Increase delay between Radio Event and CPU cycle
I am using S110 7.1.0 which I know has the ability to unblock the CPU during Radio Event. However I would like to do the opposite and increase the time between a Radio event and a CPU cycle. The reason is for Battery measurement accuracy. I cannot guarantee that when my app_timer expires to trigger battery measurements, that it doesn't measure right after a Radio Event. Since the Radio Event will cause the voltage to drop, this drop could persist during the battery measurement causing a falsely low measurement. In an effort to increase the consistency of Battery Measurements, I would like to increase the time between a Radio Event and CPU cycles. Is this possible? If there is another method to making a Battery Measurement more accurate I'm all ears.
Thanks for the help guys,
-K
p.s. I am using averaging across several measurements, but still find the Battery Level report far lower then expect values. I even removed the battery to measure its capacity/level/IR is much higher than what the battery service is reporting.
