which chip should capsule endoscope use? What is the actual maximum speed?
What is the maximum throughput of nRF24LE1?With the nRF52 DK single board, the maximum throughput is 1Mbps, which does not reach 1376.2 kbps. why?
I don't recommend to use the nRF24LE1 for any new development. You can find throughput numbers for the nRF52 running BLE here:
I just did what you gave this specification. the specification is https://infocenter.nordicsemi.com/topic/sds_s132/SDS/s1xx/ble_data_throughput/ble_data_throughput.html?cp=4_5_2_0_16 . which does not reach 1327.5 kbps, Configuration is as follows:
| Protocol | ATT MTU size | LL payload size1 | Connection interval | Method | Maximum data throughput (LE 1M PHY) | Maximum data throughput (LE 2M PHY) |
| GATT Server | 247 | 251 | 50 ms | Send Notification | 702.8 kbps | 1327.5 kbps |
| Receive Write command | 702.8 kbps | 1327.5 kbps |
nRF24LE1 is used in old products. The current throughput rate is 500kbps. I want to increase the throughput rate, but I don't know how to do it.
