APP_ERROR_CHECK(err_code); undeclared identifier
I'm starting with nrf52 dk using Keil ide for ANT+ applications...
I tried to run an example inside the sdk folder and I have problems with app_error functions.
All called check functions was not declared. I included paths for components, softdevices, etc., but the errors persists.
I'm using SDK15.3 and keil IDE 5.28
thanks for help
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(417): error:  #20: identifier "NRF_ERROR_SOC_BASE_NUM" is undefined
      return NRF_ERROR_SOC_NVIC_INTERRUPT_PRIORITY_NOT_ALLOWED;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(421): error:  #20: identifier "NRF_SUCCESS" is undefined
    return NRF_SUCCESS;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(429): error:  #20: identifier "NRF_SUCCESS" is undefined
      return NRF_SUCCESS;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(433): error:  #20: identifier "NRF_ERROR_SOC_BASE_NUM" is undefined
      return NRF_ERROR_SOC_NVIC_INTERRUPT_NOT_AVAILABLE;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(440): error:  #20: identifier "NRF_ERROR_SOC_BASE_NUM" is undefined
    return NRF_ERROR_SOC_NVIC_SHOULD_NOT_RETURN;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(463): error:  #20: identifier "NRF_SUCCESS" is undefined
    return NRF_SUCCESS;
..\..\..\..\..\..\..\components\libraries\util\nrf_nvic.h(480): error:  #20: identifier "NRF_SUCCESS" is undefined
    return NRF_SUCCESS;
..\..\..\..\..\..\..\external\segger_rtt\SEGGER_RTT_printf.c: 0 warnings, 19 errors
compiling nrf_sdh_ant.c...
..\..\..\..\..\..\..\components\softdevice\common\nrf_sdh_ant.c(89): error:  #20: identifier "NRF_SUCCESS" is undefined
      if (ret_code == NRF_SUCCESS)
..\..\..\..\..\..\..\components\softdevice\common\nrf_sdh_ant.c(126): error:  #20: identifier "NRF_SUCCESS" is undefined
          if (ret_code != NRF_SUCCESS)
..\..\..\..\..\..\..\components\softdevice\common\nrf_sdh_ant.c(149): error:  #20: identifier "NRF_ERROR_NOT_FOUND" is undefined
      if (ret_code != NRF_ERROR_NOT_FOUND)
..\..\..\..\..\..\..\components\softdevice\common\nrf_sdh_ant.c: 0 warnings, 3 errors
compiling system_nrf52.c...
".\_build\nrf52832_xxaa.axf" - 664 Error(s), 0 Warning(s).
    In order to run ANT examples, you must first obtain the ANT SoftDevice you want to use, as per the chapter in the documentation, "Running ANT examples":
    https://infocenter.nordicsemi.com/topic/sdk_nrf5_v16.0.0/ant_advanced_burst.html?cp=5_1_4_0_0
    Håkon
    Thanks for your answer...
    I followed the procedures of this tutorial, including the ANT headers files, but the error continue....
    below, the part of build output. The compiler not foud the nrf_error.h. I unziped the sdk file in the path of my hard disk (example: C:\nRF5_SDK_15.3.0_59ac345)
    ..\..\..\..\..\..\components\libraries\log\src\nrf_log_frontend.c(293): error:  #20: identifier "NRF_SUCCESS" is undefined
              if (module_idx_get(&module_id, ordered_idx) == NRF_SUCCESS)
    ..\..\..\..\..\..\components\libraries\log\src\nrf_log_frontend.c(303): error:  #20: identifier "NRF_SUCCESS" is undefined
    ..\..\..\..\..\..\components\libraries\log\src\nrf_log_frontend.c(512): error:  #20: identifier "NRF_SUCCESS" is undefined
          if (nrf_ringbuf_alloc(&m_log_push_ringbuf, &p_dst, &ssize, true) == NRF_SUCCESS)
    ..\..\..\..\..\..\components\libraries\log\src\nrf_log_frontend.c: 0 warnings, 29 errors
    compiling nrf_sdh.c...
    ".\_build\nrf52832_xxaa.axf" - 659 Error(s), 0 Warning(s).
    Target not created.
    Build Time Elapsed:  00:00:17
  • are you certain that you unzipped the headers to this exact location, with the same folder structure?
    The SDK does not include the header files for the ANT SoftDevices. You must add them to your project before you can compile your application. To do so, extract the downloaded zip file that contains the SoftDevice and copy the SoftDevice headers to components/softdevice/SoftDevice/headers.
    If you open your project settings, you can see the expected path for the headers, here's an example from one of the examples:
    ..\..\..\..\..\..\..\components\softdevice\s212\headers;
    ..\..\..\..\..\..\..\components\softdevice\s212\headers\nrf52;
    Håkon
