i want to enable
void (*cb)(void); this line
this code
how to enable it like second img in segger embedded studio?
i want to enable
this code
Hi
What do you mean by enabling that line?
This function pointer can be used to register a callback that will be called when the sensor has data ready to be processed.
In the Thingy code it is connected to the static void mpulib_data_handler(void * p_event_data, uint16_t event_size) function on line 322 of drv_motion.c.
Best regards
Torbjørn
Hi!
I mean when i build this project i got this error " 'struct int_param_s' has no member named 'cb' ".
So i was thought i have to enable 'void (*cb)(void); #endif' this line code like second image.
Hi
You need to define one of the EMPL_TARGET_xxx defines, such as EMPL_TARGET_UC3L0 or EMPL_TARGET_NRF52.
Can you confirm whether or not you have done this?
Best regards
Torbjørn
Thank you for your great answer! I didn't define about EMPL_TARGET_NRF52 and problem is solved!
I am happy to help. Glad to hear you found the problem
