RTE\Device\nRF52832_xxAA\system_nrf52.c(29): error: #5: cannot open source input file "nrf_erratas.h": No such file or directory
I am using nRF52832, And SDK 15.3, the ble_app_blinky project,
   a.   if i have installed only the latest version of Device family 8.29.0 ,  when i try to build the project, it asks for permission to install 8.24.1 also.as shown in below fig
b. If I install version 8.24.1 in the pack installer as shown below, I get an error with erratas.h file
I have tried the solution given in other thread, to delete a file in module folder. But the error still persists.
Can anyone kindly guide me?
    I had exactly the same problem but finally I've sorted this issue:
    1. Remove nRF_DeviceFamilyPack version 8.29 because it looks like automatically add to system_nrf_528xx #include "nrf_erratas.h" which makes a problem.
    I am using 8.24.1
    2. Close Keil
    2. Unzip once again the SDK and open blinky project (just to clear)
    3. Compile and should work.
  • i have uploaded sdk 15 BLE blinky example, s132 soft device
    The nrf connect reads as below,
    2019-11-11T07:50:18.248Z INFO Application data folder: C:\Users\bjnag\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
    2019-11-11T07:50:19.780Z DEBUG App pc-nrfconnect-programmer v1.2.3 official
    2019-11-11T07:50:19.781Z DEBUG App path: C:\Users\bjnag\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
    2019-11-11T07:50:19.781Z DEBUG nRFConnect 3.2.0 is supported by the app (^3.2.0)
    2019-11-11T07:50:19.781Z DEBUG nRFConnect path: C:\Users\bjnag\AppData\Local\Programs\nrfconnect\resources\app.asar
    2019-11-11T07:50:19.782Z DEBUG HomeDir: C:\Users\bjnag
    2019-11-11T07:50:19.782Z DEBUG TmpDir: C:\Users\bjnag\AppData\Local\Temp
    2019-11-11T07:50:19.847Z INFO Using nrfjprog library 10.3.0, pc-nrfjprog-js 1.5.8
    2019-11-11T07:50:28.933Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:51:22.259Z INFO Target device closed.
    2019-11-11T07:51:24.473Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:51:26.998Z INFO Using J-Link Software version 6.50
    2019-11-11T07:51:32.641Z INFO Segger serial:  519001316
    2019-11-11T07:51:32.642Z INFO Segger speed:  2000  kHz
    2019-11-11T07:51:32.643Z INFO Segger version:  J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
    2019-11-11T07:51:32.683Z INFO Probed: 519001316.
    2019-11-11T07:51:32.684Z INFO Model: NRF52832_xxAA_REV1.
    2019-11-11T07:51:32.685Z INFO RAM: 64KiB.
    2019-11-11T07:51:32.685Z INFO Flash: 512KiB in pages of 4KiB.
    2019-11-11T07:51:36.112Z INFO Reading device non-volatile memory. This may take a few seconds.
    2019-11-11T07:51:41.098Z INFO Non-volatile memory has been read. 5 non-empty memory blocks identified.
    2019-11-11T07:51:41.259Z INFO SoftDevice detected, id 0x81 (S132 v2.0.0)
    2019-11-11T07:53:32.606Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:53:35.425Z INFO Using J-Link Software version 6.50
    2019-11-11T07:53:38.350Z INFO Segger serial:  519001316
    2019-11-11T07:53:38.351Z INFO Segger speed:  2000  kHz
    2019-11-11T07:53:38.351Z INFO Segger version:  J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
    2019-11-11T07:53:38.370Z INFO Probed: 519001316.
    2019-11-11T07:53:38.371Z INFO Model: NRF52832_xxAA_REV1.
    2019-11-11T07:53:38.371Z INFO RAM: 64KiB.
    2019-11-11T07:53:38.371Z INFO Flash: 512KiB in pages of 4KiB.
    2019-11-11T07:53:40.198Z INFO Reading device non-volatile memory. This may take a few seconds.
    2019-11-11T07:53:44.902Z INFO Non-volatile memory has been read. 6 non-empty memory blocks identified.
    2019-11-11T07:53:45.102Z INFO SoftDevice detected, id 0x81 (S132 v2.0.0)
    2019-11-11T07:54:01.696Z INFO Recovery procedure finished
    2019-11-11T07:54:01.711Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:54:03.836Z INFO Using J-Link Software version 6.50
    2019-11-11T07:54:06.367Z INFO Segger serial:  519001316
    2019-11-11T07:54:06.367Z INFO Segger speed:  2000  kHz
    2019-11-11T07:54:06.367Z INFO Segger version:  J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
    2019-11-11T07:54:06.385Z INFO Probed: 519001316.
    2019-11-11T07:54:06.386Z INFO Model: NRF52832_xxAA_REV1.
