none-any.whl
Collecting sphinx-tabs
Using cached files.pythonhosted.org/.../sphinx-tabs-1.1.13.tar.gz
Collecting sphinxcontrib-svg2pdfconverter
Using cached files.pythonhosted.org/.../sphinxcontrib_svg2pdfconverter-1.0.1-py3-none-any.whl
Requirement already satisfied: west>=0.6.2 in c:\python38\lib\site-packages (from -r zephyr\scripts\requirements.txt (line 22)) (0.6.3)
Collecting wheel==0.30.0
Using cached files.pythonhosted.org/.../wheel-0.30.0-py2.py3-none-any.whl
Collecting windows-curses
Using cached files.pythonhosted.org/.../windows_curses-2.1.0-cp38-cp38-win_amd64.whl
Requirement already satisfied: six>=1.4 in c:\python38\lib\site-packages (from breathe==4.9.1->-r zephyr\scripts\requirements.txt (line 3)) (1.12.0)
Requirement already satisfied: jinja2 in c:\python38\lib\site-packages (from gcovr->-r zephyr\scripts\requirements.txt (line 6)) (2.10.3)
Collecting github3.py>=0.8.2
Using cached files.pythonhosted.org/.../github3.py-1.3.0-py2.py3-none-any.whl
Collecting whelk>=1.11
Using cached files.pythonhosted.org/.../whelk-2.7.1.tar.gz
Requirement already satisfied: docopt>=0.5.0 in c:\python38\lib\site-packages (from git-spindle==2.0->-r zephyr\scripts\requirements.txt (line 7)) (0.6.2)
Collecting arrow==0.14.2; python_version != "3.4"
Using cached files.pythonhosted.org/.../arrow-0.14.2-py2.py3-none-any.whl
Requirement already satisfied: Click==7.0 in c:\python38\lib\site-packages (from gitlint->-r zephyr\scripts\requirements.txt (line 8)) (7.0)
Requirement already satisfied: pyparsing>=2.0.2 in c:\python38\lib\site-packages (from packaging->-r zephyr\scripts\requirements.txt (line 11)) (2.4.2)
Requirement already satisfied: python-dateutil>=2.4.2 in c:\python38\lib\site-packages (from pykwalify->-r zephyr\scripts\requirements.txt (line 14)) (2.8.0)
Collecting prettytable
Using cached files.pythonhosted.org/.../prettytable-0.7.2.tar.bz2
Collecting intervaltree<4.0,>=3.0.2
Using cached files.pythonhosted.org/.../intervaltree-3.0.2.tar.gz
Collecting cmsis-pack-manager>=0.2.7
Using cached files.pythonhosted.org/.../cmsis_pack_manager-0.2.8-py2.py3-none-win_amd64.whl
Collecting pyusb<2.0,>=1.0.0b2
Using cached files.pythonhosted.org/.../pyusb-1.0.2.tar.gz
Collecting pywinusb>=0.4.0; platform_system == "Windows"
Using cached files.pythonhosted.org/.../pywinusb-0.4.2.zip
Collecting more-itertools>=4.0.0
Using cached files.pythonhosted.org/.../more_itertools-7.2.0-py3-none-any.whl
Collecting py>=1.5.0
Using cached files.pythonhosted.org/.../py-1.8.0-py2.py3-none-any.whl
Collecting pluggy<1.0,>=0.12
Using cached files.pythonhosted.org/.../pluggy-0.13.0-py2.py3-none-any.whl
Collecting wcwidth
Using cached files.pythonhosted.org/.../wcwidth-0.1.7-py2.py3-none-any.whl
Collecting atomicwrites>=1.0
Using cached files.pythonhosted.org/.../atomicwrites-1.3.0-py2.py3-none-any.whl
Collecting attrs>=17.4.0
Using cached files.pythonhosted.org/.../attrs-19.3.0-py2.py3-none-any.whl
Requirement already satisfied: Pygments>=2.0 in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2.4.2)
Requirement already satisfied: snowballstemmer>=1.1 in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2.0.0)
Requirement already satisfied: imagesize in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (1.1.0)
Requirement already satisfied: setuptools in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (41.2.0)
Requirement already satisfied: babel!=2.0,>=1.3 in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2.7.0)
Requirement already satisfied: alabaster<0.8,>=0.7 in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (0.7.12)
Collecting sphinxcontrib-websupport
Using cached files.pythonhosted.org/.../sphinxcontrib_websupport-1.1.2-py2.py3-none-any.whl
