Error in Merging usbd_cdc_acm and ble_app_rscs_c
Hello team Nordic,
Example ble_app_rscs_c is working well with my pca10056, im using it to scan for advertising reports. To do the same with pca10059, im trying to merge with usbd_cdc and send the adv data via virtual usb port, since it doesnt support UART.
I just included the files and headers and some piece of code of the ble_app_rscs_c and the softdevice into usbd_cdc_acm, so i could use ble funcionalities. When compiling i saw some libraries missing and was just adding them... But got at a point that i cant understand the errors, apparently in the output files. Please see print of SES  output erros.
I dont even know if i am doing this the right way, by adding the libraries manually. It would help if there is an easier way, or a correct way to.
Any help is appreciated! Thanks.
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "ble_dis_c.h"
#include "ble_rscs_c.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
#define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that identifies the BLE configuration of the SoftDevice. */
#define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
#define APP_SOC_OBSERVER_PRIO       1                                   /**< SoC observer priority of the application. There is no need to modify this value. */
#define SCAN_INTERVAL               0x0320                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                 0x0320                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION           	0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
NRF_BLE_SCAN_DEF(m_scan);                                   /**< Scanning Module instance. */
static bool                  m_memory_access_in_progress;   /**< Flag to keep track of ongoing operations on persistent memory. */
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x00,
    .interval      = SCAN_INTERVAL,
    .window        = SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .timeout       = SCAN_DURATION,
//    .scan_phys     = BLE_GAP_PHY_CODED,                                 // Choose only one of the following scan_phys
    .scan_phys     = BLE_GAP_PHY_1MBPS,
//    .scan_phys     = BLE_GAP_PHY_2MBPS,
    .extended      = 1,
static void scan_start(void);
//    uint8_t  idx = 0;
//    unsigned char mac[6];
    int8_t rssi;
          case BLE_GAP_EVT_ADV_REPORT:
          NRF_LOG_RAW_INFO("Device: %02x:%02x:%02x:%02x:%02x:%02x  ", p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[0],
        p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[1],
        p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[2],
        p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[3],
        p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[4],
        p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[5]);
               rssi = p_ble_evt->evt.gap_evt.params.adv_report.rssi;
               NRF_LOG_RAW_INFO("RSSI:%d \r\n", rssi);
 * @brief SoftDevice SoC event handler.
 * @param[in] evt_id    SoC event.
 * @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
    switch (evt_id)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
        /* fall through */
        case NRF_EVT_FLASH_OPERATION_ERROR:
            if (m_memory_access_in_progress)
                m_memory_access_in_progress = false;
                scan_start();
            // No implementation needed.
    ret_code_t err_code;
    uint32_t ram_start = 0;
    // Enable BLE stack.
    // Register handlers for BLE and SoC events.
    NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
            NRF_LOG_INFO("Scan timed out.");
            scan_start();
        } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = false;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    init_scan.p_scan_param     = &m_scan_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
/**@brief Function for starting scanning.
    // If there is any pending write to flash, defer scanning until it completes.
