HID keyboard and central BLE missing keyboard presses
Hi support team,
I've been developing a project that uses a cycling cadence sensor and interacts with my nRF52840 DK which is the central device. I merged the rscs central example with the HID composite example and changed the rscs example to work for my cycling cadence sensor. I have it working. On each rotation of the cadence sensor I intend to send a keyboard up arrow to the computer, which it does. The issue I can't seem to get around is that it seems as if when the sensor rotates slow enough, so only single crank rotations are sent to my DK everything is fine and happy. But, when the sensor rotates a couple of times (say 3) before new data is sent the "app_usbd_event_queue_process()" function call is getting overrun with keyboard presses and in turn the up arrow isn't always being sent to my PC. I hope that makes sense.
So far I have created a repeated timer that checks to see if the current revolution count has changed every 50ms. And I have also played around with the Scheduler Tutorial.
Not sure if its worth putting my code here but I will anyways
 * This file was changed to work with cycling speed and cadence, not running speed and cadence.
#include <stdbool.h>
#include <stdint.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <stddef.h>
#include "nordic_common.h"
#include "nrf_sdm.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_db_discovery.h"
#include "ble_srv_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_util.h"
#include "app_error.h"
#include "ble_dis_c.h"
#include "ble_rscs_c.h"
#include "app_timer.h"
#include "app_scheduler.h"
#include "bsp_btn_ble.h"
#include "peer_manager.h"
#include "peer_manager_handler.h"
#include "fds.h"
#include "nrf_fstorage.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_delay.h"
#include "nrf_ble_scan.h"
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_drv_power.h"
#include "app_usbd.h"
#include "app_usbd_core.h"
#include "app_usbd_hid_kbd.h"
#include "app_usbd_dummy.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
 * @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
            "uart_cli:~$ ",
            &m_cli_uart_transport.transport,
            '\r',
            4);
 * @brief Enable USB power detection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
 * @brief Enable HID keyboard class
#define CONFIG_HAS_KBD      1
 * @brief Letter to be sent on LETTER button
 * @sa BTN_KBD_LETTER
//#define CONFIG_KBD_LETTER APP_USBD_HID_KBD_G
#define CONFIG_KBD_LETTER APP_USBD_HID_KBD_UP
 * @brief Propagate SET_PROTOCOL command to other HID instance
#define PROPAGATE_PROTOCOL  0
#define LED_HID_REP        (BSP_BOARD_LED_2) /**< Changes its state if any HID report was received or transmitted */
#define LED_USB_START      (BSP_BOARD_LED_3) /**< The USBD library has been started and the bus is not in SUSPEND state */
#define BTN_KBD_LETTER     3
#define APP_BLE_CONN_CFG_TAG        1                                   /**< Tag that identifies the BLE configuration of the SoftDevice. */
#define APP_BLE_OBSERVER_PRIO       3                                   /**< BLE observer priority of the application. There is no need to modify this value. */
#define APP_SOC_OBSERVER_PRIO       1                                   /**< SoC observer priority of the application. There is no need to modify this value. */
#define SEC_PARAM_BOND              1                                   /**< Perform bonding. */
#define SEC_PARAM_MITM              0                                   /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC              0                                   /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS          0                                   /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES   BLE_GAP_IO_CAPS_NONE                /**< No I/O capabilities. */
#define SEC_PARAM_OOB               0                                   /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE      7                                   /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE      16                                  /**< Maximum encryption key size. */
#define SCAN_INTERVAL               0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                 0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION           0x0000                              /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning continues until it is explicitly disabled. */
