Is LFCLK enabled after zboss_start();? and after zboss_start_no_autostart()?
I would like to know if the LFCLK is enabled after zboss_start(); and after zboss_start_no_autostart().
I would like to use an rtc event to trigger a PPI routine and this requires the LFCLK running while the device is in sleeping mode.
I have not found any info about how the zboss library handles the LFCLK. Neither any reference to any function to request to keep the  LFCLK running. Sorry if I missed any info.
Thanks for your help
Armand
  • Hi Armand,
    No, LFCLK is not enabled/running after zboss_start(), but it's initialized by the application for use for in app_timer (timers_init()), which is used by zboss.
    You can use the app_timer in the application as well, without any modifications, but you should not change the NRF_RTC1->CC[N] registers.
    If you are not using the Softdevice you could also use RTC0.
    Marjeris
