Linking Error (_impure_ptr, __memcpy_chk, ) in Segger Studio
I try to use the opus codec on an 52840-DK. The Build and Flash with ARMGCC woks fine (with gcc-arm-none-eabi-8-2019-q3-update) but I'd like to use the debugger from the Segger Studio. When I build the code inside Segger I got these failures.
  Generating linker script 'i2s_pca10056.ld'
  Linking i2s_pca10056.elf
    ../../../../../../external/opus/lib/libopus.a(celt.o): in function `celt_fatal':
    undefined reference to `_impure_ptr'
    ../../../../../../external/opus/lib/libopus.a(bands.o): in function `quant_all_bands':
    undefined reference to `__memcpy_chk'
    ../../../../../../external/opus/lib/libopus.a(PLC.o): in function `silk_PLC_conceal':
    ../../../../../../external/opus/lib/libopus.a(decode_core.o): in function `silk_decode_core':
Build failed
I found it could be related to the newlib-nano or stdlib. Which lib and where can I change it in Segger Studio or .emProject?
    Generally, Embedded Studio offers the user to use any standard library they want. First, disable the use of Embedded Studio standard libraries in project options under Library->Include Standard Libraries->No
    To add your library go to project options Linker->Additional Input Files and add your newlib directory there.
    Now try to rebuild your project and you should be good to go.
    From this post.
    -Amanda H.