#define SCAN_DURATION_WITELIST  3000                                /**< Duration of the scanning in units of 10 milliseconds. */
#define MIN_CONNECTION_INTERVAL     MSEC_TO_UNITS(7.5, UNIT_1_25_MS)    /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL     MSEC_TO_UNITS(30, UNIT_1_25_MS)     /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY               0                                   /**< Determines slave latency in counts of connection events. */
#define SUPERVISION_TIMEOUT         MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Determines supervision timeout in units of 10 millisecond. */
#define TARGET_UUID                 BLE_UUID_CYCLING_SPEED_AND_CADENCE  /**BLE_UUID_RUNNING_SPEED_AND_CADENCE< Target UUID that the application looks for. */
// Scheduler settings
#define SCHED_MAX_EVENT_DATA_SIZE   sizeof(ble_rscs_c_evt_t)
#define SCHED_QUEUE_SIZE            200 //started as 10
/**@brief Variable length data encapsulation in terms of length and pointer to data. */
typedef struct
    uint8_t * p_data;   /**< Pointer to data. */
    uint16_t  data_len; /**< Length of data. */
} data_t;
/**@brief Strings to display data retrieved by Device Information Service client module. */
static char const * const m_dis_char_names[] =
    "Manufacturer Name String",
    "Model Number String     ",
    "Serial Number String    ",
    "Hardware Revision String",
    "Firmware Revision String",
    "Software Revision String",
    "System ID",
    "IEEE 11073-20601 Regulatory Certification Data List",
    "PnP ID"
BLE_DIS_C_DEF(m_ble_dis_c);                                 /**< Device Information Service client instance. */
BLE_RSCS_C_DEF(m_rscs_c);                                   /**< Running Speed and Cadence Service client instance. */
NRF_BLE_GATT_DEF(m_gatt);                                   /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                            /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                   /**< Scanning Module instance. */
APP_TIMER_DEF(m_repeated_timer_id);     /**< Handler for repeated timer used to check whether the revoltion data has changed. */
static bool                  scanningStarted = false;
static uint16_t              m_conn_handle;                 /**< Current connection handle. */
static bool                  m_whitelist_disabled;          /**< True if the whitelist is temporarily disabled. */
static bool                  m_memory_access_in_progress;   /**< Flag to keep track of ongoing operations on persistent memory. */
static bool                  m_rscs_log_enabled;            /**< Flag to enable logs related with RSCS measurements. */
static uint16_t new_CCR = 0;
static uint16_t CCR = 0;
static uint16_t deltaCCR = 0;
static uint16_t revCount;
static bool revFlag = true;
static ble_gap_scan_params_t m_scan_param =                 /**< Scan parameters requested for scanning and connection. */
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_WHITELIST,
    .timeout       = SCAN_DURATION_WITELIST,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
    .extended      = 1,
 * @brief Additional key release events
 * This example needs to process release events of used buttons
enum {
    BSP_USER_EVENT_RELEASE_0 = BSP_EVENT_KEY_LAST + 1, /**< Button 0 released */
    BSP_USER_EVENT_RELEASE_1,                          /**< Button 1 released */
    BSP_USER_EVENT_RELEASE_2,                          /**< Button 2 released */
    BSP_USER_EVENT_RELEASE_3,                          /**< Button 3 released */
    BSP_USER_EVENT_RELEASE_4,                          /**< Button 4 released */
    BSP_USER_EVENT_RELEASE_5,                          /**< Button 5 released */
    BSP_USER_EVENT_RELEASE_6,                          /**< Button 6 released */
    BSP_USER_EVENT_RELEASE_7,                          /**< Button 7 released */
 * @brief USB composite interfaces
#define APP_USBD_INTERFACE_KBD   1
 * @brief User event handler, HID keyboard
static void hid_kbd_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_hid_user_event_t event);
/*lint -save -e26 -e64 -e123 -e505 -e651*/
 * @brief Global HID keyboard instance
APP_USBD_HID_KBD_GLOBAL_DEF(m_app_hid_kbd,
                            APP_USBD_INTERFACE_KBD,
                            NRF_DRV_USBD_EPIN2,
                            hid_kbd_user_ev_handler,
                            APP_USBD_HID_SUBCLASS_BOOT
APP_USBD_DUMMY_GLOBAL_DEF(m_app_kbd_dummy, APP_USBD_INTERFACE_KBD);
/*lint -restore*/
 * @brief Class specific event handler.
 * @param p_inst    Class instance.
 * @param event     Class specific event.
