Hello team Nordic,
Example ble_app_rscs_c is working well with my pca10056, im using it to scan for advertising reports. To do the same with pca10059, im trying to merge with usbd_cdc and send the adv data via virtual usb port, since it doesnt support UART.
I just included the files and headers and some piece of code of the ble_app_rscs_c and the softdevice into usbd_cdc_acm, so i could use ble funcionalities. When compiling i saw some libraries missing and was just adding them... But got at a point that i cant understand the errors, apparently in the output files. Please see print of SES output erros.
I dont even know if i am doing this the right way, by adding the libraries manually. It would help if there is an easier way, or a correct way to.
Any help is appreciated! Thanks.
* Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "ble_dis_c.h"
#include "ble_rscs_c.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
#define APP_BLE_CONN_CFG_TAG 1 /**< Tag that identifies the BLE configuration of the SoftDevice. */
#define APP_BLE_OBSERVER_PRIO 3 /**< BLE observer priority of the application. There is no need to modify this value. */
#define APP_SOC_OBSERVER_PRIO 1 /**< SoC observer priority of the application. There is no need to modify this value. */
#define SCAN_INTERVAL 0x0320 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0320 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning Module instance. */
static bool m_memory_access_in_progress; /**< Flag to keep track of ongoing operations on persistent memory. */
static ble_gap_scan_params_t m_scan_param = /**< Scan parameters requested for scanning and connection. */
.active = 0x00,
.interval = SCAN_INTERVAL,
.window = SCAN_WINDOW,
.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
.timeout = SCAN_DURATION,
// .scan_phys = BLE_GAP_PHY_CODED, // Choose only one of the following scan_phys
.scan_phys = BLE_GAP_PHY_1MBPS,
// .scan_phys = BLE_GAP_PHY_2MBPS,
.extended = 1,
static void scan_start(void);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// uint8_t idx = 0;
// unsigned char mac[6];
int8_t rssi;
case BLE_GAP_EVT_ADV_REPORT:
NRF_LOG_RAW_INFO("Device: %02x:%02x:%02x:%02x:%02x:%02x ", p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[0],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[1],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[2],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[3],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[4],
p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[5]);
rssi = p_ble_evt->evt.gap_evt.params.adv_report.rssi;
NRF_LOG_RAW_INFO("RSSI:%d \r\n", rssi);
* @brief SoftDevice SoC event handler.
* @param[in] evt_id SoC event.
* @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
switch (evt_id)
case NRF_EVT_FLASH_OPERATION_SUCCESS:
/* fall through */
case NRF_EVT_FLASH_OPERATION_ERROR:
if (m_memory_access_in_progress)
m_memory_access_in_progress = false;
scan_start();
// No implementation needed.
ret_code_t err_code;
uint32_t ram_start = 0;
// Enable BLE stack.
// Register handlers for BLE and SoC events.
NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("Scan timed out.");
scan_start();
} break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
init_scan.p_scan_param = &m_scan_param;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
/**@brief Function for starting scanning.
// If there is any pending write to flash, defer scanning until it completes.
if (nrf_fstorage_is_busy(NULL))
m_memory_access_in_progress = true;
return;
err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing the timer. */
static void timer_init(void)
* @details Handles any pending log operations, then sleeps until the next event occurs.
