Unable to downgrade nRF9160 modem firmware from 1.0.1 to 1.0.0
I'm trying to downgrade the nRF9160 modem firmware from 1.0.1 to 1.0.0. I'm currently unable to connect to LTE network from a location where I was connecting in seconds beforehand. This is critical because even in locations where the LTE network is around -60dBm (measured with my phone) the modem does not connect.
Re-flashing the 1.0.1 works flawlessly so this is not an issue with my software configuration.
When trying to downgrade with nRFConnect I get the following log :
2019-10-22T16:30:48.533Z INFO Recovery procedure finished
2019-10-22T16:30:48.547Z INFO Using nrfjprog to communicate with target
2019-10-22T16:30:50.188Z INFO Using J-Link Software version 6.48
2019-10-22T16:30:52.318Z INFO Segger serial:  600114712
2019-10-22T16:30:52.319Z INFO Segger speed:  2000  kHz
2019-10-22T16:30:52.319Z INFO Segger version:  J-Link V10 compiled Jul 23 2019 13:46:10
2019-10-22T16:30:52.328Z INFO Probed: 600114712.
2019-10-22T16:30:52.328Z INFO Model: NRF9160_xxAA_FUTURE.
2019-10-22T16:30:52.328Z INFO RAM: 256KiB.
2019-10-22T16:30:52.328Z INFO Flash: 1024KiB in pages of 4KiB.
2019-10-22T16:30:53.784Z INFO Reading device non-volatile memory. This may take a few seconds.
2019-10-22T16:31:07.457Z INFO Modem DFU starts to write...
2019-10-22T16:31:07.457Z INFO Writing to device with serial number: 600114712
2019-10-22T16:31:07.457Z INFO Writing to device with file: E:\nordic\modem_upgrade\mfw_nrf9160_1.0.0.zip
2019-10-22T16:31:09.589Z INFO Checking file 1 of 7 files.
2019-10-22T16:31:09.590Z INFO Finished with file.
2019-10-22T16:31:09.593Z INFO Checking file 2 of 7 files.
2019-10-22T16:31:09.595Z INFO Finished with file.
2019-10-22T16:31:09.597Z INFO Checking file 3 of 7 files.
2019-10-22T16:31:09.605Z INFO Programming file.
2019-10-22T16:31:09.637Z INFO Programming 1 of 1 segments.
2019-10-22T16:31:09.728Z INFO Programming finished.
2019-10-22T16:31:09.731Z INFO Finished with file.
2019-10-22T16:31:09.735Z INFO Checking file 4 of 7 files.
2019-10-22T16:31:09.738Z INFO Programming file.
2019-10-22T16:31:14.423Z INFO Programming 1 of 33 segments.
2019-10-22T16:31:14.873Z ERROR Modem DFU failed with error: Error: Error occured when program. Errorcode: CouldNotCallFunction (0x9)
Lowlevel error: Unknown value (ffffff23)
What solution do I have to get my modem to work again?
Thanks
  • Note: it is not possible to downgrade to previous modem firmware releases after applying this upgrade.
    So you were able to connect to the LTE-M network without any issues with the nrf9160 with the mfw v1.0.0?
    Are you using the iBasis SIM card or local carrier SIM card?
    Please share the LTE link monitor log from when you are trying to connect and it would be nice if you could share a modem trace then we can figure out what is going wrong.
    I finally managed to connect with the nRF9160DK devkit, with mfw v1.0.1 and the iBasis SIM. It also worked with an Orange SIM (I'm in France). It connected almost immediately, so what I'm experiencing is definitely not a network issue.
    The issue is that I'm still unable to connect to LTE with my custom board. The radio hardware is based on the Thingy:91 schematics. Please note that it was also able to connect extremely rapidly (in seconds) to the network last week, we did not make any changes to the hardware.
    I'm guessing the modem configuration got scrambled somehow, but I fail to see how it happened and do not know how to restore its factory state.
    Both boards run the mfw_1.0.1 firmware and the AT_CLIENT sample code, files were gathered using the nRFConnect Link Monitor and Trace Collector.
    Thank you for your help!
