SOFTDEVICE: ASSERTION FAILED
I am working to implement the BLE stack for a HID keyboard, borrowing/based off the supplied example "ble_peripheral/ble_app_hids_keyboard".
Stack initialization and other variable initialization appear to complete successfully, however shortly after branching away from the initializing code, I am seeing an assert come from the softdevice core (SOFTDEVICE: ASSERTION FAILED, pc=0x0000C578). I am using S112.
I am sure this is due to my misuse/mis-configuration of the system, however I'm not sure where to go with the only information being the program counter pointing somewhere into softdevice.
A few more potentially relevant details: I am using a proprietary RTOS in the application code, which does utilize SV calls, however I don't think any of the swi numbers are conflicting (all less than 0x0F), as I verified the 'forwarded' vector table being invoked properly. The assert also happens well before the OS has started the first task (it's during task allocation when the assert happens). I am using a custom hardware platform, with the NRF52832-QFAA. Softdevice is configured to use the internal RC oscillator (16+2 recommended steering settings).
Any pointers in the right direction is much appreciated, thank you!
[Edit]
I am working in IAR 8.40, debugging via J-Link. The behavior, succinctly, is as follows:
1. Boot up OK
2. Initialize BLE stack and dependencies OK
3. Start application RTOS OK
4. Various tasks and systems running OK
5. Enable advertising -- returns OK
6. Various tasks continue to run OK
7. Suddenly get softdevice assert, program counter is always 0x000127B8 now PROBLEM
