under code is my sdk main code and i want to change code to Sensor --I2C-- nRF52 --UART-- app but where i have to start and change ?
Copyright (c) 2010 - 2017, Nordic Semiconductor ASA
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
1. Redistributions of source code must retain the above copyright notice, this
list of conditions and the following disclaimer.
2. Redistributions in binary form, except as embedded into a Nordic
Semiconductor ASA integrated circuit in a product or a software update for
such product, must reproduce the above copyright notice, this list of
conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
3. Neither the name of Nordic Semiconductor ASA nor the names of its
contributors may be used to endorse or promote products derived from this
software without specific prior written permission.
4. This software, with or without modification, must only be used with a
Nordic Semiconductor ASA integrated circuit.
5. Any software provided in binary form under this license must not be reverse
engineered, decompiled, modified and/or disassembled.
THIS SOFTWARE IS PROVIDED BY NORDIC SEMICONDUCTOR ASA "AS IS" AND ANY EXPRESS
OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
OF MERCHANTABILITY, NONINFRINGEMENT, AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL NORDIC SEMICONDUCTOR ASA OR CONTRIBUTORS BE
LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE
GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/** @file
* @brief Thingy application main file.
* This file contains the source code for the Thingy application that uses the Weather Station service.
#include <stdint.h>
#include <float.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "softdevice_handler.h"
#include "app_scheduler.h"
#include "app_button.h"
#include "m_ble.h"
#include "m_environment.h"
#include "m_sound.h"
#include "m_motion.h"
#include "m_ui.h"
#include "m_batt_meas.h"
#include "drv_ext_light.h"
#include "drv_ext_gpio.h"
#include "nrf_delay.h"
#include "twi_manager.h"
#include "support_func.h"
#include "pca20020.h"
#include "app_error.h"
#define NRF_LOG_MODULE_NAME "main "
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define DEAD_BEEF 0xDEADBEEF /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
#define SCHED_MAX_EVENT_DATA_SIZE MAX(APP_TIMER_SCHED_EVENT_DATA_SIZE, BLE_STACK_HANDLER_SCHED_EVT_SIZE) /**< Maximum size of scheduler events. */
#define SCHED_QUEUE_SIZE 60 /**< Maximum number of events in the scheduler queue. */
static const nrf_drv_twi_t m_twi_sensors = NRF_DRV_TWI_INSTANCE(TWI_SENSOR_INSTANCE); //TWI sensor(Two-Wire Interface) info
static m_ble_service_handle_t m_ble_service_handles[THINGY_SERVICES_MAX]; //THINGY_SERVICES_MAX == 5
void app_error_fault_handler(uint32_t id, uint32_t pc, uint32_t info) //(unsigned int, unsigned int, unsigned int)
#if NRF_LOG_ENABLED // 1
error_info_t * err_info = (error_info_t*)info;
NRF_LOG_ERROR(" id = %d, pc = %d, file = %s, line number: %d, error code = %d = %s \r\n", \
id, pc, nrf_log_push((char*)err_info->p_file_name), err_info->line_num, err_info->err_code, nrf_log_push((char*)nrf_strerror_find(err_info->err_code)));
(void)m_ui_led_set_event(M_UI_ERROR);
NRF_LOG_FINAL_FLUSH();
nrf_delay_ms(5);
// On assert, the system can only recover with a reset.
#ifndef DEBUG
NVIC_SystemReset();
app_error_save_and_stop(id, pc, info);
/**@brief Function for assert macro callback.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
/**@brief Function for putting Thingy into sleep mode.
uint32_t err_code;
NRF_LOG_INFO("Entering sleep mode \r\n");
err_code = m_motion_sleep_prepare(true);
err_code = support_func_configure_io_shutdown();
// Enable wake on button press.
nrf_gpio_cfg_sense_input(BUTTON, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
// Enable wake on low power accelerometer.
nrf_gpio_cfg_sense_input(LIS_INT1, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_HIGH);
NRF_LOG_FLUSH();
nrf_delay_ms(5);
// Go to system-off (sd_power_system_off() will not return; wakeup will cause a reset). When debugging, this function may return and code execution will continue.
NRF_LOG_WARNING("sd_power_system_off() returned. -Probably due to debugger being used. Instructions will still run. \r\n");
NRF_LOG_FLUSH();
#ifdef DEBUG
if(!support_func_sys_halt_debug_enabled())
APP_ERROR_CHECK(err_code); // If not in debug mode, return the error and the system will reboot.
NRF_LOG_WARNING("Exec stopped, busy wait \r\n");
NRF_LOG_FLUSH();
while(true) // Only reachable when entering emulated system off.
// Infinte loop to ensure that code stops in debug mode.
#else
/**@brief Function for placing the application in low power state while waiting for events.
