How do I use button Push Interrupt
I want to change Variable state( 0->1 or 1->0) when I push the button.
I was searching for example relating to the GPIO.
but I did not find that i want.
Everything is a timer example
I would like to implement a function that operates when just press a button(using a interrupt).
You can do the advice would be appreciated.
I'd like to get help on how to implement.
What should I do?
I use nrf51822-DK and small button.
  • You can use the GPIOTE module (nRF51 Series Reference Manual section 14). Here is a small example that will toggle a LED when you push a button:
    #include "nrf_gpiote.h"
    #include "boards.h"
    #define GPIOTE_CHANNEL_0 0
    // Interrupt handler
    void GPIOTE_IRQHandler(){
    	  nrf_gpio_pin_toggle(BSP_LED_0);
    	  NRF_GPIOTE->EVENTS_IN[0] = 0;
        nrf_gpio_cfg_output(BSP_LED_0);  //Configure LED 0 as output
    	nrf_gpio_cfg_input(BSP_BUTTON_0,BUTTON_PULL); //Configure button 0 as input
        //Configure GPIOTE channel 0, to generate an event from button 0:
    	nrf_gpiote_event_config(GPIOTE_CHANNEL_0, BSP_BUTTON_0, NRF_GPIOTE_POLARITY_HITOLO);
    	NRF_GPIOTE->INTENSET = GPIOTE_INTENSET_IN0_Enabled; //Set GPIOTE interrupt register on channel 0
    	NVIC_EnableIRQ(GPIOTE_IRQn); //Enable interrupts
        for(;;){}
  • Hii all,
    I used same code for nrf51422 DK. But I'm not getting whats going wrong as I'm new to this environment. As pca10028.h is configured for Nrf51422 hence BSP_LED_0 is pin 21 and BSP_Button_0 is pin17.
    Please help.
