Too many method calls in serial interface (or any other) callback causes strange behavior in nRF Mesh SDK
I'm using SDK v3.2 and I'm extending the lighting example. I'm developing an extension to the provisioner, to inform a back-end about the configuration of the subnet it is part of. For that, I use the existing serial interface handler. However, I also want to know the Network ID derived from the NetKey. For that, I use the Application serial command. Within that command, I define a more specific opcode, which leads to the underlying code:
static void serial_interface_cb(const uint8_t* p_data, uint32_t length)
    NRF_MESH_ASSERT(length > 0);
    switch(p_data[0])
        case BLUESS_OPCODE_NETWORK_ID_DISCOVERY_SERIAL_COMMAND:
            ; // Empty statement
            mesh_key_index_t p_key_list[DSM_SUBNET_MAX_LIMIT];
            uint32_t p_count = DSM_SUBNET_MAX_LIMIT;
            dsm_subnet_get_all(p_key_list, &p_count);
            uint32_t length = sizeof(bluess_serial_opcode_t) + p_count * NRF_MESH_NETID_SIZE;
            uint32_t index = 0;
            uint8_t p_serial[length];
            p_serial[index] = BLUESS_OPCODE_NETWORK_ID_DISCOVERY_SERIAL_EVENT;
            index += sizeof(bluess_serial_opcode_t);
            for(uint32_t i = 0 ; i < p_count ; i++){
                nrf_mesh_beacon_secmat_t * p_secmat;
                uint8_t key = 0;
                uint32_t status = dsm_subnet_key_get(dsm_net_key_index_to_subnet_handle(p_key_list[i]), &key);
                if(status == NRF_SUCCESS){
                    status = nrf_mesh_keygen_beacon_secmat(&key, p_secmat);
                memcpy(&p_serial[index], &p_secmat->net_id[0], NRF_MESH_NETID_SIZE);
                index += NRF_MESH_NETID_SIZE;
            nrf_mesh_serial_tx(p_serial, length);
As the provisioner is only part of one subnet, p_count will become equal to 1. This is the case from the start of the for-loop. However, I notice that during the for-loop, suddenly p_count becomes much larger, causing the loop to run endlessly. When commenting out the whole code within the for-loop, the callback is completed as it should, without p_count changing in between. At first glance, it seems that to many method calls within a callback, causes issues... Is there any explanation for this?
Mathias
    There is absolutely no reason why p_count should change, as it is a variable local to the function and it is never assigned to anything else than it's initial value of (the constant) DSM_SUBNET_MAX_LIMIT. If you see it changing, there must be something with the debugging session (e.g. you are debugging a Release build, or otherwise optimized build that lacks debug info.)
    In general you should not do too much in a callback, as callbacks tend to be called from code running in higher interrupt priority (and so the callback function itself is also run in that higher interrupt priority.) Depending on the calling context, other parts of the stack may misbehave as a result. Also, there may be restrictions to what API calls can be called from interrupt context. In the nRF5 SDK for Mesh documentation, Interrupt priority levels are thoroughly documented.
    Terje
    PS: For readability of the code, I recommend that you rename the variable p_count, as there is a convention that the "p_" prefix indicates a pointer. E.g. the variable name "p_data" means "pointer to data".
  • There is absolutely no reason why p_count should change, as it is a variable local to the function and it is never assigned to anything else than it's initial value of (the constant) DSM_SUBNET_MAX_LIMIT..
    Why not? I call dsm_subnet_get_all(p_key_list, &p_count);, which will put the correct keys in the p_key_list and updates p_count to the correct amount of keys in that list, no?
    Okay, but where should I then do the necessary parsing, handling, etc. of received serial data in the callback? Should I save it in some kind of buffer, set a timer and then put a an if-statement in the global main while loop to handle the contents of that buffer? Is that the correct way? Or is there another, better way?
    Thanks for this tip! :)
    By "stack" in that context I was referring to the BT mesh stack, and not the call stack. (I should have specified.) But yes, each invocation of the function will get its own stack frame on the call stack, and so there should be no mangling of values there.
    An exception is if you have the local variable declared static within a function, in which case all invocations of that same function will use the same memory for the variable. Then the variable is not stored in the stack frame for the particular invocation of the function, but rather in the static part of memory (which is kept at a predetermined location throughout program execution.) But that is clearly not the case here.
    Another exception is if you take a pointer to the variable, but that should not be the case here either. (While you do pass the address of (e.g. pointer to) the variable to dsm_subnet_get_all(), that function only uses the pointer for returning the count. It does not store it for other parts of the mesh stack to mess with it.)
    I would be surprised if the key to solving this issue is not either in an error code returned from an API call, or the callback function lasting for too long.
    Terje
  • Hi Terje,
    Probably it'll be the callback function lasting for too long then.
    Could it be that when it lasts to long, other parts of the stack behave strangely and for some reason (part of) the heap gets cleared? That could be an explanation.
    Mathias
    Trouble is we don't use a heap, so the stack growing into the (non-existing) heap shouldn't happen. Also, the stack is shared between SoftDevice and application, so no colliding stacks... Not quite sure what happens on a stack overflow, though.
    I am more curious as to how you determined p_count changed. How did you read that / output it?
    Terje
  • Via logging over JLink, which I understand I should avoid in a callback...
    But I think you're right about a status not returning NRF_SUCCESS... If I change nrf_mesh_beacon_secmat_t * p_secmat; to nrf_mesh_beacon_secmat_t p_secmat = {0}; and status = nrf_mesh_keygen_beacon_secmat(&key, p_secmat); to status = nrf_mesh_keygen_beacon_secmat(&key, &p_secmat);, then it works. So I think it was because of NULL pointers.
    Anyway, learned a lot today, also about the fact that the board doesn't use a heap. Thanks!
    Of course! I see it as well now. Yes, that uninitialized pointer would definitely be an error. It is always important in C to be aware of where to allocate (and deallocate) memory, even if you only use the stack and static variables.
    By the way, it is perfectly possible to use a heap on the nRF SoCs, even though we tend not to use one in our SDKs.
    Terje
    Terje