    UNUSED_PARAMETER(p_inst);
    switch (event) {
        case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
            /* Only one output report IS defined for HID keyboard class. Update LEDs state. */
            bsp_board_led_invert(LED_HID_REP);
            //kbd_status();
        case APP_USBD_HID_USER_EVT_IN_REPORT_DONE:
        case APP_USBD_HID_USER_EVT_SET_BOOT_PROTO:
            UNUSED_RETURN_VALUE(hid_kbd_clear_buffer(p_inst));
        case APP_USBD_HID_USER_EVT_SET_REPORT_PROTO:
 * @brief USBD library specific event handler.
 * @param event     USBD library event.
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SOF:
        case APP_USBD_EVT_DRV_SUSPEND:
            app_usbd_suspend_req(); // Allow the library to put the peripheral into sleep mode
            bsp_board_leds_off();
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_START);
            //kbd_status(); /* Restore LED state - during SUSPEND all LEDS are turned off */
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void scan_start(void);
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of an assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for handling database discovery events.
 * @details This function is a callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function forwards the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    ble_rscs_on_db_disc_evt(&m_rscs_c, p_evt);
    ble_dis_c_on_db_disc_evt(&m_ble_dis_c, p_evt);
/**@brief Function for handling Peer Manager events.
 * @param[in] p_evt  Peer Manager event.
static void pm_evt_handler(pm_evt_t const * p_evt)
    pm_handler_on_pm_evt(p_evt);
    pm_handler_disconnect_on_sec_failure(p_evt);
    pm_handler_flash_clean(p_evt);
    switch (p_evt->evt_id)
            scan_start();
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    ret_code_t err_code;
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_CONNECTED:
            // Discover the peer's services.
            err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
            if (ble_conn_state_central_conn_count() < NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                scan_start();
            //scanningStarted = true; //make sure connection established before allowing USB data transfer.
        } break;
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection Request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                         p_gap_evt->params.disconnected.reason);
                scan_start();
            // Stop the repeated timer upon ble disconnect. (stop checking for change in crank revolutions).
            err_code = app_timer_stop(m_repeated_timer_id);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
        } break;
 * @brief SoftDevice SoC event handler.
 * @param[in] evt_id    SoC event.
 * @param[in] p_context Context.
static void soc_evt_handler(uint32_t evt_id, void * p_context)
    switch (evt_id)
        case NRF_EVT_FLASH_OPERATION_SUCCESS:
        /* fall through */
        case NRF_EVT_FLASH_OPERATION_ERROR:
            if (m_memory_access_in_progress)
                m_memory_access_in_progress = false;
                scan_start();
            // No implementation needed.
    uint32_t ram_start = 0;
    // Enable BLE stack.
    // Register handlers for BLE and SoC events.
    NRF_SDH_SOC_OBSERVER(m_soc_observer, APP_SOC_OBSERVER_PRIO, soc_evt_handler, NULL);
/**@brief Function for disabling the use of the whitelist for scanning.
static void whitelist_disable(void)
    if (!m_whitelist_disabled)
        NRF_LOG_INFO("Whitelist temporarily disabled.");
        m_whitelist_disabled = true;
        nrf_ble_scan_stop();
        scan_start();
/** @brief Function for setting the @ref ERROR_PIN high, and then enter an infinite loop.
static void show_error(void)
    bsp_board_leds_on();
    while (true)
        // Do nothing.
 * @param[in]   event   Event generated by button press.
    switch ((unsigned int) event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
        case BSP_EVENT_DISCONNECT:
            err_code = sd_ble_gap_disconnect(m_conn_handle,
        case BSP_EVENT_WHITELIST_OFF:
            whitelist_disable();
//        case CONCAT_2(BSP_EVENT_KEY_, BTN_KBD_LETTER):
//            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, CONFIG_KBD_LETTER, true));
//            break;
//        case CONCAT_2(BSP_USER_EVENT_RELEASE_, BTN_KBD_LETTER):
//            UNUSED_RETURN_VALUE(app_usbd_hid_kbd_key_control(&m_app_hid_kbd, CONFIG_KBD_LETTER, false));
//            break;
/**@brief Running Speed and Cadence collector handler.
