Multiple timers using app_timer
Hi devs,
It is not a real issue it is about a possible misconception about app_timer
For my application, I am using multiples timers using app_timer_create. From my understanding, the app_timer runs over RTC1, and each instance (timers created) depends on  RTC1 and RTC1's interruptions.
My question: is there any chance when using multiples timers based on app_time it increases the power consumption?
Arepa
  • Hi
    The main impact on current consumption from the app_timer module is the total frequency of interrupts, not how many timers you set up. Each app_timer callback requires the MCU to wakeup from sleep, and run whatever code you add to the app_timer callback.
    In other words, if you have 10 app_timers running at a 1Hz frequency current consumption will be much less than one app_timer running at a 1000Hz frequency.
    Best regards
    Torbjørn
