why the fs_sys_event_handler() can't be called--when use fstorage to write flash?
SDK11, NRF51822
#include "fstorage.h"
#include "section_vars.h"
#define NUM_PAGES 6
static uint8_t fs_callback_flag;
static void fs_evt_handler(fs_evt_t const * const evt, fs_ret_t result)
	if (result != FS_SUCCESS)
		//bsp_indication_set(BSP_INDICATE_FATAL_ERROR);
		NRF_LOG_PRINTF("    fstorage command successfully completed   \n\r");
		fs_callback_flag = 0;
FS_REGISTER_CFG(fs_config_t fs_config) =
	.callback  = fs_evt_handler, // Function for event callbacks.
	.num_pages = NUM_PAGES, 	 // Number of physical flash pages required.
	.priority  = 0xFE			 // Priority for flash usage.
void init_fstorage(void)
		fs_ret_t ret = fs_init();
		if (ret != FS_SUCCESS)
			NRF_LOG_PRINTF("FS init failed!\n");
			NRF_LOG_PRINTF("FS init ok!\n");
void feed_wdt(void)
	uint32_t err_code = sd_app_evt_wait();
void fstorage_test(void)
		static uint32_t data;
		uint32_t flash_data[4];
		fs_ret_t ret;
		// Erase one page (page 0).
		NRF_LOG_PRINTF("Erasing a flash page at address 0x%X\r\n", (uint32_t)fs_config.p_start_addr);
		fs_callback_flag = 1;
		ret = fs_erase(&fs_config, fs_config.p_start_addr, 1);
		while(fs_callback_flag == 1)  { feed_wdt(); }
		//ret = fs_erase(&fs_config, fs_config.p_start_addr+1024, 1);
		//while(fs_callback_flag == 1)  { power_manage(); }
		//Read the first 4 words of the page
		NRF_LOG_PRINTF("Data read from flash address 0x%X: ", (uint32_t)fs_config.p_start_addr);
		for(int i=0; i<4; i++)
			flash_data[i] = *(fs_config.p_start_addr + i);
			NRF_LOG_PRINTF("%X ", flash_data[i]);
		NRF_LOG_PRINTF("\r\n");
		data = 0xAAAAAAAA;
		NRF_LOG_PRINTF("Writing data 0x%X to address 0x%X\r\n", data, (uint32_t)fs_config.p_start_addr);
		ret = fs_store(&fs_config, fs_config.p_start_addr, &data, 1);      //Write data to memory address 0x0003F00. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
		while(fs_callback_flag == 1)  {feed_wdt(); }
		data = 0xBBBBBBBB;
		NRF_LOG_PRINTF("Writing data 0x%X to address 0x%X\r\n", data, (uint32_t)fs_config.p_start_addr + 4);
		ret = fs_store(&fs_config, fs_config.p_start_addr + 1, &data, 1);      //Write data to memory address 0x0003F000. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
		data = 0xCCCCCCCC;
		NRF_LOG_PRINTF("Writing data 0x%X to address 0x%X\r\n", data, (uint32_t)fs_config.p_start_addr + 8);
		ret = fs_store(&fs_config, fs_config.p_start_addr + 2, &data, 1);      //Write data to memory address 0x0003F000. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
		ret = fs_erase(&fs_config, fs_config.p_start_addr+0x100, 1);
		while(fs_callback_flag == 1)  { feed_wdt();}
		NRF_LOG_PRINTF("Data read from flash address 0x%X: ", (uint32_t)fs_config.p_start_addr+0x100);
				flash_data[i] = *(fs_config.p_start_addr +0x100+ i);
		data = 0xAAAAAAAA;
		NRF_LOG_PRINTF("Writing data 0x%X to address 0x%X\r\n", data, (uint32_t)fs_config.p_start_addr+0x100);
		ret = fs_store(&fs_config, fs_config.p_start_addr+0x100, &data, 1);      //Write data to memory address 0x0003F00. Check it with command: nrfjprog --memrd 0x0003F000 --n 16
				flash_data[i] = *(fs_config.p_start_addr+0x100 + i);
void sys_evt_dispatch(uint32_t sys_evt) //
	//pstorage_sys_event_handler(sys_evt);
    fs_sys_event_handler(sys_evt);
	ble_advertising_on_sys_evt(sys_evt);
    uint32_t err_code;
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize SoftDevice.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Subscribe for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
		// Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
void application_init(void)
    uint32_t err_code;
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    system_gpios_init();
    dx_ble_app_init();
    app_pwms_init();
    err_code = param_data_init();
    battery_check_init();
    button_check_init();
    wdt_init();
	init_fstorage();
	//fstorage_test(); //here run OK
    err_code = app_timer_create(&m_app_assist_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                app_assist_meas_timeout_handler);
    NRF_LOG_INIT();
	application_init();
    NRF_LOG_PRINTF("system start......\r\n");
    // Enter main loop.
    for (;;)
        power_manage();
if I use the fstorage_test at the applicaiton_init(void), then runs ok.
but on my product, I use a key to power the system, if I use the fstorage_test() in the   power on function(), then the fs_sys_event_handler() can't be called, code as following:
static void power_key_long_press_proc(void)
		NRF_LOG_PRINTF("power on\r\n");
		app_timer_start(m_app_assist_timer_id, APP_ASSIST_MEAS_INTERVAL, NULL);
		fstorage_test(); // if at here, the function run failed.
        get_toy_ble_mac(app_system_param.dec_addr);
        POWER_ON(POWER_MASK);
		ble_advertising_start(BLE_ADV_MODE_FAST);
static void bottun_event_handler(void * p_context)
    //some code here...
    if(long_press == 1)
        power_key_long_press_proc();
Can someone help me?