static void rscs_c_evt_handler(ble_rscs_c_t * p_rsc_c, ble_rscs_c_evt_t * p_rsc_c_evt)
    switch (p_rsc_c_evt->evt_type)
        case BLE_RSCS_C_EVT_DISCOVERY_COMPLETE:
            // Initiate bonding.
            err_code = ble_rscs_c_handles_assign(&m_rscs_c,
                                                 p_rsc_c_evt->conn_handle,
                                                 &p_rsc_c_evt->params.rscs_db);
            err_code = pm_conn_secure(p_rsc_c_evt->conn_handle, false);
            if (err_code != NRF_ERROR_BUSY)
            // Running Speed and Cadence Service discovered. Enable Running Speed and Cadence notifications.
            err_code = ble_rscs_c_rsc_notif_enable(p_rsc_c);
            NRF_LOG_INFO("Cycling Speed and Cadence Service discovered."); //was running not cycling
            new_CCR = p_rsc_c_evt->params.rsc.cumulative_crank_revolutions; //incase of disconnect
//            revFlag = true;
            if(revCount == new_CCR)
                  deltaCCR = 0;
                  CCR = new_CCR;
                  revCount = new_CCR;
                  CCR = new_CCR;
                  deltaCCR = 0;
             //START THE TIMER
            err_code = app_timer_start(m_repeated_timer_id, APP_TIMER_TICKS(25), NULL);
        case BLE_RSCS_C_EVT_RSC_NOTIFICATION:
            revCount = new_CCR;
//            if (m_rscs_log_enabled)
//                //revCount = new_CCR;
////                deltaCCR = new_CCR - CCR;
//                NRF_LOG_INFO("");
//                //NRF_LOG_DEBUG("CSC Measurement received");
//                NRF_LOG_INFO("Cumulative Crank Revolutions = %d", p_rsc_c_evt->params.rsc.cumulative_crank_revolutions);
//                NRF_LOG_INFO("Last Event Time = %d", p_rsc_c_evt->params.rsc.last_crank_event_time);
//                //NRF_LOG_INFO("Instantaneous Cadence = " NRF_LOG_FLOAT_MARKER, NRF_LOG_FLOAT(inst_cadence));
////                NRF_LOG_INFO("Instantaneous Cadence = %d", inst_cadence);
/**@brief Function for reading all characteristics that can be present in DIS.
 * @return    The number of discovered characteristics.
static uint32_t ble_dis_c_all_chars_read(void)
    uint32_t   disc_char_num = 0;
    for (ble_dis_c_char_type_t char_type = (ble_dis_c_char_type_t) 0;
         char_type < BLE_DIS_C_CHAR_TYPES_NUM;
         char_type++)
        err_code = ble_dis_c_read(&m_ble_dis_c, char_type);
        // The NRF_ERROR_INVALID_STATE error code means that the characteristic is not present in DIS.
            disc_char_num++;
    return disc_char_num;
/**@brief Function for logging string characteristics that can be present in Device Information Service.
 * @param[in] char_type Type of string characteristic.
 * @param[in] p_string  Response data of the characteristic that has been read.
static void ble_dis_c_string_char_log(ble_dis_c_char_type_t            char_type,
                                      ble_dis_c_string_t const * const p_string)
    char response_data_string[BLE_DIS_C_STRING_MAX_LEN] = {0};
    if (sizeof(response_data_string) > p_string->len)
        memcpy(response_data_string, p_string->p_data, p_string->len);
        NRF_LOG_INFO("%s: %s",
                     m_dis_char_names[char_type],
                     nrf_log_push((char *) response_data_string));
        NRF_LOG_ERROR("String buffer for DIS characteristics is too short.")
/**@brief Function for logging System ID characteristic data that can be present in Device Information Service.