    2019-10-23T14:49:08.097Z INFO Application data folder: C:\Users\julien.le-guen\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-10-23T14:49:08.562Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2019-10-23T14:49:08.562Z DEBUG App path: C:\Users\julien.le-guen\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-10-23T14:49:08.563Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-10-23T14:49:08.563Z DEBUG nRFConnect path: C:\Users\julien.le-guen\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-10-23T14:49:08.563Z DEBUG HomeDir: C:\Users\julien.le-guen
    2019-10-23T14:49:08.563Z DEBUG TmpDir: C:\Users\JULIEN~1.LE-\AppData\Local\Temp
    2019-10-23T14:49:19.293Z INFO Modem port is opened
    2019-10-23T14:49:19.309Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:49:50.344Z DEBUG modem << ** Booting Zephyr OS v1.14.99-ncs2 *****\x0D\x0A
    2019-10-23T14:49:50.360Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-23T14:49:50.364Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.369Z DEBUG modem << 01 0x08000 0x10000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.376Z DEBUG modem << 02 0x10000 0x18000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.380Z DEBUG modem << 03 0x18000 0x20000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.389Z DEBUG modem << 04 0x20000 0x28000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.396Z DEBUG modem << 05 0x28000 0x30000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.399Z DEBUG modem << 06 0x30000 0x38000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.430Z DEBUG modem << 07 0x38000 0x40000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.437Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.447Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.450Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.461Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.467Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.480Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.484Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.493Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.499Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.501Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.512Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.530Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.533Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.536Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.540Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.542Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.552Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.554Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.565Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.568Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.576Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.578Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.581Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.584Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.587Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D\x0A\x0D\x0A\x0D\x0A
    2019-10-23T14:49:50.590Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-23T14:49:50.593Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.597Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.599Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.601Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.609Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.612Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.615Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.617Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.620Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.628Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.630Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.634Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.638Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.643Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.647Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.649Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.651Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.656Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.659Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.679Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.681Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.686Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.694Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.699Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.701Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.704Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.712Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.713Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.715Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.717Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.719Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:49:50.722Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2019-10-23T14:49:50.726Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2019-10-23T14:49:50.728Z DEBUG modem << 00 NRF_P0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.729Z DEBUG modem << 01 NRF_CLOCK\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.730Z DEBUG modem << 02 NRF_RTC1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.732Z DEBUG modem << 03 NRF_NVMC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.735Z DEBUG modem << 04 NRF_UARTE1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.739Z DEBUG modem << 05 NRF_UARTE2\x09\x09Secure\x09\x09SKIP\x0D\x0A