    if (nrf_fstorage_is_busy(NULL))
        m_memory_access_in_progress = true;
        return;
    err_code = nrf_ble_scan_start(&m_scan);
/**@brief Function for initializing logging. */
static void log_init(void)
/**@brief Function for initializing the timer. */
static void timer_init(void)
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
 * @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
            "uart_cli:~$ ",
            &m_cli_uart_transport.transport,
            '\r',
            4);
/**@file
 * @defgroup usbd_cdc_acm_example main.c
 * @ingroup usbd_cdc_acm_example
 * @brief USBD CDC ACM example
#define LED_USB_RESUME      (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN    (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX      (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX      (BSP_BOARD_LED_3)
#define BTN_CDC_DATA_SEND       0
#define BTN_CDC_NOTIFY_SEND     1
#define BTN_CDC_DATA_KEY_RELEASE        (bsp_event_t)(BSP_EVENT_KEY_LAST + 1)
 * @brief Enable power USB detection
 * Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
 * @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
 * @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            bsp_board_led_on(LED_CDC_ACM_OPEN);
            /*Setup first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   m_rx_buffer,
                                                   READ_SIZE);
            UNUSED_VARIABLE(ret);
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            bsp_board_led_off(LED_CDC_ACM_OPEN);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            bsp_board_led_invert(LED_CDC_ACM_TX);
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
            NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
            do
                /*Get amount of data transfered*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
                /* Fetch data until internal buffer is empty */
                                            m_rx_buffer,
                                            READ_SIZE);
            } while (ret == NRF_SUCCESS);
            bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
            bsp_board_led_off(LED_USB_RESUME);
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_RESUME);
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
            bsp_board_leds_off();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void bsp_event_callback(bsp_event_t ev)
    ret_code_t ret;
    switch ((unsigned int)ev)
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_DATA_SEND):
            m_send_flag = 1;
        case BTN_CDC_DATA_KEY_RELEASE :
            m_send_flag = 0;
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_NOTIFY_SEND):
            ret = app_usbd_cdc_acm_serial_state_notify(&m_app_cdc_acm,
                                                       APP_USBD_CDC_ACM_SERIAL_STATE_BREAK,
                                                       false);
            return; // no implementation needed
static void init_bsp(void)
    ret_code_t ret;
    ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
    APP_ERROR_CHECK(ret);
    UNUSED_RETURN_VALUE(bsp_event_to_button_action_assign(BTN_CDC_DATA_SEND,
                                                          BSP_BUTTON_ACTION_RELEASE,
                                                          BTN_CDC_DATA_KEY_RELEASE));
    /* Configure LEDs */
static void init_cli(void)
    ret_code_t ret;
    ret = bsp_cli_init(bsp_event_callback);
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    ret = nrf_cli_start(&m_cli_uart);
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    ret = NRF_LOG_INIT(NULL);
    ret = nrf_drv_clock_init();
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    ret = app_timer_init();
    init_bsp();
    init_cli();
    timer_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    scan_start();
    app_usbd_serial_num_generate();
    ret = app_usbd_init(&usbd_config);
    NRF_LOG_INFO("USBD CDC ACM example started.");
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    while (true)
        while (app_usbd_event_queue_process())
            /* Nothing to do */
        if(m_send_flag)
            static int  frame_counter;
            size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
            ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
            if (ret == NRF_SUCCESS)
                ++frame_counter;
        nrf_cli_process(&m_cli_uart);
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        /* Sleep CPU only if there was no interrupt since last loop processing */
        __WFE();
  • Hi.
    You have to take a look at the flash_placement.xml file for a pca10059 project if you wish to merge a pca10056 project with a pca10059 project.
    Above you can see all the dongle project in the SDK, choose for example an peripheral project.
    Also, you should take a look at this tutorial on how to program the nRF52 Dongle.
    Andreas
  • Hi
    Thanks for your reply. I already modified the udbd cdc example to pca10059. I did it by the Linker preferences in options panel. And it workes well. Im including the BLE files and dependencies of the ble_app_rscs_c into the working pca10059 project.
    Could the flash placement still be the problem?
    See my flash placement file below.
    Thanks!!
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data"  inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs"  inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
      </MemorySegment>
      <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)">
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
    </Root>
  • Hi.
    Just looking at the picture attached I can see that atleast these lines are missing:
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
    Andreas
  • Thank you .
    The observers lines were missing in the flash_placement file. I could compile the application after adding them and others that i found when comparing the flash_placement files from both examples.
    But even after compiled succesfully, i cant run the application. Im testing it using pca10056, and got a fatal error when running the  ble_stack_init();
    There are key points that i must observe inside this function when porting from pca10056 to pca10059?
    It seems that all the dependecies were included into the project, since its compiles succesfully now..
    I got the following output from Hard Fault handler:
    HARD FAULT at 0x000143D4
      R0:  0x2003FFA0  R1:  0x00002605  R2:  0x20000B60  R3:  0x2003FFA0
      R12: 0x20001094  LR:  0x000144E7  PSR: 0x01000000
  • Hi.
    The pin configuration is different, other then that it should not be anything.
    It could be difficult to debug a hardfault.
    Take a look at this page on StackOverflow.
    To quick summarize:
    You have to find the stack pointer (SP) value at r13, as you can see that that is the location of the stack pointer in Cortex M4:
    You then have to add 0x18 to the stack pointer value, and this will give you the program counter (PC) value that cause the error.
    Andreas