 * @param[in] p_sys_id Pointer to structure that describes the content of the System ID characteristic.
static void ble_dis_c_system_id_log(ble_dis_sys_id_t const * const p_sys_id)
    NRF_LOG_INFO("%s:", m_dis_char_names[BLE_DIS_C_SYS_ID]);
    NRF_LOG_INFO(" Manufacturer Identifier:            0x%010X", p_sys_id->manufacturer_id);
    NRF_LOG_INFO(" Organizationally Unique Identifier: 0x%06X", p_sys_id->organizationally_unique_id);
/**@brief Function for logging IEEE 11073-20601 Regulatory Certification Data List characteristic
 *        data that can be present in DIS.
 * @param[in] p_cert_list  Pointer to structure that describes the content of Certification Data List
 *                         characteristic.
static void ble_dis_c_cert_list_log(ble_dis_reg_cert_data_list_t const * const p_cert_list)
    NRF_LOG_INFO("%s:", m_dis_char_names[BLE_DIS_C_CERT_LIST]);
    NRF_LOG_HEXDUMP_INFO(p_cert_list->p_list, p_cert_list->list_len);
/**@brief Function for logging PnP ID characteristic data that can be present in Device Information Service.
 * @param[in] p_pnp_id Pointer to structure that describes the content of PnP ID characteristic.
static void ble_dis_c_pnp_id_log(ble_dis_pnp_id_t const * const p_pnp_id)
    NRF_LOG_INFO("%s:", m_dis_char_names[BLE_DIS_C_PNP_ID]);
    NRF_LOG_INFO(" Vendor ID Source: 0x%02X", p_pnp_id->vendor_id_source);
    NRF_LOG_INFO(" Vendor ID:        0x%04X", p_pnp_id->vendor_id);
    NRF_LOG_INFO(" Product ID:       0x%04X", p_pnp_id->product_id);
    NRF_LOG_INFO(" Product Version:  0x%04X", p_pnp_id->product_version);
/**@brief Device Information Service client handler.
static void ble_dis_c_evt_handler(ble_dis_c_t * p_ble_dis_c, ble_dis_c_evt_t const * p_ble_dis_evt)
    static uint32_t disc_chars_num     = 0;
    static uint32_t disc_chars_handled = 0;
    switch (p_ble_dis_evt->evt_type)
        case BLE_DIS_C_EVT_DISCOVERY_COMPLETE:
            err_code = ble_dis_c_handles_assign(p_ble_dis_c,
                                                p_ble_dis_evt->conn_handle,
                                                p_ble_dis_evt->params.disc_complete.handles);
            disc_chars_num     = ble_dis_c_all_chars_read();
            NRF_LOG_INFO("Device Information Service discovered.");
        case BLE_DIS_C_EVT_DIS_C_READ_RSP:
            ble_dis_c_evt_read_rsp_t const * p_read_rsp = &p_ble_dis_evt->params.read_rsp;
            //Print header log.
            if ((disc_chars_handled == 0) && (disc_chars_num != 0))
                NRF_LOG_INFO("");
                NRF_LOG_INFO("Device Information:");
            switch (p_read_rsp->char_type)
                case BLE_DIS_C_MANUF_NAME:
                case BLE_DIS_C_MODEL_NUM:
                case BLE_DIS_C_SERIAL_NUM:
                case BLE_DIS_C_HW_REV:
                case BLE_DIS_C_FW_REV:
                case BLE_DIS_C_SW_REV:
                    ble_dis_c_string_char_log(p_read_rsp->char_type, &p_read_rsp->content.string);
                case BLE_DIS_C_SYS_ID:
                    ble_dis_c_system_id_log(&p_read_rsp->content.sys_id);
                case BLE_DIS_C_CERT_LIST:
                    ble_dis_c_cert_list_log(&p_read_rsp->content.cert_list);
                case BLE_DIS_C_PNP_ID:
                    ble_dis_c_pnp_id_log(&p_read_rsp->content.pnp_id);
            disc_chars_handled++;
            if(disc_chars_handled == disc_chars_num)
                NRF_LOG_INFO("");
                disc_chars_num     = 0;
                //m_rscs_log_enabled = true;
        case BLE_DIS_C_EVT_DIS_C_READ_RSP_ERROR:
            NRF_LOG_ERROR("Read request for: %s characteristic failed with gatt_status: 0x%04X.",
                          m_dis_char_names[p_ble_dis_evt->params.read_rsp.char_type],
                          p_ble_dis_evt->params.read_rsp_err.gatt_status);
        case BLE_DIS_C_EVT_DISCONNECTED:
 * @brief Running Speed and Cadence collector initialization.