Requirement already satisfied: requests>=2.0.0 in c:\python38\lib\site-packages (from sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2.22.0)
Requirement already satisfied: configobj in c:\python38\lib\site-packages (from west>=0.6.2->-r zephyr\scripts\requirements.txt (line 22)) (5.0.6)
Requirement already satisfied: MarkupSafe>=0.23 in c:\python38\lib\site-packages (from jinja2->gcovr->-r zephyr\scripts\requirements.txt (line 6)) (1.1.1)
Collecting jwcrypto>=0.5.0
Using cached files.pythonhosted.org/.../jwcrypto-0.6.0-py2.py3-none-any.whl
Collecting uritemplate>=3.0.0
Using cached files.pythonhosted.org/.../uritemplate-3.0.0-py2.py3-none-any.whl
Collecting sortedcontainers<3.0,>=2.0
Using cached files.pythonhosted.org/.../sortedcontainers-2.1.0-py2.py3-none-any.whl
Collecting appdirs>=1.4
Using cached files.pythonhosted.org/.../appdirs-1.4.3-py2.py3-none-any.whl
Collecting milksnake>=0.1.2
Using cached files.pythonhosted.org/.../milksnake-0.1.5-py2.py3-none-any.whl
Requirement already satisfied: pytz>=2015.7 in c:\python38\lib\site-packages (from babel!=2.0,>=1.3->sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2019.3)
Requirement already satisfied: urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1 in c:\python38\lib\site-packages (from requests>=2.0.0->sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (1.25.6)
Requirement already satisfied: certifi>=2017.4.17 in c:\python38\lib\site-packages (from requests>=2.0.0->sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2019.9.11)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\python38\lib\site-packages (from requests>=2.0.0->sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (3.0.4)
Requirement already satisfied: idna<2.9,>=2.5 in c:\python38\lib\site-packages (from requests>=2.0.0->sphinx==1.7.5->-r zephyr\scripts\requirements.txt (line 18)) (2.8)
Requirement already satisfied: cryptography>=1.5 in c:\python38\lib\site-packages (from jwcrypto>=0.5.0->github3.py>=0.8.2->git-spindle==2.0->-r zephyr\scripts\requirements.txt (line 7)) (2.8)
Requirement already satisfied: cffi>=1.6.0 in c:\python38\lib\site-packages (from milksnake>=0.1.2->cmsis-pack-manager>=0.2.7->pyocd==0.21.0->-r zephyr\scripts\requirements.txt (line 15)) (1.13.0)
Requirement already satisfied: pycparser in c:\python38\lib\site-packages (from cffi>=1.6.0->milksnake>=0.1.2->cmsis-pack-manager>=0.2.7->pyocd==0.21.0->-r zephyr\scripts\requirements.txt (line 15)) (2.19)
ERROR: pyocd 0.21.0 has requirement pyyaml<6.0,>=5.1, but you'll have pyyaml 4.2b4 which is incompatible.
Installing collected packages: Pillow, docutils, sphinxcontrib-websupport, sphinx, breathe, gcovr, jwcrypto, uritemplate, github3.py, whelk, git-spindle, arrow, gitlint, junit2html, ply, pyelftools, prettytable, sortedcontainers, intervaltree, appdirs, milksnake, cmsis-pack-manager, pyusb, pywinusb, pyocd, more-itertools, py, pluggy, wcwidth, atomicwrites, attrs, pytest, sphinx-rtd-theme, sphinx-tabs, sphinxcontrib-svg2pdfconverter, wheel, windows-curses
Running setup.py install for Pillow ... error
command: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-vfrm1uka\\Pillow\\setup.py'"'"'; __file__='"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-vfrm1uka\\Pillow\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\fabien\AppData\Local\Temp\pip-record-0bbqhvde\install-record.txt' --single-version-externally-managed --compile
cwd: C:\Users\fabien\AppData\Local\Temp\pip-install-vfrm1uka\Pillow\
Complete output (176 lines):
C:\Users\fabien\AppData\Local\Temp\pip-install-vfrm1uka\Pillow\setup.py:28: RuntimeWarning: Pillow does not yet support Python 3.8 and does not yet provide prebuilt Windows binaries. We do not recommend building from source on Windows.
