Sending raw beacon data from nrf52832 to external device esp8266 via UART
Hello everyone,
I'm currently working on a project that requires a nrf52832 chip to relay raw beacon data over UART to an esp-12F module. I am having a difficult time figuring out why it is not working. When running the program the esp module does not receive anything on it's input buffer. I am using an off the shelf device with the schematic showing connecting UART terminals. This example was created using the ble_app_uart_c example from the NRF5 SDK 15.3, also using the s132 soft device and my development environment of choice is keil µvision. Everything builds and compiles just fine and I only run into visible problems when I use a debugger.
When I try to debug the code with the NRF52 DK I am getting stuck in this while loop. Is there a problem with the way I #defined DEBUG?
Here is the code I am using right now.
#include <stdio.h>
#include <stdint.h>
#include <stdbool.h>
#include "nordic_common.h"
#include "app_error.h"
#include "app_uart.h"
#include "ble_db_discovery.h"
#include "app_timer.h"
#include "app_util.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_gap.h"
#include "ble_hci.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "ble_nus_c.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_ble_scan.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
#define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
#define RETARGET_ENABLED        1
#define DEBUG					1
#define UART_TX_BUF_SIZE        1024                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE        1024                                     /**< UART RX buffer size. */
BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
BLE_NUS_C_DEF(m_ble_TnP_c);                                             /**< BLE TnP client instance. */
/**@brief TnP UUID. */
static ble_uuid128_t const m_TnP_uuid = {
			.uuid128 = {0xFD, 0xA5, 0x06, 0x93, 0xA4, 0xE2, 0x4F, 0xB1, 0xAF, 0xCF, 0xC6, 0xEB, 0x07, 0x64, 0x78, 0x25}
			/**< Little-Endian UUID bytes. */};
/**@brief Function for handling asserts in the SoftDevice.
 * @details This function is called in case of an assert in the SoftDevice.
 * @warning This handler is only an example and is not meant for the final product. You need to analyze
 *          how your product is supposed to react in case of assert.
 * @param[in] line_num     Line number of the failing assert call.
 * @param[in] p_file_name  File name of the failing assert call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
*@brief Function for starting scanning. */
static void scan_start(void)
    ret_code_t ret;
    ret = nrf_ble_scan_start(&m_scan);
    APP_ERROR_CHECK(ret);
    ret = bsp_indication_set(BSP_INDICATE_SCANNING);
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t ret;
    switch(p_scan_evt->scan_evt_id)
		 case NRF_BLE_SCAN_EVT_FILTER_MATCH:
			 int i =0;
			 ble_data_t rawBLEData =  p_scan_evt->params.filter_match.p_adv_report->data;//p_adv_report
			 printf("%s",(char*)rawBLEData.p_data);
			 app_uart_put(0x3C);
     		 for(i=0;i<rawBLEData.len;i++){
				printf("%d",rawBLEData.p_data[i]);
				app_uart_put(rawBLEData.p_data[i]);
				app_uart_put(rawBLEData.len);
				//send raw data to esp8266
			 nrf_delay_ms(1);
			 app_uart_put(0x3E);
		 }break;
         case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
        //     NRF_LOG_INFO("Scan timed out.");
             scan_start();
         } break;
/**@brief Function for initializing the scanning and setting the filters.
static void scan_init(void)
    ret_code_t          err_code;
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.connect_if_match = false;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_TnP_uuid);
    err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
 * @details This function receives a single character from the app_uart module and appends it to
 *          a string. The string is sent over BLE when the last character received is a
 *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
    static uint16_t index = 0;
    uint32_t ret_val;
    switch (p_event->evt_type)
        /**@snippet [Handling data from UART] */
        case APP_UART_DATA_READY:
            index++;
            if (data_array[index - 1] == '\n' /*|| (index >= (max_data_len))*/)
             //   NRF_LOG_DEBUG("Ready to send data to ESP8266 module");
                do
                    ret_val = ble_nus_c_string_send(&m_ble_TnP_c, data_array, index);
                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
                        APP_ERROR_CHECK(ret_val);
                } while (ret_val == NRF_ERROR_RESOURCES);
                index = 0;
        //    NRF_LOG_ERROR("Communication error occurred while handling UART.");
        case APP_UART_FIFO_ERROR:
         //   NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
 * @brief Function for handling shutdown events.
 * @param[in]   event       Shutdown type.
static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
    switch (event)
        case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
            // Prepare wakeup buttons.
    return true;
NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
	int i=0;
		case BLE_GAP_EVT_ADV_REPORT:
			 app_uart_put(0x3C);
			 printf("%s",(char*)p_ble_evt->evt.gap_evt.params.adv_report.data.p_data);
		for(i=0;i<p_ble_evt->evt.gap_evt.params.adv_report.data.len;i++){
					app_uart_put(p_ble_evt->evt.gap_evt.params.adv_report.data.p_data[i]);
				//	app_uart_put(p_adv_report->data.p_data[i]);
		//		nrf_delay_ms(1);
				app_uart_put(0x3E);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
            //    NRF_LOG_INFO("Connection Request timed out.");
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            // Accepting parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                    &p_gap_evt->params.conn_param_update_request.conn_params);
         //   NRF_LOG_DEBUG("PHY update request.");
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
    uint32_t ram_start = 0;
    // Enable BLE stack.
 * @param[in] event  Event generated by button press.
    switch (event)
        case BSP_EVENT_SLEEP:
            nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
/**@brief Function for initializing the UART. */
static void uart_init(void)
        .rx_pin_no    = RX_PIN_NUMBER,
        .tx_pin_no    = TX_PIN_NUMBER,
        .use_parity   = false,
        .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                       UART_RX_BUF_SIZE,
                       UART_TX_BUF_SIZE,
                       uart_event_handle,
                       APP_IRQ_PRIORITY_LOWEST,
                       err_code);
/**@brief Function for initializing buttons and leds. */
static void buttons_leds_init(void)
    bsp_event_t startup_event;
    err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
/**@brief Function for initializing the timer. */
static void timer_init(void)
 * @details Handles any pending log operations, then sleeps until the next event occurs.
        nrf_pwr_mgmt_run();
    // Initialize.
    timer_init();
	uart_init();
    buttons_leds_init();
    power_management_init();
    ble_stack_init();
    scan_init();
    // Start execution.
    scan_start();
    // Enter main loop.
    for (;;)
        idle_state_handle();
Can anyone possibly help and see what I'm doing wrong?
Thank you so much in advance.