static void rscs_c_init(void)
    ble_rscs_c_init_t rscs_c_init_obj;
    rscs_c_init_obj.evt_handler = rscs_c_evt_handler;
    ret_code_t err_code = ble_rscs_c_init(&m_rscs_c, &rscs_c_init_obj);
/**@brief Function for initializing the Device Information Service client. */
static void dis_c_init(void)
    ble_dis_c_init_t init;
    memset(&init, 0, sizeof(ble_dis_c_init_t));
    init.evt_handler = ble_dis_c_evt_handler;
    err_code = ble_dis_c_init(&m_ble_dis_c, &init);
/**@brief Function for initializing the Peer Manager.
 * @param[in] erase_bonds  Indicates whether the bonding information must be cleared from
 *                         persistent storage during the initialization of the Peer Manager.
static void peer_manager_init()
    err_code = pm_init();
    sec_param.bond           = SEC_PARAM_BOND;
    sec_param.mitm           = SEC_PARAM_MITM;
    sec_param.lesc           = SEC_PARAM_LESC;
    sec_param.keypress       = SEC_PARAM_KEYPRESS;
    sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
    sec_param.oob            = SEC_PARAM_OOB;
    sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
    sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
    sec_param.kdist_own.enc  = 1;
    sec_param.kdist_own.id   = 1;
    sec_param.kdist_peer.enc = 1;
    sec_param.kdist_peer.id  = 1;
/**@brief Clear bonding information from the persistent storage.
static void delete_bonds(void){
    NRF_LOG_INFO("Erase bonds");
    err_code = pm_peers_delete();
 * @brief Database discovery collector initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
/**@brief Retrive a list of peer manager peer IDs.
 * @param[inout] p_peers   The buffer where to store the list of peer IDs.
 * @param[inout] p_size    In: The size of the @p p_peers buffer.
 *                         Out: The number of peers copied in the buffer.
static void peer_list_get(pm_peer_id_t * p_peers, uint32_t * p_size)
    pm_peer_id_t peer_id;
    uint32_t     peers_to_copy;
    peers_to_copy = (*p_size < BLE_GAP_WHITELIST_ADDR_MAX_COUNT) ?
                     *p_size : BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
    peer_id = pm_next_peer_id_get(PM_PEER_ID_INVALID);
    *p_size = 0;
    while ((peer_id != PM_PEER_ID_INVALID) && (peers_to_copy--))
        p_peers[(*p_size)++] = peer_id;
        peer_id = pm_next_peer_id_get(peer_id);
static void whitelist_load()
    ret_code_t   ret;
    pm_peer_id_t peers[8];
    uint32_t     peer_cnt;
    memset(peers, PM_PEER_ID_INVALID, sizeof(peers));
    peer_cnt = (sizeof(peers) / sizeof(pm_peer_id_t));
    // Load all peers from the flash and whitelist them.
    peer_list_get(peers, &peer_cnt);
    ret = pm_whitelist_set(peers, peer_cnt);
    APP_ERROR_CHECK(ret);
    // Setup the list of device identities.
    // Some SoftDevices do not support this feature.
    ret = pm_device_identities_list_set(peers, peer_cnt);
    if (ret != NRF_ERROR_NOT_SUPPORTED)
static void on_whitelist_req(void)
    // Whitelist buffers.
    ble_gap_addr_t whitelist_addrs[8];
    ble_gap_irk_t  whitelist_irks[8];
    memset(whitelist_addrs, 0x00, sizeof(whitelist_addrs));
    memset(whitelist_irks,  0x00, sizeof(whitelist_irks));
    uint32_t addr_cnt = (sizeof(whitelist_addrs) / sizeof(ble_gap_addr_t));
    uint32_t irk_cnt  = (sizeof(whitelist_irks)  / sizeof(ble_gap_irk_t));
    // Reload the whitelist and whitelist all peers.