    2019-11-11T07:54:06.386Z INFO RAM: 64KiB.
    2019-11-11T07:54:06.386Z INFO Flash: 512KiB in pages of 4KiB.
    2019-11-11T07:54:08.501Z INFO Reading device non-volatile memory. This may take a few seconds.
    2019-11-11T07:54:13.145Z INFO Non-volatile memory has been read. 1 non-empty memory blocks identified.
    2019-11-11T07:54:15.223Z INFO Parsing HEX file:  C:\Users\bjnag\Desktop\Softwares\s132_nrf52_7.0.1_softdevice.hex
    2019-11-11T07:54:15.435Z INFO File was last modified at  8/29/2019, 10:57:45 AM
    2019-11-11T07:54:15.600Z INFO Data block: 0x00000000-0x00000B00 (0x00000B00  bytes long)
    2019-11-11T07:54:15.601Z INFO Data block: 0x00001000-0x000258C0 (0x000248C0  bytes long)
    2019-11-11T07:54:15.603Z INFO SoftDevice detected, id 0xCB (S132 v7.0.1)
    2019-11-11T07:54:22.910Z INFO Writing procedure starts
    2019-11-11T07:54:32.305Z INFO Write procedure finished
    2019-11-11T07:54:32.311Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:54:34.588Z INFO Using J-Link Software version 6.50
    2019-11-11T07:54:37.345Z INFO Segger serial:  519001316
    2019-11-11T07:54:37.346Z INFO Segger speed:  2000  kHz
    2019-11-11T07:54:37.346Z INFO Segger version:  J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
    2019-11-11T07:54:37.368Z INFO Probed: 519001316.
    2019-11-11T07:54:37.369Z INFO Model: NRF52832_xxAA_REV1.
    2019-11-11T07:54:37.369Z INFO RAM: 64KiB.
    2019-11-11T07:54:37.369Z INFO Flash: 512KiB in pages of 4KiB.
    2019-11-11T07:54:39.286Z INFO Reading device non-volatile memory. This may take a few seconds.
    2019-11-11T07:54:44.197Z INFO Non-volatile memory has been read. 3 non-empty memory blocks identified.
    2019-11-11T07:54:44.334Z INFO SoftDevice detected, id 0xCB (S132 v7.0.1)
    2019-11-11T07:54:44.336Z INFO SoftDevice detected, id 0xCB (S132 v7.0.1)
    2019-11-11T07:54:54.820Z INFO Using nrfjprog to communicate with target
    2019-11-11T07:54:57.112Z INFO Using J-Link Software version 6.50
    2019-11-11T07:54:59.873Z INFO Segger serial:  519001316
    2019-11-11T07:54:59.873Z INFO Segger speed:  2000  kHz
    2019-11-11T07:54:59.873Z INFO Segger version:  J-Link Lite-Cortex-M V9 compiled May 17 2019 09:50:01
    2019-11-11T07:54:59.893Z INFO Probed: 519001316.
    2019-11-11T07:54:59.894Z INFO Model: NRF52832_xxAA_REV1.
    2019-11-11T07:54:59.894Z INFO RAM: 64KiB.
    2019-11-11T07:54:59.896Z INFO Flash: 512KiB in pages of 4KiB.
    2019-11-11T07:55:02.055Z INFO Reading device non-volatile memory. This may take a few seconds.
    2019-11-11T07:55:06.762Z INFO Non-volatile memory has been read. 4 non-empty memory blocks identified.
    2019-11-11T07:55:06.899Z INFO SoftDevice detected, id 0xCB (S132 v7.0.1)
    2019-11-11T07:55:06.901Z INFO SoftDevice detected, id 0xCB (S132 v7.0.1)
    But, when i open BLE of nRF COnnect, i get the following error
    08:55:11.147	Application data folder: C:\Users\bjnag\AppData\Roaming\nrfconnect\pc-nrfconnect-ble
    08:55:15.499	Validating connectivity firmware for device with serial number 000519001316...
    08:55:18.629	Error while setting up device 000519001316: No serial port available for device with serial number 000519001316
    08:55:18.636	Device closed.
    08:55:57.585	Validating connectivity firmware for device with serial number 000519001316...
    08:55:59.726	Error while setting up device 000519001316: No serial port available for device with serial number 000519001316
    08:55:59.730	Device closed.
    09:02:04.763	Validating connectivity firmware for device with serial number 000519001316...
    09:02:07.461	Error while setting up device 000519001316: No serial port available for device with serial number 000519001316
    09:02:07.467	Device closed.
    ANd i cant view the device in App either
  • Hi Nagashree
    What device is it that you're struggling to set up in nRFConnect? Is this a development kit or a custom board?
    As for the new error, you should try including the path to the file "nrf52832_erratas.h". I don't know exactly where this file is located on your system but you should be able to find it somewhere.
    Simon