nrf_pwr_mgmt_run();
* @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
"uart_cli:~$ ",
&m_cli_uart_transport.transport,
'\r',
4);
/**@file
* @defgroup usbd_cdc_acm_example main.c
* @ingroup usbd_cdc_acm_example
* @brief USBD CDC ACM example
#define LED_USB_RESUME (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX (BSP_BOARD_LED_3)
#define BTN_CDC_DATA_SEND 0
#define BTN_CDC_NOTIFY_SEND 1
#define BTN_CDC_DATA_KEY_RELEASE (bsp_event_t)(BSP_EVENT_KEY_LAST + 1)
* @brief Enable power USB detection
* Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE 0
#define CDC_ACM_COMM_EPIN NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE 1
#define CDC_ACM_DATA_EPIN NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT NRF_DRV_USBD_EPOUT1
* @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
cdc_acm_user_ev_handler,
CDC_ACM_COMM_INTERFACE,
CDC_ACM_DATA_INTERFACE,
CDC_ACM_COMM_EPIN,
CDC_ACM_DATA_EPIN,
CDC_ACM_DATA_EPOUT,
APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
* @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
switch (event)
case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
bsp_board_led_on(LED_CDC_ACM_OPEN);
/*Setup first transfer*/
ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
m_rx_buffer,
READ_SIZE);
UNUSED_VARIABLE(ret);
case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
bsp_board_led_off(LED_CDC_ACM_OPEN);
case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
bsp_board_led_invert(LED_CDC_ACM_TX);
case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
ret_code_t ret;
NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
do
/*Get amount of data transfered*/
size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
/* Fetch data until internal buffer is empty */
m_rx_buffer,
READ_SIZE);
} while (ret == NRF_SUCCESS);
bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
switch (event)
case APP_USBD_EVT_DRV_SUSPEND:
bsp_board_led_off(LED_USB_RESUME);
case APP_USBD_EVT_DRV_RESUME:
bsp_board_led_on(LED_USB_RESUME);
case APP_USBD_EVT_STARTED:
case APP_USBD_EVT_STOPPED:
app_usbd_disable();
bsp_board_leds_off();
case APP_USBD_EVT_POWER_DETECTED:
NRF_LOG_INFO("USB power detected");
if (!nrf_drv_usbd_is_enabled())
app_usbd_enable();
case APP_USBD_EVT_POWER_REMOVED:
NRF_LOG_INFO("USB power removed");
app_usbd_stop();
case APP_USBD_EVT_POWER_READY:
NRF_LOG_INFO("USB ready");
app_usbd_start();
static void bsp_event_callback(bsp_event_t ev)
ret_code_t ret;
switch ((unsigned int)ev)
case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_DATA_SEND):
m_send_flag = 1;
case BTN_CDC_DATA_KEY_RELEASE :
m_send_flag = 0;
case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_NOTIFY_SEND):
ret = app_usbd_cdc_acm_serial_state_notify(&m_app_cdc_acm,
APP_USBD_CDC_ACM_SERIAL_STATE_BREAK,
false);
return; // no implementation needed
static void init_bsp(void)
ret_code_t ret;
ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
APP_ERROR_CHECK(ret);
UNUSED_RETURN_VALUE(bsp_event_to_button_action_assign(BTN_CDC_DATA_SEND,
BSP_BUTTON_ACTION_RELEASE,
BTN_CDC_DATA_KEY_RELEASE));
/* Configure LEDs */
static void init_cli(void)
ret_code_t ret;
ret = bsp_cli_init(bsp_event_callback);
nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
uart_config.pseltxd = TX_PIN_NUMBER;
uart_config.pselrxd = RX_PIN_NUMBER;
uart_config.hwfc = NRF_UART_HWFC_DISABLED;
ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
ret = nrf_cli_start(&m_cli_uart);
ret_code_t ret;
static const app_usbd_config_t usbd_config = {
.ev_state_proc = usbd_user_ev_handler
ret = NRF_LOG_INIT(NULL);
ret = nrf_drv_clock_init();
while(!nrf_drv_clock_lfclk_is_running())
/* Just waiting */
ret = app_timer_init();
init_bsp();
init_cli();
timer_init();
power_management_init();
ble_stack_init();
scan_init();
scan_start();
app_usbd_serial_num_generate();
ret = app_usbd_init(&usbd_config);
NRF_LOG_INFO("USBD CDC ACM example started.");
app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
ret = app_usbd_class_append(class_cdc_acm);
if (USBD_POWER_DETECTION)
ret = app_usbd_power_events_enable();
NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
app_usbd_enable();
app_usbd_start();
while (true)
while (app_usbd_event_queue_process())
/* Nothing to do */
if(m_send_flag)
static int frame_counter;
size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
if (ret == NRF_SUCCESS)
++frame_counter;
nrf_cli_process(&m_cli_uart);
UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
/* Sleep CPU only if there was no interrupt since last loop processing */
__WFE();