warnings.warn(
running install
running build
running build_py
creating build
creating build\lib.win-amd64-3.8\PIL
copying src\PIL\BdfFontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BlpImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BmpImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\BufrStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ContainerIO.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\CurImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\DcxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\DdsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\EpsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ExifTags.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\features.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FitsStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FliImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FpxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\FtexImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GbrImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GdImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GifImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GimpGradientFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GimpPaletteFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\GribStubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Hdf5StubImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IcnsImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IcoImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Image.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageChops.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageCms.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageColor.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageDraw.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageDraw2.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageEnhance.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFilter.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageFont.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageGrab.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMath.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMode.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageMorph.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageOps.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImagePalette.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImagePath.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageQt.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageSequence.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageShow.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageStat.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageTk.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageTransform.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImageWin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\ImtImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\IptcImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\Jpeg2KImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\JpegImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\JpegPresets.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\McIdasImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MicImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MpegImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MpoImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\MspImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PaletteFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PalmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcdImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcfFontFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PcxImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PdfImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PdfParser.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PixarImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PngImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PpmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PsdImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PSDraw.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\PyAccess.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SgiImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SpiderImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\SunImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TarIO.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TgaImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TiffImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\TiffTags.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WalImageFile.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WebPImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\WmfImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XbmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XpmImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\XVThumbImagePlugin.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_binary.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_tkinter_finder.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_util.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\_version.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\__init__.py -> build\lib.win-amd64-3.8\PIL
copying src\PIL\__main__.py -> build\lib.win-amd64-3.8\PIL
running egg_info
writing src\Pillow.egg-info\PKG-INFO
writing dependency_links to src\Pillow.egg-info\dependency_links.txt
writing top-level names to src\Pillow.egg-info\top_level.txt
reading manifest file 'src\Pillow.egg-info\SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.c'
warning: no files found matching '*.h'
warning: no files found matching '*.sh'
warning: no previously-included files found matching '.appveyor.yml'
warning: no previously-included files found matching '.coveragerc'
warning: no previously-included files found matching '.codecov.yml'
warning: no previously-included files found matching '.editorconfig'
warning: no previously-included files found matching '.readthedocs.yml'
warning: no previously-included files found matching 'azure-pipelines.yml'
warning: no previously-included files matching '.git*' found anywhere in distribution
warning: no previously-included files matching '*.pyc' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
no previously-included directories found matching '.azure-pipelines'
no previously-included directories found matching '.travis'
writing manifest file 'src\Pillow.egg-info\SOURCES.txt'
running build_ext
The headers or library files could not be found for zlib,
a required dependency when compiling Pillow from source.
pillow.readthedocs.io/.../installation.html
File "C:\Users\fabien\AppData\Local\Temp\pip-install-vfrm1uka\Pillow\setup.py", line 852, in <module>
setup(
File "c:\python38\lib\site-packages\setuptools\__init__.py", line 145, in setup
return distutils.core.setup(**attrs)
File "c:\python38\lib\distutils\core.py", line 148, in setup
dist.run_commands()
File "c:\python38\lib\distutils\dist.py", line 966, in run_commands
self.run_command(cmd)
File "c:\python38\lib\distutils\dist.py", line 985, in run_command
cmd_obj.run()
File "c:\python38\lib\site-packages\setuptools\command\install.py", line 61, in run
return orig.install.run(self)
File "c:\python38\lib\distutils\command\install.py", line 545, in run
self.run_command('build')
File "c:\python38\lib\distutils\cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "c:\python38\lib\distutils\command\build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "c:\python38\lib\distutils\command\build_ext.py", line 340, in run
self.build_extensions()
File "C:\Users\fabien\AppData\Local\Temp\pip-install-vfrm1uka\Pillow\setup.py", line 687, in build_extensions
raise RequiredDependencyException(f)
__main__.RequiredDependencyException: zlib
File "<string>", line 1, in <module>
File "C:\Users\fabien\AppData\Local\Temp\pip-install-vfrm1uka\Pillow\setup.py", line 902, in <module>
raise RequiredDependencyException(msg)
ERROR: Command errored out with exit status 1: 'c:\python38\python.exe' -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-vfrm1uka\\Pillow\\setup.py'"'"'; __file__='"'"'C:\\Users\\fabien\\AppData\\Local\\Temp\\pip-install-vfrm1uka\\Pillow\\setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\fabien\AppData\Local\Temp\pip-record-0bbqhvde\install-record.txt' --single-version-externally-managed --compile Check the logs for full command output.
