Hello, I am trying to send and recieve data with the M24C32-FMN6TP 32 Kbit (4K x 8bit) eeprom. My data are arrays with 16bit values and the datasheet says it cannot write more than 32bytes at once so I tried to test this by writing three 32byte blocks and reading them back.
The following functions are used for reading and writing over TWI:
void TwiWrite(uint16_t addr, uint16_t* array_ptr, uint8_t array_len) { TwiWriteExpand(&m_twi, EEPROM_SLAVE_ADDRESS, addr, (uint8_t *)(array_ptr), sizeof(*array_ptr) * array_len , FALSE); } void TwiWriteExpand(nrf_drv_twi_t const * p_instance, uint8_t slv_address, uint16_t address, uint8_t const *p_data, uint8_t length, bool no_stop) { uint8_t buff_pos = 2; // Offset for address uint8_t buffer[EEPROM_SIZE]; // Size of EEPROM buffer buffer[0] = (uint8_t)(address >> 8); buffer[1] = (uint8_t)(address & 0xFF); for(int i = 0; i < length; i++) buffer[buff_pos++] = p_data[i]; nrf_drv_twi_tx(p_instance, slv_address, buffer, buff_pos, FALSE); } uint16_t TwiRead(uint16_t addr, uint16_t * pdata, uint8_t read_len) { uint16_t data; nrf_drv_twi_tx(&m_twi, EEPROM_SLAVE_ADDRESS, (uint8_t *)&addr, 2, TRUE); // EEPROM address nrf_drv_twi_rx(&m_twi, EEPROM_SLAVE_ADDRESS, (uint8_t*)pdata, (read_len * sizeof(*pdata))); // Receive data return data; }
The sequence in main is:
uint16_t valuesA[16] = {1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16}; uint16_t valuesB[16] = {17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32}; uint16_t valuesC[16] = {33,34,35,36,37,38,39,40,41,42,43,44,45,46,47,48}; uint16_t returnA[16] = {0}; uint16_t returnB[16] = {0}; uint16_t returnC[16] = {0}; TwiWrite(32, valuesA, 16); nrf_delay_ms(10); TwiWrite(64, valuesB, 16); nrf_delay_ms(10); TwiWrite(96, valuesC, 16); nrf_delay_ms(10); TwiRead(32 , returnA, 16); nrf_delay_ms(10); TwiRead(64 , returnB, 16); nrf_delay_ms(10); TwiRead(96 , returnC, 16);
The EEPROM during debugging (optimization level 0) does not return buffer B or C, it keeps on returning A as seen in the following video: https://youtu.be/geM4tW3MBvw
What could be going wrong here?
