ISSUES DUE TO "UNABLE TO FIND OR OPEN THE JlinkARM.dll"
HI,
  •  We are mainly using "nRFgo Studio" and "nRF Connect" application for erasing and flashing codes to our custom board and its taking place successfully for a long time.
  • The hardware tools we are using for flashing the code is "J-LINK BASE " version 10.1.
  • But now  we can't able to flash or erase the code to our custom board either with "nRFgo Studio" or nRF  Connect.I don,t known why its happening?
When i tried to erase the code in our custom board using "nRFgo Studio"
When i tried to read our custom board using "nRF_Connect" its not reading look the below screen shot
DOUBTS
  • What is the reason behind these issues?
  • Is it a problem with our custom board or with jlink tool?
  • What are the solution for these problems?
Please reply as soon as you can possible . Its a major issue with us.
  • Nandhu, the device does not work as it should, meaning that something is wrong. This can be ESD damage while debugging (clear tape can cause this), or other issues. However; in order to figure this out, you need to debug your design to figure out what is wrong.
    Try swap-testing, where you take a bad board and a good board, then swap the chip on those. See if the problem follows the nRF.
    Håkon
  • Hakson,
    The error started showing on four pre-production boards suddenly. We doubt this could be caused due to handling. The nrf52832 were assembled by our contract manufacture. Could you provide instructions on how to swap the chips?
    Also, are there any hardware checks we could do by probing any of nrf52832 pins?
    What was done to all the boards prior to when this happened? If all boards stopped working at the same time, there should be a common denominator.
    Here is a video on how to change a QFN IC: https://www.youtube.com/watch?v=_1PXEp0RQ7s
    If you are unsure on how to do this, I would recommend getting help from a colleague or the contract manufacturer.
    You can check the current consumption, and the voltage to ensure that is OK. You could also check certain GPIOs to see if they behave as defined in the firmware that is currently loaded onto the devices.
    Håkon
