Aside from the connection interval, I'd like to know if the 2Mhz phy is enable along with Data Packet Length Extension and Connection Event Length Extension.
Is there a way for the app to get this information?
When the PHY is updated you will get a event, BLE_GAP_EVT_PHY_UPDATE, with the PHY that is used. See this and this link.
This is handled by the GATT Module. You can read it with the function nrf_ble_gatt_data_length_get().
This is something that is either enabled or disabled. When enabled the SoftDevice will dynamically extend the connection event when possible.
If sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt) returned NRF_SUCCESS, it's enabled. You cannot use sd_ble_opt_get for this option. See this link. Snippet on how to enable:
ret_code_t err_code;
ble_opt_t opt;
memset(&opt, 0x00, sizeof(opt));
opt.common_opt.conn_evt_ext.enable = 1;
err_code = sd_ble_opt_set(BLE_COMMON_OPT_CONN_EVT_EXT, &opt);