    2019-10-23T14:49:50.742Z DEBUG modem << 06 NRF_TWIM2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.744Z DEBUG modem << 07 NRF_SPIM3\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.745Z DEBUG modem << 08 NRF_TIMER0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.747Z DEBUG modem << 09 NRF_TIMER1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.749Z DEBUG modem << 10 NRF_TIMER2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.751Z DEBUG modem << 11 NRF_SAADC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.753Z DEBUG modem << 12 NRF_PWM0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.757Z DEBUG modem << 13 NRF_PWM1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.760Z DEBUG modem << 14 NRF_PWM2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.762Z DEBUG modem << 15 NRF_PWM3\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.763Z DEBUG modem << 16 NRF_IPC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.764Z DEBUG modem << 17 NRF_VMC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.766Z DEBUG modem << 18 NRF_FPU\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.768Z DEBUG modem << 19 NRF_EGU1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.771Z DEBUG modem << 20 NRF_EGU2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:49:50.775Z DEBUG modem << 21 NRF_GPIOTE1\x09\x09Non-Secure\x09OK\x0D\x0A\x0D\x0A
    2019-10-23T14:49:50.777Z DEBUG modem << SPM: NS image at 0xc000\x0D\x0A
    2019-10-23T14:49:50.780Z DEBUG modem << SPM: NS MSP at 0x20023b90\x0D\x0A
    2019-10-23T14:49:50.781Z DEBUG modem << SPM: NS reset vector at 0xe61d\x0D\x0A
    2019-10-23T14:49:50.782Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2019-10-23T14:49:51.076Z DEBUG modem << ***** Booting Zephyr OS v1.14.99-ncs2 *****\x0D\x0A
    2019-10-23T14:49:51.083Z DEBUG modem << The AT host sample started\x0D\x0A
    2019-10-23T14:49:56.277Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:49:56.295Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-10-23T14:49:56.327Z DEBUG modem << OK\x0D
    2019-10-23T14:49:56.348Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-10-23T14:49:56.413Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.055Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:50:01.063Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-23T14:50:01.083Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.092Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-23T14:50:01.109Z DEBUG modem << +CGSN: "352656100268153"\x0D
    2019-10-23T14:50:01.121Z DEBUG modem << \x0A
    2019-10-23T14:50:01.123Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.155Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-23T14:50:01.166Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-23T14:50:01.168Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.189Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-23T14:50:01.214Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-23T14:50:01.217Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.239Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-23T14:50:01.276Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-23T14:50:01.279Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.281Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100268153
    2019-10-23T14:50:01.283Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-23T14:50:01.325Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-10-23T14:50:01.327Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.359Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-23T14:50:01.389Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-10-23T14:50:01.392Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.451Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-23T14:50:01.466Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-10-23T14:50:01.471Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.476Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-10-23T14:50:01.500Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.517Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-23T14:50:01.545Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-10-23T14:50:01.578Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.599Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-10-23T14:50:01.638Z DEBUG modem << OK\x0D\x0A
    2019-10-23T14:50:01.644Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-23T14:50:01.679Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-10-23T14:50:01.682Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.689Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-23T14:50:01.715Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","10.160.133.153",0,0\x0D\x0A
    2019-10-23T14:50:01.723Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.762Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-23T14:50:01.795Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2019-10-23T14:50:01.797Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.845Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-10-23T14:50:01.860Z DEBUG modem << OK\x0D\x0A
    2019-10-23T14:50:01.878Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-23T14:50:01.899Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.932Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-23T14:50:01.966Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:01.987Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-23T14:50:02.047Z DEBUG modem << +CEREG: 2,5,"0567","00B98C05",7\x0D\x0A
    2019-10-23T14:50:02.053Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.098Z DEBUG modem >> AT+COPS=3,2\x0D\x0A
    2019-10-23T14:50:02.115Z DEBUG modem << OK\x0D
    2019-10-23T14:50:02.147Z DEBUG modem >> AT+COPS?\x0D\x0A
    2019-10-23T14:50:02.182Z DEBUG modem << +COPS: 0,2,"20801",7\x0D\x0A
    2019-10-23T14:50:02.193Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.226Z DEBUG modem >> AT%XCBAND\x0D\x0A
    2019-10-23T14:50:02.248Z DEBUG modem << %XCBAND: 20\x0D\x0A
    2019-10-23T14:50:02.260Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.281Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-23T14:50:02.310Z DEBUG modem << +CGDCONT: 0,"IP","ibasis.iot","10.160.133.153",0,0\x0D\x0A
