RT,Nrf52810's Timer input capture, can I use DMA transfer?I want to save some time, see the manual, input capture is not possible to use DMA transfer
You can use PPI to trigger the TIMER task TASKS_CAPTURE[n]. When this CAPTURE[n] task is triggered, the Counter value is copied to the CC[n] register. So with PPI you can e.g. connected a GPIOTE event to trigger the TIMER CAPTURE task.
HI
But is it possible to get the CC register values copied automatically to memory by DMA, without the processor doing that in a ISR?
No
I am facing a similar problem. Two sensors are triggering with data_ready pins and a timer value is captured upon the event. But the value can be stored only in RAM if I have a context switch. But this depends on the processor usage. Therefore, it can be that one sensor triggers a capture event, but the interrupt routine is delayed due to softdevice processing etc. and in the meantime the other sensor triggers a more recent capture. In this case the timing is screwed.
I've tried to used another capture channel of the same timer but somehow the NRF_TIMER_TASK_CAPTURE4 of timer4 is permanent at the same value. But I have to admit that I am not sure if the event is correctly configured since the code in the header is always greyed out . And I do not know where TIMER_INTENSET_COMPARE4_Msk is defined.
/** @brief Timer tasks. */
typedef enum
NRF_TIMER_TASK_START = offsetof(NRF_TIMER_Type, TASKS_START), ///< Task for starting the timer.
NRF_TIMER_TASK_STOP = offsetof(NRF_TIMER_Type, TASKS_STOP), ///< Task for stopping the timer.
NRF_TIMER_TASK_COUNT = offsetof(NRF_TIMER_Type, TASKS_COUNT), ///< Task for incrementing the timer (in counter mode).
NRF_TIMER_TASK_CLEAR = offsetof(NRF_TIMER_Type, TASKS_CLEAR), ///< Task for resetting the timer value.
NRF_TIMER_TASK_SHUTDOWN = offsetof(NRF_TIMER_Type, TASKS_SHUTDOWN), ///< Task for powering off the timer.
NRF_TIMER_TASK_CAPTURE0 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[0]), ///< Task for capturing the timer value on channel 0.
NRF_TIMER_TASK_CAPTURE1 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[1]), ///< Task for capturing the timer value on channel 1.
NRF_TIMER_TASK_CAPTURE2 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[2]), ///< Task for capturing the timer value on channel 2.
NRF_TIMER_TASK_CAPTURE3 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[3]), ///< Task for capturing the timer value on channel 3.
#if defined(TIMER_INTENSET_COMPARE4_Msk) || defined(__NRFX_DOXYGEN__)
NRF_TIMER_TASK_CAPTURE4 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[4]), ///< Task for capturing the timer value on channel 4.
#if defined(TIMER_INTENSET_COMPARE5_Msk) || defined(__NRFX_DOXYGEN__)
NRF_TIMER_TASK_CAPTURE5 = offsetof(NRF_TIMER_Type, TASKS_CAPTURE[5]), ///< Task for capturing the timer value on channel 5.
} nrf_timer_task_t;Hi,
Constantin said:I've tried to used another capture channel of the same timer but somehow the NRF_TIMER_TASK_CAPTURE4 of timer4 is permanent at the same value. But I have to admit that I am not sure if the event is correctly configured since the code in the header is always greyed out . And I do not know where TIMER_INTENSET_COMPARE4_Msk is defined.
Please make a new ticket for this issue.
