Hi
We are doing field trials of a nRF52840 product with s140 SD, now and again NFC stops working (tag type-4, read and write).
This has been seen in SDK15.3.0 with SD6.1.1 and SDK16.0.0 with SD7.0.1.
Basically NFC stops responding, all NFC callbacks stop but nothing else is affected, when the nRF52840 wakes from sleep or is reset NFC works fine again.
It doesn't seem to be repeatable although I have seen the issue three times, once when debugging, other users a lot more - we use or own PCB NFC antenna, can this be causing too high a voltage at resonance? Or is it the NFC engine itself?
The data sheet states that NFC current must be limited to 80mA and the nRF52840 shorts the NFC pins when greater than 2V. Can the NFC pins be AC coupled or will this mess up any DC biasing? Can series resistance be added?
Thanks
Ken...