#define FPU_EXCEPTION_MASK 0x0000009F
static void power_manage(void)
__set_FPSCR(__get_FPSCR() & ~(FPU_EXCEPTION_MASK));
(void) __get_FPSCR();
NVIC_ClearPendingIRQ(FPU_IRQn);
uint32_t err_code = sd_app_evt_wait();
/**@brief Battery module data handler.
static void m_batt_meas_handler(m_batt_meas_event_t const * p_batt_meas_event)
NRF_LOG_INFO("Voltage: %d V, Charge: %d %%, Event type: %d \r\n",
p_batt_meas_event->voltage_mv, p_batt_meas_event->level_percent, p_batt_meas_event->type);
if (p_batt_meas_event != NULL)
if( p_batt_meas_event->type == M_BATT_MEAS_EVENT_LOW)
uint32_t err_code;
// Enable wake on USB detect only.
nrf_gpio_cfg_sense_input(USB_DETECT, NRF_GPIO_PIN_NOPULL, NRF_GPIO_PIN_SENSE_HIGH);
NRF_LOG_WARNING("Battery voltage low, shutting down Thingy. Connect USB to charge \r\n");
// Go to system-off mode (This function will not return; wakeup will cause a reset).
#ifdef DEBUG
NRF_LOG_FLUSH();
#else
static void thingy_ble_evt_handler(m_ble_evt_t * p_evt)
switch (p_evt->evt_type)
case thingy_ble_evt_connected:
NRF_LOG_INFO(NRF_LOG_COLOR_CODE_GREEN "Thingy_ble_evt_connected \r\n");
case thingy_ble_evt_disconnected:
NRF_LOG_INFO(NRF_LOG_COLOR_CODE_YELLOW "Thingy_ble_evt_disconnected \r\n");
nrf_delay_ms(5);
NVIC_SystemReset();
case thingy_ble_evt_timeout:
NRF_LOG_INFO(NRF_LOG_COLOR_CODE_YELLOW "Thingy_ble_evt_timeout \r\n");
sleep_mode_enter();
NVIC_SystemReset();
/**@brief Function for initializing the Thingy.
static void thingy_init(void)
uint32_t err_code;
m_ui_init_t ui_params;
m_environment_init_t env_params;
m_motion_init_t motion_params;
m_ble_init_t ble_params;
batt_meas_init_t batt_meas_init = BATT_MEAS_PARAM_CFG;
/**@brief Initialize the TWI manager. */
err_code = twi_manager_init(APP_IRQ_PRIORITY_THREAD);
/**@brief Initialize LED and button UI module. */
ui_params.p_twi_instance = &m_twi_sensors;
err_code = m_ui_init(&m_ble_service_handles[THINGY_SERVICE_UI],
&ui_params);
/**@brief Initialize environment module. */
env_params.p_twi_instance = &m_twi_sensors;
err_code = m_environment_init(&m_ble_service_handles[THINGY_SERVICE_ENVIRONMENT],
&env_params);
/**@brief Initialize motion module. */
motion_params.p_twi_instance = &m_twi_sensors;
err_code = m_motion_init(&m_ble_service_handles[THINGY_SERVICE_MOTION],
&motion_params);
err_code = m_sound_init(&m_ble_service_handles[THINGY_SERVICE_SOUND]);
/**@brief Initialize the battery measurement. */
batt_meas_init.evt_handler = m_batt_meas_handler;
err_code = m_batt_meas_init(&m_ble_service_handles[THINGY_SERVICE_BATTERY], &batt_meas_init);
err_code = m_batt_meas_enable(BATT_MEAS_INTERVAL_MS);
/**@brief Initialize BLE handling module. */
ble_params.evt_handler = thingy_ble_evt_handler;
ble_params.p_service_handles = m_ble_service_handles;
ble_params.service_num = THINGY_SERVICES_MAX;
err_code = m_ble_init(&ble_params);
err_code = m_ui_led_set_event(M_UI_BLE_DISCONNECTED);
static void board_init(void)
uint32_t err_code;
drv_ext_gpio_init_t ext_gpio_init;
#if defined(THINGY_HW_v0_7_0)
#error "HW version v0.7.0 not supported."
#elif defined(THINGY_HW_v0_8_0)
NRF_LOG_WARNING("FW compiled for depricated Thingy HW v0.8.0 \r\n");
#elif defined(THINGY_HW_v0_9_0)
NRF_LOG_WARNING("FW compiled for depricated Thingy HW v0.9.0 \r\n");
static const nrf_drv_twi_config_t twi_config =
.scl = TWI_SCL,
.sda = TWI_SDA,
.frequency = NRF_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_LOW
static const drv_sx1509_cfg_t sx1509_cfg =
.twi_addr = SX1509_ADDR,
.p_twi_instance = &m_twi_sensors,
.p_twi_cfg = &twi_config
ext_gpio_init.p_cfg = &sx1509_cfg;
err_code = support_func_configure_io_startup(&ext_gpio_init);
nrf_delay_ms(100);
/**@brief Application main function.
uint32_t err_code;
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO(NRF_LOG_COLOR_CODE_GREEN"===== Thingy started! =====\r\n");
// Initialize.
APP_SCHED_INIT(SCHED_MAX_EVENT_DATA_SIZE, SCHED_QUEUE_SIZE);
err_code = app_timer_init();
board_init();
thingy_init();
for (;;)
app_sched_execute();
if (!NRF_LOG_PROCESS()) // Process logs
power_manage();
