I have multiple sensor data that needs to be recorded in separate files. This data is being collected in parallel. Using the FATFS xample in SDK 15, I am able to write one sensor's data to the SD Card. But I am not able to open a second file within the same directory. I use the code below to initialise and write. I tried to chnag ethe variable for FILINFO and FIL and also defined a new FILE_NAME to make a new file in the same directory but that doesnt work. Any pointers how to execute this will be really helpful. Thanks a lot!
static FATFS fs;
static DIR dir;
static FILINFO fno;
static FIL file;
uint32_t bytes_written;
FRESULT ff_result;
DSTATUS disk_state = STA_NOINIT;
int sd_init(){
NRF_BLOCK_DEV_SDC_DEFINE(
m_block_dev_sdc,
NRF_BLOCK_DEV_SDC_CONFIG(
SDC_SECTOR_SIZE,
APP_SDCARD_CONFIG(12,13,14,11)
NFR_BLOCK_DEV_INFO_CONFIG("Nordic", "SDC", "1.00")
#define FILE_NAME "NORDIC.TXT"
#define TEST_STRING "SD card example.\r\n"
// Initialize FATFS disk I/O interface by providing the block device.
static diskio_blkdev_t drives[] =
DISKIO_BLOCKDEV_CONFIG(NRF_BLOCKDEV_BASE_ADDR(m_block_dev_sdc, block_dev), NULL)
diskio_blockdev_register(drives, ARRAY_SIZE(drives));
NRF_LOG_INFO("Initializing disk 0 (SDC)...\r\n");
for (uint32_t retries = 3; retries && disk_state; --retries)
disk_state = disk_initialize(0);
if (disk_state)
NRF_LOG_INFO("Disk initialization failed.\r\n");
return 0;
uint32_t blocks_per_mb = (1024uL * 1024uL) / m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_size;
uint32_t capacity = m_block_dev_sdc.block_dev.p_ops->geometry(&m_block_dev_sdc.block_dev)->blk_count / blocks_per_mb;
NRF_LOG_INFO("Capacity: %d MB\r\n", capacity);
NRF_LOG_INFO("Mounting volume...\r\n");
ff_result = f_mount(&fs, "", 1);
if (ff_result)
NRF_LOG_INFO("Mount failed.\r\n");
return 0;
NRF_LOG_INFO("\r\n Listing directory: /\r\n");
ff_result = f_opendir(&dir, "/");
if (ff_result)
NRF_LOG_INFO("Directory listing failed!\r\n");
return 0;
do
ff_result = f_readdir(&dir, &fno);
if (ff_result != FR_OK)
NRF_LOG_INFO("Directory read failed.");
return 0;
if (fno.fname[0])
if (fno.fattrib & AM_DIR)
NRF_LOG_RAW_INFO(" <DIR> %s\r\n",(uint32_t)fno.fname);
NRF_LOG_RAW_INFO("%9lu %s\r\n", fno.fsize, (uint32_t)fno.fname);
while (fno.fname[0]);
NRF_LOG_RAW_INFO("\r\n");
NRF_LOG_INFO("Writing to file " FILE_NAME "...\r\n");
ff_result = f_open(&file, FILE_NAME, FA_READ | FA_WRITE | FA_OPEN_APPEND);
NRF_LOG_INFO("Unable to open or create file: " FILE_NAME ".\r\n");
return 0;
return 0;
int Write(){
// writiing in sd card
print_f(ff_result);
for (uint8_t d=0; d<20;d++){ // SIZE OF BUFFER
char dat_temp1[22]={0};
sprintf(dat_temp1,"%d,%d,%d,%d",BS[d],F[d], R[d], M[d]);
// f_write(&file, time_stamp_imp[d], sizeof(time_stamp_imp[11]), (UINT *) &bytes_written);
f_write(&file, dat_temp1, 22, (UINT *) &bytes_written);
f_write(&file, newline, 2, (UINT *) &bytes_written);
NRF_LOG_INFO( "Data in SD Card \n");
f_close(&file);
NRF_LOG_INFO( "file close\n");
return 0;
// NRF_LOG_INFO( "Data Written in SD Card \n");