    2019-10-23T14:50:02.312Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.338Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-23T14:50:02.360Z DEBUG modem << +CGACT: 0,1\x0D\x0A
    2019-10-23T14:50:02.364Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.394Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-23T14:50:02.414Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.433Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-23T14:50:02.464Z DEBUG modem << +CESQ: 99,99,255,255,255,50\x0D\x0A
    2019-10-23T14:50:02.469Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.496Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-23T14:50:02.515Z DEBUG modem << OK\x0D
    2019-10-23T14:50:02.531Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-23T14:50:02.560Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-23T14:50:02.566Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.596Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-23T14:50:02.626Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-23T14:50:02.629Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.664Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-23T14:50:02.726Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-23T14:50:02.730Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.777Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-23T14:50:02.808Z DEBUG modem << 204080813510411\x0D\x0A
    2019-10-23T14:50:02.811Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:50:02.814Z INFO IMSIdentity: 204080813510411
    2019-10-23T14:50:14.524Z INFO Modem port is closed
    trace-2019-10-23T14-49-46.112Z_devkit_ibasis_ok.bin
    2019-10-23T14:54:26.481Z INFO Application data folder: C:\Users\julien.le-guen\AppData\Roaming\nrfconnect\pc-nrfconnect-linkmonitor
    2019-10-23T14:54:26.723Z DEBUG App pc-nrfconnect-linkmonitor v1.1.1 official
    2019-10-23T14:54:26.723Z DEBUG App path: C:\Users\julien.le-guen\.nrfconnect-apps\node_modules\pc-nrfconnect-linkmonitor
    2019-10-23T14:54:26.723Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-10-23T14:54:26.723Z DEBUG nRFConnect path: C:\Users\julien.le-guen\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-10-23T14:54:26.723Z DEBUG HomeDir: C:\Users\julien.le-guen
    2019-10-23T14:54:26.723Z DEBUG TmpDir: C:\Users\JULIEN~1.LE-\AppData\Local\Temp
    2019-10-23T14:54:37.239Z INFO Modem port is opened
    2019-10-23T14:54:37.257Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:54:37.301Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-23T14:54:37.306Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.359Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-23T14:54:37.383Z DEBUG modem << +CGSN: "352656100458739"\x0D\x0A
    2019-10-23T14:54:37.389Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.397Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-23T14:54:37.442Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-23T14:54:37.447Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.462Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-23T14:54:37.493Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-23T14:54:37.500Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.508Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-23T14:54:37.543Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-23T14:54:37.551Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.554Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100458739
    2019-10-23T14:54:37.566Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-23T14:54:37.589Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-10-23T14:54:37.602Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.637Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-23T14:54:37.668Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-10-23T14:54:37.671Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.703Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-23T14:54:37.716Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-10-23T14:54:37.768Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.840Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-23T14:54:37.870Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-10-23T14:54:37.873Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.883Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-23T14:54:37.907Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-10-23T14:54:37.913Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.937Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-23T14:54:37.958Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:37.974Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-23T14:54:38.003Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.010Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-23T14:54:38.041Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2019-10-23T14:54:38.054Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.105Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-23T14:54:38.155Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.161Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-23T14:54:38.180Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-10-23T14:54:38.195Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.223Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-23T14:54:38.243Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.255Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-23T14:54:38.285Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-23T14:54:38.322Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.407Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-23T14:54:38.437Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-23T14:54:38.440Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.470Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-23T14:54:38.498Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-23T14:54:38.501Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.533Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-23T14:54:38.552Z DEBUG modem << 204080813510411\x0D\x0A
