How to use external Flash memory on PCA10056 board.
Hello :)
I am using pca10056.
Use SPIM to control the external flush memory of this board.
I read the IC's surface, I recognized its name is MX25R6435F. (Is it correct ?)
I tried to check the behavior by creating the following simple program using nrf5 SDK ver15.3 and SEGGER, but the MISO signal did not change.
What is wrong?
When changing the settings of lines 51 to 54 of this program and using another pin, the reaction was obtained from an EEPROM with the same instruction code.
Thank you as always.
Best regards.
 * Copyright (c) 2017 - 2019, Nordic Semiconductor ASA
 * All rights reserved.
#include "nrfx_spim.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define NRFX_SPIM_SCK_PIN   19 // 47
#define NRFX_SPIM_MOSI_PIN  20 // 45
#define NRFX_SPIM_MISO_PIN  21 // 46
#define NRFX_SPIM_SS_PIN    17 // 44
#define SPI_INSTANCE  3                                           /**< SPI instance index. */
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
static uint8_t       m_tx_buf[5];           /**< TX buffer. */
static uint8_t       m_rx_buf[5];           /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
void spim_event_handler(nrfx_spim_evt_t const * p_event,
                       void *                  p_context)
    spi_xfer_done = true;
    printf("  Transmitted:\t");
    for(int i=0;i<(sizeof(m_tx_buf)/sizeof(m_tx_buf[0]));i++)
        printf("%d\t",m_tx_buf[i]);
    printf("\n");
    printf("  Received:\t");
    for(int i=0;i<(sizeof(m_rx_buf)/sizeof(m_rx_buf[0]));i++)
        printf("%d\t",m_rx_buf[i]);
    printf("\n");
void InitSPIM(void)
    nrfx_spim_config_t spi_config = NRFX_SPIM_DEFAULT_CONFIG;
    spi_config.frequency      = NRF_SPIM_FREQ_1M;
    spi_config.ss_pin         = NRFX_SPIM_SS_PIN;
    spi_config.miso_pin       = NRFX_SPIM_MISO_PIN;
    spi_config.mosi_pin       = NRFX_SPIM_MOSI_PIN;
    spi_config.sck_pin        = NRFX_SPIM_SCK_PIN;
    spi_config.use_hw_ss      = true;
    spi_config.ss_active_high = false;
    APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spim_event_handler, NULL));
void OpRDSR(void)
    nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_XFER_TRX(m_tx_buf, m_length, m_rx_buf, m_length);
    /* RDSR (Read status register:0000 0101) */
    printf("**RDSR(ReaD Status Register)**\n");
    memset(m_tx_buf, 0x00, m_length);
    m_tx_buf[0] = 5;//0b00000101;
    memset(m_rx_buf, 0, m_length);
    spi_xfer_done = false;
    APP_ERROR_CHECK(nrfx_spim_xfer(&spi, &xfer_desc, false));
//    APP_ERROR_CHECK(nrfx_spim_xfer_dcx(&spi, &xfer_desc, 0, 15));
    while (!spi_xfer_done)
        __WFE();
void OpWREN(void)
    /* WREN (Write enable:0000 0110) */
    printf("**WREN(WRite ENable)**\n");
    memset(m_tx_buf, 0, m_length);
    m_tx_buf[0] = 0b00000110;
        __WFE();
void OpWRDI(void)
    /* WRDI (Write disable:0000 0100) */
    printf("**WRDI(WRite DIsable)**\n");
    m_tx_buf[0] = 0b00000100;
        __WFE();
/* Test1:RDSR->WREN->RDSR->WRDI->RDSR */
/* Confirm Status Registers change */
void Test1(void)
    OpRDSR();
    OpWREN();
    OpRDSR();
    OpWRDI();
    OpRDSR();
    InitSPIM();
    /* Set WP and HOLD*/
    nrf_gpio_cfg_output(22);
    nrf_gpio_pin_set(22);
    nrf_gpio_cfg_output(23);
    nrf_gpio_pin_set(23);
    Test1();
    while (1)
        __WFE();