    whitelist_load();
    ret_code_t ret;
    // Get the whitelist previously set with pm_whitelist_set().
    ret = pm_whitelist_get(whitelist_addrs, &addr_cnt,
                           whitelist_irks,  &irk_cnt);
    if (((addr_cnt == 0) && (irk_cnt == 0)) ||
        (m_whitelist_disabled))
        m_scan_param.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL;
        ret = nrf_ble_scan_params_set(&m_scan, &m_scan_param);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
            on_whitelist_req();
            m_whitelist_disabled = false;
        } break;
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
        case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
            NRF_LOG_INFO("Scan timed out.");
            scan_start();
        } break;
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
        case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    nrf_ble_scan_init_t init_scan;
    ble_uuid_t uuid =
        .type = BLE_UUID_TYPE_BLE,
        .uuid = TARGET_UUID,
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    init_scan.p_scan_param     = &m_scan_param;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
/**@brief Function for starting scanning.
    // If there is any pending write to flash, defer scanning until it completes.
    if (nrf_fstorage_is_busy(NULL))
        m_memory_access_in_progress = true;
        return;
    NRF_LOG_INFO("Starting scan.");
    m_scan_param.filter_policy = BLE_GAP_SCAN_FP_WHITELIST;
    err_code = nrf_ble_scan_params_set(&m_scan, &m_scan_param);
    err_code = nrf_ble_scan_start(&m_scan);
    err_code = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for initializing buttons and LEDs.
 * @param[out] p_erase_bonds  True if the clear bonding button was pressed to wake the application up.
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler); //"removed BSP_INIT_LEDS |"
//    err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler); //added from init_bsp() ***** was bsp_event_callback
//    APP_ERROR_CHECK(err_code); //added from init_bsp()
//    INIT_BSP_ASSIGN_RELEASE_ACTION(BTN_KBD_LETTER ); //added from init_bsp()
//    bsp_board_init(BSP_INIT_LEDS);  //added from init_bsp()
static void init_cli(void)
    ret_code_t ret;
//    ret = bsp_cli_init(bsp_event_callback);
    ret = bsp_cli_init(bsp_event_handler);
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    ret = nrf_cli_start(&m_cli_uart);
/**@brief Function for initializing logging. */
static void log_init(void)
///**@brief Function for initializing the timer. */
//static void timer_init(void)
//    ret_code_t err_code = app_timer_init();
/**@brief Function for initializing the GATT module. */
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
/**@brief Function for starting a scan, or instead triggering it from the peer manager (after
 *        deleting bonds).
 * @param[in] p_erase_bonds Pointer to a bool to determine whether bonds are to be deleted before scanning.
void scanning_start(bool * p_erase_bonds)
    // Start scanning for peripherals and initiate connection
    // with devices that advertise GATT Service UUID.
    if (*p_erase_bonds == true)
        // Scan is started by the PM_EVT_PEERS_DELETE_SUCCEEDED event.
        delete_bonds();
        scan_start();
 /**@brief Timeout handler for the repeated timer.*/
static void repeated_timer_handler(void * p_context)
    //CCR = new_CCR;
    for(int i=0; i<deltaCCR; i++)
    CCR = new_CCR;
/**@brief Button handler function to be called by the scheduler.
void usbd_scheduler_event_handler(void *p_event_data, uint16_t event_size)
    // In this case, p_event_data is a pointer to a nrf_drv_gpiote_pin_t that represents
    // the pin number of the button pressed. The size is constant, so it is ignored.
    rscs_c_evt_handler(NULL, ((ble_rscs_c_evt_t*)p_event_data)); //was too few arguements so i added NULL
static void cscs_event_handler(ble_rscs_c_evt_t p_rsc_c_evt)
    //usbd_user_ev_handler(event);
        app_sched_event_put(&p_rsc_c_evt, sizeof(p_rsc_c_evt), usbd_scheduler_event_handler);
/**@brief Create timers. */
static void create_timers()
    // Create timers
    err_code = app_timer_create(&m_repeated_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                repeated_timer_handler);
    bool erase_bonds;
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler,
    ret = NRF_LOG_INIT(NULL);
    //log_init();
    ret = nrf_drv_clock_init();
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    ret = app_timer_init();
    //init_bsp();
    //Initialize.