    2019-10-23T14:54:38.556Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:38.558Z INFO IMSIdentity: 204080813510411
    2019-10-23T14:54:39.537Z DEBUG modem << ***** Booting Zephyr OS v1.14.99-ncs2 *****\x0D\x0A
    2019-10-23T14:54:39.855Z DEBUG modem << Flash region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-23T14:54:39.858Z DEBUG modem << 00 0x00000 0x08000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.861Z DEBUG modem << 01 0x08000 0x10000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.865Z DEBUG modem << 02 0x10000 0x18000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.867Z DEBUG modem << 03 0x18000 0x20000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.868Z DEBUG modem << 04 0x20000 0x28000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.870Z DEBUG modem << 05 0x28000 0x30000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.871Z DEBUG modem << 06 0x30000 0x38000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.872Z DEBUG modem << 07 0x38000 0x40000 \x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.873Z DEBUG modem << 08 0x40000 0x48000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.879Z DEBUG modem << 09 0x48000 0x50000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.882Z DEBUG modem << 10 0x50000 0x58000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.884Z DEBUG modem << 11 0x58000 0x60000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.886Z DEBUG modem << 12 0x60000 0x68000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.887Z DEBUG modem << 13 0x68000 0x70000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.889Z DEBUG modem << 14 0x70000 0x78000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.890Z DEBUG modem << 15 0x78000 0x80000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.891Z DEBUG modem << 16 0x80000 0x88000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.898Z DEBUG modem << 17 0x88000 0x90000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.900Z DEBUG modem << 18 0x90000 0x98000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.902Z DEBUG modem << 19 0x98000 0xa0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.903Z DEBUG modem << 20 0xa0000 0xa8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.906Z DEBUG modem << 21 0xa8000 0xb0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.907Z DEBUG modem << 22 0xb0000 0xb8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.909Z DEBUG modem << 23 0xb8000 0xc0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.912Z DEBUG modem << 24 0xc0000 0xc8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.916Z DEBUG modem << 25 0xc8000 0xd0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.918Z DEBUG modem << 26 0xd0000 0xd8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.921Z DEBUG modem << 27 0xd8000 0xe0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.923Z DEBUG modem << 28 0xe0000 0xe8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.926Z DEBUG modem << 29 0xe8000 0xf0000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.931Z DEBUG modem << 30 0xf0000 0xf8000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.933Z DEBUG modem << 31 0xf8000 0x100000 \x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.940Z DEBUG modem << Non-secure callable region 0 placed in flash region 0 with size 32.\x0D\x0A\x0D\x0A\x0D\x0A
    2019-10-23T14:54:39.943Z DEBUG modem << SRAM region\x09\x09Domain\x09\x09Permissions\x0D\x0A
    2019-10-23T14:54:39.950Z DEBUG modem << 00 0x00000 0x02000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.953Z DEBUG modem << 01 0x02000 0x04000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.955Z DEBUG modem << 02 0x04000 0x06000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.957Z DEBUG modem << 03 0x06000 0x08000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.959Z DEBUG modem << 04 0x08000 0x0a000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.964Z DEBUG modem << 05 0x0a000 0x0c000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.967Z DEBUG modem << 06 0x0c000 0x0e000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.970Z DEBUG modem << 07 0x0e000 0x10000\x09Secure\x09\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.972Z DEBUG modem << 08 0x10000 0x12000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.973Z DEBUG modem << 09 0x12000 0x14000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.974Z DEBUG modem << 10 0x14000 0x16000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.978Z DEBUG modem << 11 0x16000 0x18000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.979Z DEBUG modem << 12 0x18000 0x1a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.980Z DEBUG modem << 13 0x1a000 0x1c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.983Z DEBUG modem << 14 0x1c000 0x1e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.985Z DEBUG modem << 15 0x1e000 0x20000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.986Z DEBUG modem << 16 0x20000 0x22000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.988Z DEBUG modem << 17 0x22000 0x24000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.990Z DEBUG modem << 18 0x24000 0x26000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.991Z DEBUG modem << 19 0x26000 0x28000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.992Z DEBUG modem << 20 0x28000 0x2a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.996Z DEBUG modem << 21 0x2a000 0x2c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.998Z DEBUG modem << 22 0x2c000 0x2e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.998Z DEBUG modem << 23 0x2e000 0x30000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:39.999Z DEBUG modem << 24 0x30000 0x32000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.000Z DEBUG modem << 25 0x32000 0x34000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.001Z DEBUG modem << 26 0x34000 0x36000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.002Z DEBUG modem << 27 0x36000 0x38000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.002Z DEBUG modem << 28 0x38000 0x3a000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.005Z DEBUG modem << 29 0x3a000 0x3c000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.006Z DEBUG modem << 30 0x3c000 0x3e000\x09Non-Secure\x09rwxl\x0D\x0A
