Issue in flashing of zephyr OS over UART on Nordic nrf52840_pca10056 chip
I have nrf52840 on my custom board (Based on IMX6, Running Yocto linux) which is connected over UART.
I want to an OTA of zephyr OS on that chip over serial and for that i had already tried following things.
1) I have build smp_svr and flashed it to nrf52840 so that i can use 'mcumgr' command line tool for the flashing.
Referred https://docs.zephyrproject.org/1.14.0/samples/subsys/mgmt/mcumgr/smp_svr/README.html?highlight=build%20smp_svr to know how to use 'mcumgr'.
Now, when i use mcumgr to communicate 'hello' message over serial/UART, It shows error of connection timed out. (Also tried with -t switch, but no luck).
Command used are :
1) mcumgr conn add myserial02 type=serial connstring="dev=/dev/ttymxc0, peername='Zephyr'"
2) sudo mcumgr --conntype=serial --conn=myserial02 echo hello
3) sudo mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' image upload signed.bin //Tried this command for OTA over BLE.
- So it's not able to open the connection using mcumgr and not getting any reply.
Q: So what is the best way to do an OTA of Zephyr OS over UART or BLE (If over BLE, then do i need to integrate the hci example with the zephyr).
Mayank
  • Hi Mayank,
    We are not supporting nRF52 in NCS SDK. What you were following was the implementation from Zephyr. We have the same question on this case.  I would suggest you to join the mailing list and ask there.
    I played a bit with smp_svr and to enable UART you would need to modify the pro.conf of smp_svr with following:
    #CONFIG_MCUMGR_SMP_BT=y
    #CONFIG_MCUMGR_SMP_SHELL=y
    CONFIG_MCUMGR_SMP_UART=y
    CONFIG_NET_BUF_USER_DATA_SIZE=7
    After that smp_svr should response to the mcumgr via UART.
    I haven't managed to upload an image due to error 3, not sure what the problem here.
    Update: It was a signing problem. I signed the image and it works now.
    Can you share the steps for making communication between mcumgr and UART. Have you done this using hci0 or over UART?
    I have referred https://docs.zephyrproject.org/1.14.0/samples/subsys/mgmt/mcumgr/smp_svr/README.html?highlight=build%20smp_svr as mentioned in my question above and proj.conf file is same as you have suggested.
    So while Using ---> sudo mcumgr --conntype ble --connstring ctlr_name=hci0,peer_name='Zephyr' echo hello
    It shows hci0 not found. I did not have hci0 interface up because currently i'm running smp_svr on the flash. (I get hci0 up only when i flash zephyr hci_uart application).
    - Do i need to have hci_uart application for hci0 interface and smp_svr at the same time on board?
    - First i want to get to the point where i can get a simple 'hello' response from my BLE controller.
  • I'm not very familiar with Linux but for UART you should use:
    sudo mcumgr -t 60 --conntype serial --connstring='dev=/dev/ttyACM0,baud=115200' echo hello
    sudo mcumgr -t 60 --conntype serial --connstring='dev=/dev/ttyACM0,baud=115200' image upload signed.bin
    In my case on Windows I used:
    sudo mcumgr -t 60 --conntype serial --connstring='COM1,baud=115200' echo hello
    If your Linux device has BLE, hci0 can be used. But you need to make sure you can use the hci0 interface. Have a look at this guide: https://www.pcsuggest.com/linux-bluetooth-setup-hcitool-bluez/
    Again, we are not the best to ask about FOTA with NRF52, please check with Zephyr community.