    //log_init();
    //timer_init();
    init_cli();
    ret = app_usbd_init(&usbd_config);
    power_management_init();
    ble_stack_init();
    gatt_init();
    peer_manager_init();
    db_discovery_init();
    rscs_c_init();
    dis_c_init();
    scan_init();
    whitelist_load();
    // Start execution.
    NRF_LOG_INFO("Running Speed Collector example started.");
    scanning_start(&erase_bonds);
//    while(!scanningStarted)
//        /* wait till connection*/
     app_usbd_class_inst_t const * class_inst_kbd;
#if CONFIG_HAS_KBD
    class_inst_kbd = app_usbd_hid_kbd_class_inst_get(&m_app_hid_kbd);
#else
    class_inst_kbd = app_usbd_dummy_class_inst_get(&m_app_kbd_dummy);
    ret = app_usbd_class_append(class_inst_kbd);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        //scanning_start(&erase_bonds);
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    create_timers();
    APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
    // Enter main loop.
    for(;;)
        while(app_usbd_event_queue_process())
            /* Nothing to do */
        nrf_cli_process(&m_cli_uart);
        app_sched_execute();
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        /* Sleep CPU only if there was no interrupt since last loop processing */
        sd_app_evt_wait();
//        __WFE();
//        idle_state_handle(); //put to sleep if no nRF log to process.
If there is any questions about what I am trying to explain please ask and I will try to clear it up.
    If I understand the scenario correct, it is that if you receive data quickly over BTLE, it will saturate the USBD.
    I see that your main loop consists of nrf_cli and nrf_log handling as well as the scheduler. Are you using NRF_LOG, with serial as the backend? If yes, try to disable it and see if this helps the processing.
    Same goes for nrf_cli; if you're not using it, try disabling it to see if this has an impact on your overall performance.
    Håkon
  • Hi Håkon,
    Thanks for getting back to me. It does seem like the USBD is being saturated.
    I have disabled nrf_cli and nrf_log in my sdk_config file and commented out any reference to them in main. It still seems as though the USBD is still being saturated. I also have abandon the scheduler.
    I set a repeated timer up previously to check to see if a keyboard press would need to be sent in hopes the USBD wouldn't be saturated and I could control how much data was being sent. But, no success.
    If you have any other suggestions that would be great.
    Thanks
  • The throughput over usb is fairly low compared to what it technically can handle (which is why I thought the LOG and CLI took too much time), but it would be interesting to see if your calls to "app_usbd_hid_kbd_key_control" return NRF_SUCCESS, or if they return anything else. Could you check this?
    Håkon
  • Yeah when I was first trying to diagnose this issue it was I thought it might have something to do with nRF_LOG lagging.
    Anyways, I'm not exactly sure how to check for NRF_SUCCESS but using VERIFY_SUCCESS(err_code) no errors were returned.
    It would make sense that "app_usbd_hid_kbd_key_control" would not be ready to receive a key press if it was busy. So if 4 keyboard presses were to be recorded quickly and since I'm using a for loop to do this i could see it missing a press or too due to "app_usbd_hid_kbd_key_control" not being ready to receive press and the for loop iterating to fast.
    I am going to try to work with single shot timers to take some relief off of "app_usbd_hid_kbd_key_control" and only send a keyboard press when it is ready.
  • After some trouble shooting and testing I was able to use two single shot timers to space out the time between when "app_usbd_hid_kbd_key_control" gets called in my repeated timer handler. After changing the timing of my single shot timers I was able to use 1ms as the perfect response and one of the fastest times it could execute. I also tried it with 0.5ms but it was to fast and "app_usbd_hid_kbd_key_control" was not ready to receive a keyboard press.
    I should also say that the main.c code I posted above has changed a lot as I am no longer using the scheduler.
    Thank you Håkon for the help and pointing me in the right direction. I would consider this case closed.
