mqtt_simple sample is broken on the last version
I found something SDK scripts have issues with long paths under Windows, could you fix that please ?
I believe that the long path issue is a Windows limitation and Nordic can't do much with that on their end unfortunately(except shortening their own path/file names). I suggest that you shorten the path to the NCS directory to ensure that the total length is below 256 characters.
Alternatively you can try to follow the method explained here, as it's possible to extend the limit(though it may not apply to all programs).
Hope it helps.
Thank you for your help Carl.
My pleasure. Did it work?
I have shorten my path before your answer so I don't know. Thank you for your help.