    2019-10-23T14:54:40.007Z DEBUG modem << 31 0x3e000 0x40000\x09Non-Secure\x09rwxl\x0D\x0A\x0D\x0A
    2019-10-23T14:54:40.008Z DEBUG modem << Peripheral\x09\x09Domain\x09\x09Status\x0D\x0A
    2019-10-23T14:54:40.009Z DEBUG modem << 00 NRF_P0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.011Z DEBUG modem << 01 NRF_CLOCK\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.012Z DEBUG modem << 02 NRF_RTC1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.013Z DEBUG modem << 03 NRF_NVMC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.016Z DEBUG modem << 04 NRF_UARTE1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.017Z DEBUG modem << 05 NRF_UARTE2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.019Z DEBUG modem << 06 NRF_TWIM2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.021Z DEBUG modem << 07 NRF_SPIM3\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.022Z DEBUG modem << 08 NRF_TIMER0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.024Z DEBUG modem << 09 NRF_TIMER1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.025Z DEBUG modem << 10 NRF_TIMER2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.027Z DEBUG modem << 11 NRF_SAADC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.031Z DEBUG modem << 12 NRF_PWM0\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.032Z DEBUG modem << 13 NRF_PWM1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.033Z DEBUG modem << 14 NRF_PWM2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.036Z DEBUG modem << 15 NRF_PWM3\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.037Z DEBUG modem << 16 NRF_IPC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.039Z DEBUG modem << 17 NRF_VMC\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.040Z DEBUG modem << 18 NRF_FPU\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.041Z DEBUG modem << 19 NRF_EGU1\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.043Z DEBUG modem << 20 NRF_EGU2\x09\x09Non-Secure\x09OK\x0D\x0A
    2019-10-23T14:54:40.045Z DEBUG modem << 21 NRF_GPIOTE1\x09\x09Non-Secure\x09OK\x0D\x0A\x0D\x0A
    2019-10-23T14:54:40.047Z DEBUG modem << SPM: NS image at 0x40000\x0D\x0A
    2019-10-23T14:54:40.049Z DEBUG modem << SPM: NS MSP at 0x20023b90\x0D\x0A
    2019-10-23T14:54:40.050Z DEBUG modem << SPM: NS reset vector at 0x4261d\x0D\x0A
    2019-10-23T14:54:40.051Z DEBUG modem << SPM: prepare to jump to Non-Secure image.\x0D\x0A
    2019-10-23T14:54:40.213Z DEBUG modem << ***** Booting Zephyr OS v1.14.99-ncs2 *****\x0D\x0A
    2019-10-23T14:54:40.218Z DEBUG modem << The AT host sample started\x0D\x0A
    2019-10-23T14:54:50.113Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:54:50.133Z DEBUG modem << +CFUN: 4\x0D\x0A
    2019-10-23T14:54:50.149Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:50.154Z DEBUG modem >> AT+CFUN=1\x0D\x0A
    2019-10-23T14:54:50.229Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.486Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:54:52.502Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-23T14:54:52.529Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.536Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-23T14:54:52.563Z DEBUG modem << +CGSN: "352656100458739"\x0D\x0A
    2019-10-23T14:54:52.565Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.569Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-23T14:54:52.596Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-23T14:54:52.598Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.602Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-23T14:54:52.627Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-23T14:54:52.631Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.645Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-23T14:54:52.671Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-23T14:54:52.679Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.682Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100458739
    2019-10-23T14:54:52.703Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-23T14:54:52.737Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-10-23T14:54:52.741Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.774Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-23T14:54:52.801Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-10-23T14:54:52.803Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.828Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-23T14:54:52.849Z DEBUG modem << +CMEE: 0\x0D\x0A
    2019-10-23T14:54:52.851Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.870Z DEBUG modem >> AT+CMEE=1\x0D\x0A
    2019-10-23T14:54:52.898Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.902Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-23T14:54:52.929Z DEBUG modem << +CNEC: 0\x0D\x0A
    2019-10-23T14:54:52.931Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.948Z DEBUG modem >> AT+CNEC=24\x0D\x0A
    2019-10-23T14:54:52.962Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:52.980Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-23T14:54:53.007Z DEBUG modem << +CGEREP: 0,0\x0D\x0A
    2019-10-23T14:54:53.010Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.036Z DEBUG modem >> AT+CGDCONT?\x0D\x0A
    2019-10-23T14:54:53.060Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.067Z DEBUG modem >> AT+CGACT?\x0D\x0A
