I have SAADC configured in burst mode with 4x oversampling and tACQ=5uSec.
What is the total conversion period?
tACQ + tCONV*4
or
(tACQ+tCONV)*4
In other words, is Sample and Hold performed only once or once for each conversion within the burst?
tACQ + tCONV*4
or
(tACQ+tCONV)*4
The last alternative would be the correct one, as the sample will be performed for each conversion. This can be tested by using a PPI to sets up a task that toggles a pin each time a conversion is done. The image shows that the pin is toggled 16 times when an oversample of x16 is used.
regards
Jared
static int16_t buffer[2];
static uint32_t event_count = 0;
NRF_SAADC->ENABLE = 1;
NRF_SAADC->OVERSAMPLE = 4;
NRF_SAADC->RESULT.PTR = (uint32_t) buffer;
NRF_SAADC->CH[0].PSELN = 0x0;
NRF_SAADC->CH[0].CONFIG = 0x01020000; // 10us, Burst mode.
NRF_SAADC->CH[0].PSELP = 0x1; // Sample 2 channels.
NRF_SAADC->RESULT.MAXCNT = 1;
NRF_SAADC->EVENTS_END = 0;
NRF_SAADC->EVENTS_CALIBRATEDONE = 0;
NRF_SAADC->EVENTS_DONE = 0;
#define PPI_CHANNEL (0)
#define PIN_GPIO (27)
// Configure PIN_GPIO as output
NRF_GPIO->DIRSET = (1UL << PIN_GPIO);
// Configure GPIOTE->TASKS_OUT[0] to toggle PIN_GPIO
NRF_GPIOTE->CONFIG[0] = (GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos) |
(GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos) |
(GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos) |
(PIN_GPIO << GPIOTE_CONFIG_PSEL_Pos);
// Configure PPI channel with connection between TIMER->EVENTS_COMPARE[0] and GPIOTE->TASKS_OUT[0]
NRF_PPI->CH[PPI_CHANNEL].EEP = (uint32_t)&NRF_SAADC->EVENTS_DONE;
NRF_PPI->CH[PPI_CHANNEL].TEP = (uint32_t)&NRF_GPIOTE->TASKS_OUT[0];
// Enable PPI channel
NRF_PPI->CHENSET = (1UL << PPI_CHANNEL);
while(1){
NRF_SAADC->TASKS_START = 1;
while(NRF_SAADC->EVENTS_STARTED == 0);
NRF_SAADC->EVENTS_STARTED = 0;
NRF_SAADC->TASKS_SAMPLE = 1;
while(NRF_SAADC->EVENTS_END == 0)
event_count++;
nrf_delay_ms(100);