    2019-10-23T14:54:53.092Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.114Z DEBUG modem >> AT+CGEREP=1\x0D\x0A
    2019-10-23T14:54:53.136Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.145Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-23T14:54:53.169Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.190Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-23T14:54:53.211Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.243Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-23T14:54:53.265Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2019-10-23T14:54:53.269Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.296Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-23T14:54:53.318Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.336Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-23T14:54:53.363Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-10-23T14:54:53.365Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.379Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-23T14:54:53.397Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.418Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-23T14:54:53.448Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-23T14:54:53.450Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.485Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-23T14:54:53.505Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-23T14:54:53.510Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.547Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-23T14:54:53.568Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-23T14:54:53.570Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.597Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-23T14:54:53.619Z DEBUG modem << 204080813510411\x0D\x0A
    2019-10-23T14:54:53.630Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:53.633Z INFO IMSIdentity: 204080813510411
    2019-10-23T14:54:58.428Z DEBUG modem >> AT+CFUN?\x0D\x0A
    2019-10-23T14:54:58.451Z DEBUG modem << +CFUN: 1\x0D\x0A
    2019-10-23T14:54:58.463Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.484Z DEBUG modem >> AT+CGSN=1\x0D\x0A
    2019-10-23T14:54:58.506Z DEBUG modem << +CGSN: "352656100458739"\x0D\x0A
    2019-10-23T14:54:58.513Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.539Z DEBUG modem >> AT+CGMI\x0D\x0A
    2019-10-23T14:54:58.569Z DEBUG modem << Nordic Semiconductor ASA\x0D\x0A
    2019-10-23T14:54:58.572Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.595Z DEBUG modem >> AT+CGMM\x0D\x0A
    2019-10-23T14:54:58.633Z DEBUG modem << nRF9160-SICA\x0D\x0A
    2019-10-23T14:54:58.636Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.643Z DEBUG modem >> AT+CGMR\x0D\x0A
    2019-10-23T14:54:58.665Z DEBUG modem << mfw_nrf9160_1.0.1\x0D\x0A
    2019-10-23T14:54:58.668Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.670Z INFO Nordic Semiconductor ASA nRF9160-SICA [mfw_nrf9160_1.0.1] SerNr: 352656100458739
    2019-10-23T14:54:58.693Z DEBUG modem >> AT+CEMODE?\x0D\x0A
    2019-10-23T14:54:58.719Z DEBUG modem << +CEMODE: 2\x0D\x0A
    2019-10-23T14:54:58.725Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.746Z DEBUG modem >> AT%XCBAND=?\x0D\x0A
    2019-10-23T14:54:58.765Z DEBUG modem << %XCBAND: (1,2,3,4,5,8,12,13,14,17,18,19,20,25,26,28,66)\x0D\x0A
    2019-10-23T14:54:58.771Z DEBUG modem << OK\x0D\x0A
    2019-10-23T14:54:58.808Z DEBUG modem >> AT+CMEE?\x0D\x0A
    2019-10-23T14:54:58.829Z DEBUG modem << +CMEE: 1\x0D\x0A
    2019-10-23T14:54:58.830Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.834Z DEBUG modem >> AT+CNEC?\x0D\x0A
    2019-10-23T14:54:58.859Z DEBUG modem << +CNEC: 24\x0D\x0A
    2019-10-23T14:54:58.860Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.883Z DEBUG modem >> AT+CGEREP?\x0D\x0A
    2019-10-23T14:54:58.915Z DEBUG modem << +CGEREP: 1,0\x0D\x0A
    2019-10-23T14:54:58.918Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.944Z DEBUG modem >> AT+CIND=1,1,1\x0D\x0A
    2019-10-23T14:54:58.964Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:58.994Z DEBUG modem >> AT+CEREG=2\x0D\x0A
    2019-10-23T14:54:59.027Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.030Z DEBUG modem >> AT+CEREG?\x0D\x0A
    2019-10-23T14:54:59.058Z DEBUG modem << +CEREG: 2,4,"FFFE","FFFFFFFF",7\x0D\x0A
    2019-10-23T14:54:59.060Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.092Z DEBUG modem >> AT%CESQ=1\x0D\x0A
    2019-10-23T14:54:59.119Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.148Z DEBUG modem >> AT+CESQ\x0D\x0A
    2019-10-23T14:54:59.184Z DEBUG modem << +CESQ: 99,99,255,255,255,255\x0D\x0A
    2019-10-23T14:54:59.186Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.230Z DEBUG modem >> AT%XSIM=1\x0D\x0A
    2019-10-23T14:54:59.260Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.292Z DEBUG modem >> AT%XSIM?\x0D\x0A
    2019-10-23T14:54:59.332Z DEBUG modem << %XSIM: 1\x0D\x0A
    2019-10-23T14:54:59.333Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.370Z DEBUG modem >> AT+CPIN?\x0D\x0A
    2019-10-23T14:54:59.411Z DEBUG modem << +CPIN: READY\x0D\x0A
    2019-10-23T14:54:59.416Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.459Z DEBUG modem >> AT+CPINR="SIM PIN"\x0D\x0A
    2019-10-23T14:54:59.492Z DEBUG modem << +CPINR: "SIM PIN",3\x0D\x0A
    2019-10-23T14:54:59.493Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.528Z DEBUG modem >> AT+CIMI\x0D\x0A
    2019-10-23T14:54:59.549Z DEBUG modem << 204080813510411\x0D\x0A
    2019-10-23T14:54:59.550Z DEBUG modem << OK\x0D\x0A\x00
    2019-10-23T14:54:59.556Z INFO IMSIdentity: 204080813510411
    2019-10-23T14:55:03.431Z INFO Modem port is closed
    trace-2019-10-23T14-54-46.464Z_custom_ibasis_fail.bin
    I finally figured it out, somehow the MAGPIO table got flushed and the RF switches on the board were not properly configured... Well that will teach me not to rely too much on the non-volatile storage :)
    Thank you for the help!
